Old 11-08-2018, 03:59 PM   #19
redbean
Drives: 09 Yaris hatchback
Originally Posted by tmontague View Post
It's normal for a m/t car to "buck" in first gear. If you want to roll in traffic in 1st then you'll have to press the clutch pedal
And that's a great way to burn out your clutch / throwout bearing, right? I guess I have to change my driving style a bit. In the US where everyone drives automatics, everyone creeps up in traffic because all you do is let your foot off the brake. Now when I drive an automatic, it's starting to feel weird that it pulls forward without my foot on the gas.
When you all say "double clutch into reverse", do you mean after going forward and stopping, or just any time you put it into reverse? Do you rev it? My Yaris crunches into reverse about 75% of the time regardless of whether I just started the car and back out of a parking space, or go from 1st to R to parallel park.
I'm also trying to work on making sure the revs are right when shifting, but it's hard to know where I'm supposed to be without a tach.
redbean is offline   Reply With Quote
Old 11-08-2018, 05:53 PM   #20
dogsridewith
Drives: 2007 2-door hatchback
No crunch reverse gear manual transmission Toyota Yaris
No need to double clutch into reverse...in fact single clutch probably works better. If in neutral and idling, push down the clutch pedal (to the floor stop on a Yaris), shift into second and then, without touching throttle or lifting clutch foot, shift right over into reverse. Skillfully add throttle and lift clutch foot to drive backwards.
(And stop the car before doing all this.)
(Doesn't have to be second gear to do this, but might as well use a forward gear that isn't sticky or showing worn syncro symptoms.)
Old 11-11-2018, 09:25 AM   #21
bentjazz
Drives: 2009 Yaris--3dr MT
Finally got around to test driving the low miles, manual Yaris mentioned in this post. The manual shifter felt like what I imagine a 90 year old with arthritis feels like....stiff as hell. I must say I wasn't impressed, at all. Perhaps it was just that particular Yaris. Be that as it may, I'll be sticking with my automatic Yaris for the foreseeable future. While I was there, I did drive one of their Honda Fit manuals. It was a dream compared to the Yaris. Smooth as silk and a real pleasure to drive. If it didn't have so many miles, I might have bought it.
Old 11-12-2018, 08:15 AM   #22
dogsridewith
Stiff into which gears?
Did the clutch release (the motor loads up and the car starts to move) when the pedal is still almost right at the floor stop?
Old 11-12-2018, 04:24 PM   #23
bentjazz
dogsridewith, seemed like it was stiff into all gears. It really sucked, to be quite honest. The shifting process was sound, but it was just stiff in all gears. I couldn't imagine driving that Yaris every day. I'd go bonkers and end up in the nut house, for sure. Love my auto Yaris, however. In all actuality, there had to be something wrong with that manual. First time I've ever driven a Yaris manual, so I hope to God not all Yaris manuals are like that one. The Honda Fit manual, however, was really awesome. Loved it.
Old 11-12-2018, 05:52 PM   #24
DarkShadowFox
short shifter.
Old 11-12-2018, 09:06 PM   #25
dogsridewith
Maybe why it was for sale.
Old 11-15-2018, 01:50 PM   #26
redbean
I have to say, I drove a Honda Fit manual before I pulled the trigger on the Yaris, and I hated the shifter. It felt like cheap plastic and metal that would explode in my hand if I shifted it too aggressively.
Old 12-11-2018, 02:09 PM   #27
maximumunicorn
Drives: 2003 Tundra, 2008 Yaris
I just test drove an '08 Yaris base with 56k miles and the manual transmission felt great to me (shifter wasn't stiff in this example at least). I prefer it to the two Fits I've test driven. Clutch engagement is higher in the pedal stroke than I was expecting in the Yaris, but nothing you couldn't get used to.
maximumunicorn is offline   Reply With Quote
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
2YR/25K Retrospective/Review (French-Built 2015 Yaris SE, Manual 5-spd) Kalispel Third Gen Yaris General Discussion 12 08-24-2017 11:26 AM
Yaris 2011 repair manual. gitmoyaris DIY / Maintenance / Service 2 08-22-2017 11:10 PM
07 yaris 4d4 automated manual serious issues maximapitko DIY / Maintenance / Service 3 07-04-2010 12:46 PM
