Old 06-05-2019, 03:56 PM   #19
Pinchlite
Drives: 2007 yaris HB
There are six heat shields in total. The other 5 are all under the car. You'll have to get under there and check them all for corroded connection points. I've had to deal with 3 underbody shields over the past few years.
Sent from my EML-L09 using Tapatalk
Got it solved.It was a thicker metal flange around the exhaust.A spot weld came undone.Mechanic retacked and all is good.
Pinchlite is offline   Reply With Quote
Old 07-15-2020, 11:14 AM   #20
Pinchlite
Originally Posted by DarkShadowFox View Post
Oh oh oh check your water pump/ water pump seal.
I know this is old but how do I do that.
I only get the noise when it is really hot weather.
Old 07-15-2020, 11:17 AM   #21
Pinchlite
Clackling sound only hot weather.
My best guess is that the heat shield around the exhaust manifold has rusted in one or several locations and is rattling. The easiest fix is just rip it off.
The noise is stil there.all shields removed even underneath car.
Had 2 mechanics go over exhaust while having other work done.
I do notice I only get the noise in really hot weather,
Not a peep all winter and cooler months.
Old 02-08-2021, 02:28 AM   #22
rayfloyd170
Drives: Yaris 2016 1.3 Manual
do you get a manual trans? if yes then check the 2 shifter cables if they are rubbing against each other... i just had a hard 2 months figuring out mine and lamost ordered a clutch set as advised by 2 shop mechanics i went... with endless troubleshooting i even got 1 bolt off the exhaust damaged since i suspect the exhaust was making the sound.. when moving the engine while it is off, there is a slight sound too but that is near the exhaust and just the 2 shifter cables grinding each other... i could be wrong but it is worth a try if you have the stick shift. I placed a rubber cushion in between the metal guide and put a little grease and voila all the unusual metallic sound are gone.
rayfloyd170 is offline   Reply With Quote
Old 02-08-2021, 04:36 AM   #23
Pinchlite
Thanks and will check.....only hot weather is it present.....not a peep in colder weather.
AGAIN...ONLY HOT WEATHER noise appears!!!!
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
Raising the sound stage... SAV912 In Car Entertainment + Electronics (audio / video / alarm) 11 07-30-2011 05:26 AM
Odd Metallic Sound From The Engine Bay Kaotic Lazagna DIY / Maintenance / Service 5 08-29-2009 03:03 AM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 03:11 AM
