Old 02-05-2019, 04:04 PM   #19
Leegamer
Leegamer's Avatar
I had no idea there were 2 different gallon measurements
I'm a hermit named Lee
Old 02-05-2019, 04:07 PM   #20
Hence the 'I'm a hermit named Lee' sig. ;)
Sent from my EML-L09 using Tapatalk
Old 02-05-2019, 04:09 PM   #21
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Pretty good, if torque can be trusted. I find that the only true measurement is manually calculating with every trip to the pump.
True. I guess I would mainly loosely monitor that parameter in torque for significant changes in fuel consumption. Pretty much the same for other parameters like longer term changes in coolant temp, A/FR, voltage etc.
Old 02-05-2019, 04:26 PM   #22
2bz
Drives: 2008 Yaris 3DR Hatch MT
Update: Today (62 degrees F), I drove about 45 minutes with my OBD2 scanner plugged in. 1/3 city, 1/3 highway and 1/3 back roads. I got 42.1 MPG (imperial) or 35 MPG (US). It's been cold here and gas is 10% ethanol. Maybe it's just my kid's right foot?
2bz is offline   Reply With Quote
Old 02-05-2019, 04:26 PM   #23
Leegamer
Leegamer's Avatar
That sounds about right mileage wise.
Old 02-05-2019, 07:03 PM   #24
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Is your kid driving in top gear? Some years ago, my sister had a (different brand) 5 speed manual, and used to stay in 3rd until she got above 50 MPH. She said this gave her better acceleration...
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 02-05-2019, 07:05 PM   #25
Speaking of torque, I like to see it go 52L/100km on the instant fuel economy meter.
Sent from my CLT-L04 using Tapatalk
Old 02-05-2019, 07:38 PM   #26
myfirstyota
3 Yaris and counting..
Idle... you'll see 99L/100
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 02-05-2019, 07:41 PM   #27
Nope torque says infinite if idle.
Old 02-05-2019, 07:42 PM   #28
ex-x-fire
Is the engine running too cool? Over the winter I block the grill. Temp gets up to 185 instead of 176.
This really helped my winter MPGs but nobody believes me.http://www.yarisworld.com/forums/showthread.php?t=59283
Old 02-05-2019, 07:51 PM   #29
Hahaha mine barely sees 160°F
Old 02-05-2019, 08:33 PM   #30
myfirstyota
The car will bump idle up if the engine temp is too low. I'm currently sitting in my car, roughly freezing out, heat on full, rpm steady at 1150. In summer it's around half that. So as for the OPs questions.... It's winter. Mileage sucks. Sorry!
Old 02-05-2019, 08:41 PM   #31
dogsridewith
Drives: 2007 2-door hatchback
Teen male gasoline miles per gallon
I'm in the cold end of a narrow valley in PA. Honest avg. 36.xx mpg by box-stock (w/rear seat delete) w/ original base model odometer calibration and 3% larger tread circumference of the RS. Not hypermiling...well, maybe some of it is. Not driving like I did in the new 67 Beetle family car. Season doesn't seem to matter.
I had a learner's permit for one week. Just a couple rides w/ dad. I think he hated it. Quiet and feet pushed hard on the floor boards...do appreciate that he told me to brake real hard to see what it felt like. (Maybe he wasn't sure when I would do it again?)
Find a way to drive one tank through that Yaris.
(edit: Oops... didn't read this page of responses before posting this.)
Old 02-05-2019, 08:54 PM   #32
06YarisRS
Haha. In my van, I can see a couple hundred L per 100 km if I stomp on it.
Old 02-05-2019, 09:50 PM   #33
myfirstyota
Kinda glad I never hooked torque up to the old hemi lol
Old 02-05-2019, 09:59 PM   #34
06YarisRS
Haha, just makes you wonder how long it would take to drain a tank if you kept on it. The Lambda v6 in my van likes its fuel when tromped on, and it's obvious as this minivan is like a rocket despite being almost 2.5 tons.
Old 02-05-2019, 10:38 PM   #35
myfirstyota
The hemi? My honest estimation, probably about 45min to an hour on a 90something liter tank hahaha
Old 02-06-2019, 06:40 AM   #36
ex-x-fire
Sound like you have a t stat that isn't closing fully, stuck open, or opening too soon.
Noobie Advice Needed ianmak UK 7 10-17-2017 02:00 PM
Need some advice about air filters srm73 Performance Modifications 22 09-10-2016 11:31 PM
Good advice for new car owners... YarisSedan General Yaris / Vitz Discussion 10 04-15-2009 03:43 PM
Legal advice needed Rahxephon Off-topic / Other Cars / Everything else Discussions 8 09-24-2007 04:56 PM
