Old 03-29-2019, 01:32 PM   #19
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
And don't forget you can shift an auto transmission too. Put it in a lower gear if need be. Can help take some stress of the brakes when descending.
Old 03-29-2019, 02:41 PM   #20
If you are new to small engines then make sure you don't shy away from putting the pedal all the way down and having the rpm go to the limit
Big engines have a lot if torque down low, small engines are typically the opposite. This will not hard a well maintained engine and it is how it is meant to be driven if you need the power.
These auto transmissions are stupid long lasting if maintained. They will easily match the mileage of the 1nz engine. I would recommend a fluid change at the 50k mile mark. That us not recommended by Toyota but I have seen the issues that "lifetime fluid" can cause *ahem Subaru CVT's*
Realistically you will probably be fine without changing the trans fluid but mountains are hard on the trans and will increase the trans temps. This would be considered "extreme conditions" in the owners manual and lead to an earlier change.
There is a trans filter but in my experience it doesn't get dirty if you keep fresh fluid in there. I've always changed out mine when I buy used cars but I've never seen a dirty one
Old 04-02-2019, 03:49 PM   #21
logoris
Drives: 2017 Yaris SE Blue Streak
my 2017 se had no issues in the Montreal mounts, main thing is dont expect to go fast up hill, and engine braking down hill will save the brakes
logoris is offline   Reply With Quote
Old 04-14-2019, 11:20 AM   #22
Bikerboy89
Drives: 2015 Yaris Liftback LE auto
Great!
The Yaris did amazing! I averaged 34.1 mpg for the trip. I love this car!
Bikerboy89 is offline   Reply With Quote
Old 04-14-2019, 11:25 AM   #23
Bikerboy89
One more photo. Near Clingmans Dome in NC.
File Type: jpeg received_564009947425239-1456x1092-1092x819.jpeg (367.3 KB, 34 views)
Old 04-15-2019, 04:17 PM   #24
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
On Instagram
On Wheelwell
Old 04-15-2019, 04:57 PM   #25
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 06:14 PM
Why Bosch auto parts doesn't list 2012 Yaris ? DanMC Third Gen Yaris General Discussion 2 04-03-2013 04:05 PM
Just Bought a 2009 Yaris Hatchback 4 Cyl Auto!! CASH DEAL!! Good Deal?????? paguy General Yaris / Vitz Discussion 13 05-28-2009 10:51 AM
