Old 10-08-2019, 03:23 PM   #1
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
Then put pump pulley then alternator on. Final tightening pump pulley with by on. I will ass a few more pics later .
Toolaholic is offline   Reply With Quote
Old 10-08-2019, 05:56 PM   #2
Toolaholic
Photos of how to pry alternator . Pry alternator til it hits adjustment mark made with a Milwaukee jobsite marker. Tighten 12 mm bolt with right hand while holding pry bar/ alternator in place with left hand. Pry off motor mount as shown
File Type: jpeg 7EF6F201-3366-423D-AC9F-1DBD8C5F6FCE.jpeg (183.7 KB, 86 views)
File Type: jpeg B098B8B4-5ED6-4533-A027-076CEC22CFC9.jpeg (289.6 KB, 82 views)
Old 10-08-2019, 05:58 PM   #3
Toolaholic
12mm Wright ratcheting wrench on alternator tensioner
File Type: jpeg 1FA386F2-4F75-4E52-9D7C-D2E9ECB2C52F.jpeg (407.5 KB, 83 views)
Old 10-08-2019, 06:03 PM   #4
Toolaholic
Torque specs : 14 lb ft alternator tensioner
40lb ft alternator bottom bolt
11nm 97 inch lbs water pump bolts/nuts
13nm 115 inch lbs water pump pulley bolts
9nm. 80 Inch lbs thermostat housing
Old 10-08-2019, 06:23 PM   #5
Toolaholic
Couldn’t fit a torque wrench even with a crows foot or torque adapter on water pump pulley . Tightened with a 0 offset hazet 10x11 TIL pulley moved and slipped belt .
File Type: jpeg DD325207-E245-4B9F-AB7D-8A7897B5257C.jpeg (199.4 KB, 81 views)
File Type: jpeg 5CE1CB90-6C19-4D0C-828B-344D2DEAEFFB.jpeg (104.0 KB, 82 views)
Old 10-08-2019, 09:37 PM   #6
Toolaholic
The gasket scrapers. A razor blade at 90 or a SK gasket scraper with my thumb on top so it stays flat .
File Type: jpeg 402A64F0-324F-44A7-96BF-D8BB183F9A2B.jpeg (141.3 KB, 82 views)
File Type: jpeg 755A4CAD-61D8-4C13-A5B1-840E68A0A38A.jpeg (71.0 KB, 81 views)
Old 10-08-2019, 09:43 PM   #7
Toolaholic
I replaced factory hose clamp with a work drive clamp. It was hard to get back on thermostat housing even when compressed all the way with hose clamp pliers .
File Type: jpeg 061852B0-1521-4C3D-A37B-EE1A220EBC0B.jpeg (211.5 KB, 82 views)
File Type: jpeg FF34E2D9-6008-4674-8523-C358D6B889B0.jpeg (341.4 KB, 82 views)
Old 10-08-2019, 09:46 PM   #8
Toolaholic
I used a asin water pump and gasket. Genuine Toyota thermostat o ring. Stant thermostat . Had alternator rebuilt at chestnut hill electric for $108. It got new brushes , bearing and voltage regulator.
Old 10-08-2019, 10:22 PM   #9
Toolaholic
10mm deep socket , 1/4 drive tekton ratchet negative battery terminal
File Type: jpeg 106C556E-EBF2-443D-B0C3-B208D66C76C1.jpeg (395.8 KB, 81 views)
Old 10-09-2019, 10:50 AM   #10
Toolaholic
Due to close proximity of fender, it takes some maneuvering to get alternator and water pump in and out but definitely doable.
Old 10-09-2019, 03:02 PM   #11
komichal
This looks like quite a bit of work! Gosh I miss my old Skoda 105, I could change this in 5 minutes there!
Old 10-09-2019, 03:44 PM   #12
Toolaholic
Wasn’t too bad. Had to finagle water pump and alternator in and out. Thin head ratchets helped a lot. It was very hard to keep socket on lowest water pump bolt when torquing to spec. Plus it was a pain scraping the minimal rubber gasket residue off due to tight quarters .
Water pump replacement guide? Mrb DIY / Maintenance / Service 5 02-05-2019 01:05 PM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Location of Water Pump lululovesu DIY / Maintenance / Service 1 10-19-2014 08:05 AM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 12:33 PM
Rear Shocks Replacement? Water Pump. babytic DIY / Maintenance / Service 7 06-15-2013 03:55 PM
