Old 04-29-2020, 08:21 PM   #19
kimona
kimona's Avatar
Drives: 2014 White VITZ
Dark is good. I really like them! You did a marvelous job. And, you created a little excitement on the yarisworld forum.
EDIT: I may consider painting the centre caps the same "root beer" colour and getting some black lug nuts.
(But, I presume you're switching caps and lugs with your other set of alloys).
Old 04-29-2020, 10:10 PM   #20
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Almost looks root beer..ish. You did an excellent job.
Old 04-29-2020, 10:30 PM   #21
Neinris
WOW!
Old 04-30-2020, 05:48 AM   #22
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Thanks! Yes, I do switch out the caps and lug nuts. However, before the discussion, I ordered another set of caps (silver). I am now eyeing some Toyota (aftermarket) black center caps - inked below - and some black lug nuts.
I have to do some measurements on the Hyundai wheel. The Yaris has a 54 mm center bore, but these caps vary from 52mm to 57mm. I think that's the outer diameter of the cap itself. But the Toyota caps actually recess into the Hyundai wheel. I think the 57mm cap would sit on top of the hole and not snap into place; not engaging the retaining tabs.
https://www.ebay.com/itm/X4-TOYOTA-W...8AAOSwUqJdu7fL
Or
https://www.ebay.com/itm/X4-TOYOTA-W...IAAOSw1p1d-xfX
EDIT: After looking at these caps again, they're kind of glossy. Maybe a more matte/flat would look better. I suppose I could clear coat them with a matte as long as the plastic didn't react adversely. Also thinking about satin or matte back lug nuts. Am I getting carried away?
EDIT 2: If the silver caps I already ordered actually fit, I could just paint them satin black.
Old 04-30-2020, 05:52 AM   #23
06YarisRS
Thanks man. Yeah, makes me want to go to A&W.
Old 04-30-2020, 05:54 AM   #24
06YarisRS
Originally Posted by Neinris View Post
WOW!
I think they're growing on me. We'll see with black lugs and center caps.
Old 04-30-2020, 07:56 AM   #25
Steve35
Steve35's Avatar
Drives: 2008 HB
Originally Posted by 06YarisRS View Post
OOh, that's nice! Super nice turbo Miata. That is an intercooler in there, right? The black does really go well with the silver/grey! Haha, just noticed the car in the background. Also silver, with black wheels. This helps. Can't quite tell from the pic, but are yours gloss or satin finish?
Turbo is right, its a 2004 Mazdaspeed Miata on one of two years Mazda turboed them. The color is Matt Black. I got them here.
https://www.good-win-racing.com/Mazd...t/61-2677.html
Steve
Steve35 is offline   Reply With Quote
Old 04-30-2020, 05:30 PM   #26
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
As I said on the 'gram, I dig it.
Interesting that Kimona favors the darker, but doesn't like black wheels. I have black wheels, but as I commented to you on Instagram, think a shade or two lighter would work even better.
Beauty is in the eye of the beholder!
On Instagram
On Wheelwell
Old 04-30-2020, 09:59 PM   #27
06YarisRS
Steve
I had a look. Very nice wheels, indeed! Before I decided to save a few bucks and go with another set of Accent rims, I was looking at these.
https://www.canadawheels.ca/fast-whe...dvehicle=81922
And for a bit more...
https://www.canadawheels.ca/ultra-wh...dvehicle=81922
Old 04-30-2020, 10:03 PM   #28
06YarisRS
Absolutely! A couple shades lighter would have been preferable. I still think black wheels would look good on my car. If the paint fails on these wheels - chips or doesn't generally wear well and they get unsightly - I'll repaint them with a single stage urethane and may go with graphite. I really think that graphite would look great against the silver.
Edit: I'm actually thinking about applying a 2K clear coat over these wheels. It is advised against - being a 1K enamel - but if I dust 2 to 3 coats on and let them flash off, I might get away with heavier coats after that. I actually sprayed a little clear coat on one of the playing cards that had over spray on it. There was no adverse reaction. I'll give the wheels a couple of weeks to cure fully if I go ahead with this.
Old 05-04-2020, 02:51 PM   #29
ern-diz
ern-diz's Avatar
On Instagram
On Wheelwell
Old 05-07-2020, 03:33 AM   #30
lacienega
lacienega's Avatar
Drives: toyota
They look great. What's the bolt pattern on these rims?
lacienega is offline   Reply With Quote
Old 05-07-2020, 06:54 AM   #31
06YarisRS
Thanks. The bolt pattern is 4 x 100.
Here's an 'informational' video I put together:
https://www.youtube.com/watch?v=y7noAaBv_5c
Old 05-07-2020, 05:13 PM   #32
lacienega
lacienega's Avatar
Drives: toyota
Thanks, good info. And the center caps are the same size from accent and toyota ?
Old 05-07-2020, 09:00 PM   #33
06YarisRS
Indeed they are for these models of Toyota and Hyundai. Not sure about other models.
Old 05-08-2020, 04:03 AM   #34
They look good. Great job with them!
DIY aftermarket steering wheel install with horn and airbag delete tmontague Performance Modifications 19 11-30-2018 12:19 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
