Old 09-03-2009, 03:00 AM   #1
RedRide
RedRide's Avatar
Since the '09s now come standard with ABS, there is no longer a choice.
I am a bit old school myself and prefer to do my own braking.
However, I'm also aware that in some near panic situations we all have tendancy to step a bit to hard on the brake pedel and lock them up.
So ABS may come in handy at those times.
Also, keep in mind that ABS has come a long way since the early days and there is no pulsating in the pedel under normal use as was once the case.
Acutually, I'm looking forward to checking out the ABS in action after the first snow storm this winter.
Hey, I may actually like it.
Old 09-03-2009, 06:11 AM   #2
yarisitis
yarisitis's Avatar
Drives: 2008 Yaris LB
I bought my car used, how am I able to tell if my car has ABS?
yarisitis is offline   Reply With Quote
Old 09-03-2009, 09:04 AM   #3
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
Smile
You drive to the edge of the Grand Canyon and lay down about 2 tons of axel grease along the lip. Drive approximately 1/4 mile away from the lip, turn around and head back towards the lip at a 90 degree angle doing about 80 miles per hour exactly at the spot where the grease was spread- you then hit the brakes very very hard right before you reach the lip.
If you can stop successfully before plunging to your gruesome death you probably have ABS!
This is referred to by technicians as testing ABS- "the hard way or sometimes the Thelma and Louise test",
Hope this helps.......or alternatively you can try what technicians call "the easy way" by looking at your instrument cluster to see if it houses an ABS light!
Lewis is offline   Reply With Quote
Old 09-03-2009, 09:39 AM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Here's an interesting starting point:
http://www.abs-education.org/faqs/faqindex.htm
Old 09-03-2009, 09:44 AM   #5
Lewis
Lewis's Avatar
Smile
I like my way better Echo_hrs!
Old 09-04-2009, 07:14 PM   #6
PhilD424
Drives: Red Yaris
I love the crap these driving schools "Teach". "Stomp Stay Clear" http://www.youtube.com/watch?v=xd5KDvXbE3M Unreal.
-Phil
PhilD424 is offline   Reply With Quote
Does your liftback have ABS? BensVitz General Yaris / Vitz Discussion 75 05-24-2011 07:11 PM
ABS....Again~~ MeggiemobileSFLA DIY / Maintenance / Service 11 04-03-2007 09:12 AM
ABS Virgin!!! yaris-intuit General Yaris / Vitz Discussion 23 11-29-2006 12:49 PM
[Survey] Does your Yaris have ABS hans_fh General Yaris / Vitz Discussion 44 11-01-2006 10:11 PM
No ABS on Sedan?? hans_fh General Yaris / Vitz Discussion 2 10-12-2006 03:39 PM
