Old 06-20-2023, 11:44 PM   #1
komichal
Usually a vinyl glove and a rag are all that help me keep this job clean.
I am not an engine designer so I have no idea about whats going on inside.
I am just wondering why nobody else came up with this method yet. It is hard to believe that it would be so good and perfectly safe, yet unrevealed till now.
I am always grateful for all the tricks people share, yet it this specific case, I would stick to the traditional way of doing things as the number of potential disadvantages hugely superseeds the advantage.
Old 06-21-2023, 07:10 AM   #2
ex-x-fire
Connecting rod bearings are under a lot of pressure, so when there's no pressurized oil there is wear.
Old 06-21-2023, 08:29 PM   #3
andulong
andulong's Avatar
Drives: 2008 Hatch Red
You might think this is fine but do you notice a trend?...no one else thinks it is a good idea. I would not purchase a car from you sir!
andulong is offline   Reply With Quote
Old 06-23-2023, 12:14 AM   #4
mirageman
Drives: 2009 yaris
Perhaps a modified version of pulling the efi fuse and simply cranking for 10 or 15 seconds would ease some stress here ... or simply running it for like 5 seconds instead of waiting until the light comes on would be enough to get a clean removal of that filter. Yes, darn it... I know I can clean the mess or awkwardly contain it, but I don't want to oil up bags, or cups or wear gloves. What I also like is the idea of pumping out much more used oil than a regular change.
mirageman is offline   Reply With Quote
Old 06-23-2023, 01:17 AM   #5
Ecefour
Drives: 2007 Yaris Hatch
I change the oil when the engine is still hot. First I nearly break the oil filter seal by hand. I keep the filter on just tight enough that engine oil doesn’t start leaking out, but lose enough that i can spin the oil filter off with just my thumb. Then i use my thumb to loosen the filter more until the oil starts to leak out. I can quickly pull my hand away before it gets oily. Once the oil stops dripping i can grab the filter with a paper towel near the top, in an area that the oil didn’t touch. This way I avoid getting oil on my hands and down my arm.
I also tend to complete my oil changes right before my nightly shower, so getting dirty is irrelevant. Why would you risk your engine like this? To each there own
Ecefour is offline   Reply With Quote
Old 07-02-2023, 02:28 PM   #6
Mister
Drives: Yaris T1
I crack the filter from the bottom and then spin it off from the top of the engine (Model T1 has enough space for this). So no mess for me. :)
Mister is offline   Reply With Quote
oil filter change SmartyPants DIY / Maintenance / Service 2 09-05-2011 12:19 AM
HOW TO CHANGE YOUR OIL & FILTER "G" DIY / Maintenance / Service 2 08-14-2011 09:20 PM
Oil Change Help Filter Stuck YarisLover09 DIY / Maintenance / Service 21 06-02-2011 08:57 AM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
