Old 06-20-2007, 03:01 PM   #19
Meteorite Man
Passin' The Gas...Station
Meteorite Man's Avatar
Drives: Same As You But Different
Send a message via Yahoo to Meteorite Man
ahhhh.........Kyrdino's, Just before the R/R tracks on 44, haven't been there in a long time.....What would you suggest? I'm pretty hungry and some kind of meat, which just happens to be my favorite vegetable.
Thanks for the hello,
Meteorite Man is offline   Reply With Quote
Old 06-20-2007, 10:45 PM   #20
Edd
Drives: None
Oh I see. No problem, But I'm doing the correct thing on flat surfaces when starting off right? As mentioned above...?
Im scared of premature clutch wear n tear~
Yep, sounds fine. Holding the clutch down WILL wear out the spring-loaded throwout bearing, however, it should outlast the rest of the clutch and is replaced at the same time, so don't worry. Generally, if the stop is more than 10-20 seconds, go into neutral and possible pull the handbrake so you can relax your feet.
vasilios, you will learn to hook it up faster and not have to rev or slip so much. The Yaris may have short gearing on first, so you may have to short-shift anyway (like you are). (Short shifting is upshifting before usual as you don't need the torque that 1st provides and you will save fuel.)
Edd is offline   Reply With Quote
Old 06-21-2007, 02:29 AM   #21
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Oh ok. Because when you said clutch wear n tear.....i tried releasing clutch slowly till the car made movement and then gave it gas, but i suffered a huge jerk leading my head to backlash a bit heh.
So i guess its ok when after its green i slowly release clutch and give it gas at same time but not fully releasing clutch so that the car jumps/jerks.....
To vasilios.....you have to change into 2nd gear really fast I've noticed on this car. At about 10mph or less when you hear the rev reaching its peak for 1st gear, shift to 2nd.....its normal~
Old 06-21-2007, 09:48 PM   #22
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
how fast are you letting it go? If you give gas first and let go of the clutch fast it will jerk/jump. I mean you can have the car not stall and go from first gear but you still get the jackrabbit/jumpy/jerky feeling....I'm tryin to perfect the smoothness from starting off.....pretty damn hard~~
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
