Old 06-25-2007, 01:42 AM   #19
keesue
Chillin' out by the Bay
keesue's Avatar
Originally Posted by kimona54 View Post
If you're not experienced using POLISH, you could damage your paint!
I wouldn't recommend that everyone use clay or polish.
For most of us, light wax is just fine... and it's very safe done by hand.
I respectfully disagree. In point of fact, one would have to work extremely hard to damage the paint by hand. The paint is sealed by a clear coat which is extremely durable. It is however, susceptible to damage from environmental polutants and grit. Rubbing the surface with this grit is like sandpaper to the clear coat. Claying and polish are designed to cleanse and correct these clear coat imperfections and they are not sufficient in and of themselves to damage the paint underneath. One would have to clay without lubricant to introduce marring to the clear coat, and polish is just that - polish. Both of these products are designed to correct issues not introduce them. (A Porter Cable is designed to prevent damage to the clear coat by its random action which reduces the heat build up common with rotary polishers which literally melt through the clear coat and damage the paint underneath). But by hand, one would have to work extremely hard over an extended period of time (days upon days) to get through the clear coat with these products to get at the paint. One would simply tire out as Mr. Brickhardmeat suggested.
Having said that, using clay and polish are steps which safely cleanse the clear coat of imperfections for the last step product - a sealant or wax (or both). A product like scratch-x will address sratches and minor imperfections as well. It is a product which is used where a rotary or PC will not go to remove swirls - and it does just that - remove swirls. NXT and other cleaner waxes work well to 'fill' in minor imperfections as noted in the BMW pictures.
Different problems require different approaches but don't rule out the use of clay and polish as one of them. They are part of a good finish regime and work quite well for the inexperienced of us. Just remember to use lubricant or really soapy water, rub softly with the clay and rub really hard with the polish.
Gettin' all the way down.
Meteorite '07 HB STILL completely stock; but....
checkin' out da other ones to see what's what.
keesue is offline   Reply With Quote
Old 06-25-2007, 01:45 AM   #20
keesue
keesue's Avatar
Originally Posted by forpinks View Post
Time to bust out a PC random orbital polisher some good detailer polish, wax soap, MF cloths and bonnets and sheep skin bonnets and some sealant glaze.
IF bad: Time to bust out a detailer grade super fine sand paper and wet sand!
Yep... or do the same thing by hand if one doesn't have a PC... Superfine sandpaper is a last resort, followed by scratch-x and or a good polish and finished with sealant. #21 and NXT are killer for this. I've had to do it and it works.
Old 06-25-2007, 02:09 AM   #21
Vanderkitten
Vanderkitten's Avatar
Drives: 2007 Yaris Hatchback
And by superfine, it's not 800!! 2000 is more like it! Just so people don't go stripping their paint!
Dave V- Creator-Vanderkitten- Clothing for Women Who Kick Ass!
Many thanks to our sponsors:
Weapon-R http://weapon-r.com
Megan Racing http://www.meganracing.com
Les Schwab Tires http://www.lesschwab.com
317 graphics http://www.317graphics.com
Vanderkitten is offline   Reply With Quote
Old 06-25-2007, 08:59 AM   #22
keesue
keesue's Avatar
Howdy, neighbor. Spent alot of time in Berkeley.
Yep, 2000 it is, and with water (wet sanding), followed by a swirl remover to get rid of the sanding marks. All of this really isn't that hard. It just requires patience and care. Rushing or using the wrong product is the real culprit. Swirls require patience to remove by hand but it is entirely doable.
Regular car wash, or Dealer car wash? Buckethead Wash, Wax, Detailing, Exterior Repairs 49 07-21-2007 12:46 PM
car wash product? Nibs Wash, Wax, Detailing, Exterior Repairs 9 05-18-2007 07:01 PM
Gasoline Car Wash Machine elsteverino889 Wash, Wax, Detailing, Exterior Repairs 1 02-22-2007 02:59 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
About hand wash and other methods.... zyovka Wash, Wax, Detailing, Exterior Repairs 5 09-27-2006 05:10 AM
