Old 07-09-2007, 02:23 PM   #19
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
Originally Posted by brickhardmeat View Post
have you thought about adding camber bolts, someone was talking about doing this and I think it may work since them rubbing is on the outer, I actually think visually neg. camber looks cool, I'm still doing some research
since it's not a track car, the really minor rubbing on the splash guards isn't a problem for me. i've had this type of rubbing, and alot worse, in many different cars so i'm used to it. if i wanted to put her on the track, i'd raise up the height and/or remove the splash guards anyway. i'd have to say no to the camber bolts to try and save as much tire as i can. but they would definitely work for you.
reznunt is offline   Reply With Quote
Old 07-09-2007, 02:26 PM   #20
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
no camber bolts for me either now that I have the basics installed , I'm not concerned with rubbing
SPONSORED BY
Old 07-10-2007, 05:39 PM   #21
ya_RS
ya_RS's Avatar
Drives: 07 RS
Originally Posted by kimona54 View Post
This is the info I have about OEM rim and tire sizes:
OEM 15x5.5, ET45, 185/60/15 or +38
OEM 16x6, ET51, 195/50/16
OEM 17x6.5, ET51, 205/45/17
I also assume that these are in stock height? now will lowering with the TRD springs 30 mm front and 30mm rear effect this?
Honda to Toyota... lets see how this plays out
ya_RS is offline   Reply With Quote
Old 07-10-2007, 06:37 PM   #22
brickhardmeat
Lonesome Cowboy
most aftermarket wheels are going to be 7 inches wide and that changes things a bit even with the same offset, also tire width and profile and how low you go, all things would have to factored in, I think lowering on TRD springs with any offset within reason should be fine up to a 16 inch wheel, you are still going to have quite a gap there
SPONSORED BY
How to determine proper wheel offset? Yaris Revenge Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 05-23-2009 10:41 AM
Yeah, I know... I'm a sellout. ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 53 06-21-2007 12:29 PM
Carbon offsetting with TerraPass BailOut General Yaris / Vitz Discussion 14 05-28-2007 12:29 AM
Offsets? Yarisagos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-12-2007 08:06 AM
Wheel Offsets bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-08-2007 01:55 AM
