Old 07-24-2009, 02:31 AM   #19
BUT3RFLY_YARIS
Drives: Yaris S Sedan
ok cool...
thanx
Gonna live today like it's my last day!!!
BUT3RFLY_YARIS is offline   Reply With Quote
Old 07-24-2009, 03:36 AM   #20
djgab101
djgab101's Avatar
Drives: toyota yaris
mine does the same but from 2nd to 3rd as well!! better go get some grease ...
djgab101 is offline   Reply With Quote
Old 07-26-2009, 02:21 PM   #21
toyota
SRacer
toyota's Avatar
Drives: Toyota Yaris 2007
Send a message via Yahoo to toyota
you know what my clutch squeaks too
whenever i press it down, i think i might to
put some grease on mine too.
anybody recomend any good brands
and how exactly do you put it on?
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop."
- Dominic, Fast & Furious
Learn The Truth about Six Pack Fast!
toyota is offline   Reply With Quote
Old 07-27-2009, 12:29 AM   #22
BUT3RFLY_YARIS
I actually had the same problem with what grease and how to do it.... so i figures since i still had like 10,000 miles b4 my warranty was i up i would use it... i took it to the delear and they put the grease on it.... no more squeaky for me.... lol
Thanx for all ur help though
Old 07-27-2009, 01:23 AM   #23
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Yeah I found the squeak in mine if u look slightly down and to the right of your engine you can see the cables moving and just figure out which one is squeaking. I just use a heavyweight gun oil>.> Redneck I know but it seems to have worked!
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 07-29-2009, 11:43 PM   #24
BUT3RFLY_YARIS
cool... i will keep that in mind next time it happens, hopefully it doesn't, cuz i know for a fact i will be out of my warranty by then....
Old 07-30-2009, 02:43 AM   #25
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
i got the same squeak !! LOL , a yaris factory defect? maybe the cable should have been gaurded ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 07-30-2009, 10:17 PM   #26
toyota
SRacer
toyota's Avatar
seriously right?
but yeah, i will have to definetly
have to check it out!
Old 08-01-2009, 01:31 AM   #27
advocate
Drives: car
This sounds really similar to a problem I'm starting to experience as well. I just broke the 28,000 mile mark on my yaris. I notice there's squeaking in the lower gears 1st to 2nd, 2nd to 3rd, as WELL as in neutral when moving the stick just left and right. Do you guys think this is the same problem? I'd like to have something to tell my mechanic when I take it in other than that the car makes a sqeaky noise when shifting.
Old 08-03-2009, 10:42 PM   #28
H3LlIoN
Drives: '09 Yarrrr hatch
Clutch springs are just squeaking. I just picked up my Yaris literally two days ago. It's got 117 miles on the odometer. Mine started doing it, so I had my roomate look at it. (He's an ASE Certified master mechanic employed as a full time tech at the local Toyota dealership) That's what he came back with. No cause for concern.
H3LlIoN is offline   Reply With Quote
Old 06-25-2010, 10:55 AM   #29
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Squeak at the pedal area or the hydraulic piston area near the transmission? I've never had that problem yet, but on some of my older cars I just used WD-40 for the pedal joints. Not a permanent fix, but does the job for a while.
Old 06-25-2010, 11:05 AM   #30
Lucas13
Drives: 07 Yaris LB
I had the same problem, I removed the little rubber boot by the hydraulic piston of the clutch and sprayed some amount of sea foam deep creep and worked great it’s been about 5 months and the noise hasn’t come back.
Lucas13 is offline   Reply With Quote
Old 06-25-2010, 11:48 AM   #31
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
Hey Lucas,
Would you be able to take a picture of what you're talking about in this post? It would be GREATLY appreciated; I'm sure not just by myself. Thanks in advance!
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
Old 06-25-2010, 11:53 AM   #32
shinlee
shinlee's Avatar
Drives: 07 liftback
yeah, mine sqeaks pretty bad as well
shinlee is offline   Reply With Quote
Old 06-25-2010, 06:36 PM   #33
Lucas13
Drives: 07 Yaris LB
Originally Posted by nick.dollimount View Post
Hey Lucas,
Hey nick.dollimount,
Here is the pic of what I did and took care of the noise, try to use a good lubricant; WD 40 will evaporate too quickly.
Let me know if this worked for you guys, good luck getting rid of the squeak
Old 06-25-2010, 06:58 PM   #34
Tamago
Tamago's Avatar
Drives: UZJ100
Stypical toyota problem, every toyota does it. grease the pivot, you'll be good to go. i like my squeak, it adds classic toyota character to Sammakko
Old 06-25-2010, 07:21 PM   #35
my car has lots of character, too
Old 06-25-2010, 11:56 PM   #36
highwaypass
Captain Slow
Drives: '08 1.5 hatchback
apply some grease to the pedal's joint. Mine works
There's only 1 brand,2 drive,3 words,4 you: TO-YO-TA
highwaypass is offline   Reply With Quote
Manual Yaris performance info? SimmZ General Yaris / Vitz Discussion 22 10-27-2009 09:27 AM
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 07:55 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
The Toyota Authorized Repair Manual. LoudYar General Yaris / Vitz Discussion 3 03-29-2007 12:20 AM
Finally drove the manual! drdavidr4u General Yaris / Vitz Discussion 2 06-14-2006 08:32 PM
