Old 07-26-2007, 01:22 PM   #19
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
how much do they cost? so it wasnt the heat collector above the cat?
Old 07-26-2007, 05:42 PM   #20
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Man if I wasnt working every damn day, id PROVE to you where its coming from. Its not the donut at the collector.. that doesnt even make sence. Its compressed between the end of the header flange, and top of the collector flange.. how would that vibrate. Your dealer is wrong.
Old 07-26-2007, 06:19 PM   #21
whooppee777
if you came to my house and fixed my rattle i'd gladly let you kick me in the nutz
Old 07-26-2007, 06:21 PM   #22
Chris07LB
Chris07LB's Avatar
Running start?
Old 07-26-2007, 06:21 PM   #23
Astroman
Modded Moderator
Astroman's Avatar
Old 07-26-2007, 06:24 PM   #24
whooppee777
Originally Posted by Chris07LB View Post
Running start?
fuck it y not? i dont want kids. i'd rather have my rattle fixed.
Old 07-26-2007, 06:26 PM   #25
Chris07LB
Chris07LB's Avatar
I'd rather a 1/4 keg of Miller Chill.
...Ill even let you drink some.
Old 07-26-2007, 06:29 PM   #26
Astroman
Modded Moderator
Astroman's Avatar
Why not both?
Old 07-26-2007, 06:33 PM   #27
Chris07LB
Chris07LB's Avatar
Because Im not into touching other men's nuts..
Old 07-26-2007, 06:36 PM   #28
whooppee777
alright new plan. you fix my rattle then throw the keg at my nutz and we'll all get wasted then everyones happy.
Old 07-26-2007, 06:43 PM   #29
Astroman
Modded Moderator
Astroman's Avatar
Good point...
Old 07-26-2007, 07:23 PM   #30
Jerkratt
Jerkratt's Avatar
hey man im down lol he had this like doctor thingy with a point on it and was touching pipeing and he called me into the shop....ask rockland toyota.. he was standing right next to me lol
"It hurts more when its wet"
Old 07-26-2007, 07:25 PM   #31
Chris07LB
Chris07LB's Avatar
As long as there was no bending over, or latex glove use.
Old 07-27-2007, 10:52 AM   #32
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
i don't think its that either but it isn't the heat shield cause we checked that ...... what doesn't help is the megan exhaust that isn't too secure or the fact that we can't tell where the noise is coming from. hey jerkratt did the noise start to happen before or after we changed your cat????
Old 07-27-2007, 12:01 PM   #33
whooppee777
this noise really really pisses me off. so if it isn't the heat shield above the cat, and isn't the gasket between the header and the cat then what else could it possibly be? it only rattles when i am in drive, is it the same for anyone else?
Old 07-27-2007, 04:18 PM   #34
Jerkratt
Jerkratt's Avatar
drive... reverse... when i first switch into gear it raddles then it stops for a couple and starts up again whe im idleing going threw drive thru sux lol put it in N everytime lol... if im correct it did it before also..... yes it made the noise before the TSB for the cat was done.. was not as loud tho rockland did u get teh megan axle-back also... u did not notice that it hangs a little low and move around hitting the place where the springs sit? thats why that hanger was there lol i would go over a nice bump and hear it knock lol.. anyway on topic of the header yes noise before and after the TSB.. theres one other place it might be comming from. the stud that holds the header to that bracket type thing....when i was under the car i heard it coming from there.. is that possible?
Old 07-27-2007, 04:19 PM   #35
Jerkratt
Jerkratt's Avatar
going to try and work on it today later weather permiting
Old 07-27-2007, 05:20 PM   #36
whooppee777
cant be that bracket thing because i didnt put the bracket back on when i installed the header and it still makes the noise. i think i am going to wrap my car in packaging bubble wrap. that should fix it.
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
Are We Still Stuck With the 4-1 Headers? Sabretooth Performance Modifications 31 02-20-2009 08:57 PM
Megan Header Advice jamal1984 Cosmetic Modifications (Exterior/Interior) 1 02-20-2007 07:22 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
GROUP BUY - Megan Racing 4-1 Header... riceboy Items for Sale by private party 489 01-10-2007 06:45 PM
