Old 04-18-2010, 11:48 AM   #19
127.0.0.1
well, 'any old' ziptie may crack, rot, break, not do the job, cut into the housing
a Toyota spec ziptie will just plain work.
the difference between walmart zipties and
a good one can be huge
Old 04-18-2010, 01:04 PM   #20
Billiam
Drives: '10 White Yaris 4D LB
I do have some ties that are designed for use in hot conditions and are UV rated. Might as well use one of those.
Old 04-18-2010, 01:17 PM   #21
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
Well I got mine fixed and it doesn't rattle now. I asked the guy what was replaced or what part he needed and apparently there is a bracket that was redesigned to prevent the cable rubbing.
Old 04-18-2010, 08:45 PM   #22
Billiam
Despite being an '10...mine had this issue sometimes. Went out this morning and did the ol' ziptie.....problem solved.
Now I just hope Toyota doesn't void the warranty for using an aftermarket tie.
Old 04-18-2010, 09:54 PM   #23
Palmer812
Drives: 2010 Meteorite Metallic LB
Originally Posted by Billiam View Post
Despite being an '10...mine had this issue sometimes. When out this morning and did the ol' ziptie.....problem solved.
I noticed this noise on mine 2010 LB the other day but didn't think too much about it until I found this thread. I just went out and popped my hood and my cable is just resting against the bracket. I will do the old zip tie fix tomorrow at work myself. I can't help but to wonder what it would take to get my local dealership to fix it under warranty since the TSB only covers up to 2009 models.
Palmer812 is offline   Reply With Quote
Old 04-18-2010, 09:56 PM   #24
Palmer812
If you don't mind cold you pop your hood and see what was actually done to fix it? I am just curious to see if they used some form of zip tie or if they actually replaced a part. The bracket is easily visible from under the hood. thanks.
Old 10-08-2010, 03:33 PM   #25
aaronwer
Drives: 2007 Yaris Sedan
hey everyone I have a 2007 sedan and experience the same problem when in reverse. I'll try the ziptie method and see what happens.
However, there is another rattle i'm experiencing (surprise surprise). When the fan comes on and runs while idleing in park (or at a light while in drive) the vibration causes the hood to rattle against the part of the car it rests against while closed. I verified this by having my wife put the car in drive while holding the brake. When I put my hand on the hood, the noise stops.
I'm guessing this has to do with the fact that there is not much padding along the edges of the hood. Any ideas to absorb the vibration and stop the rattle? a sticky foam piece of some kind?
aaronwer is offline   Reply With Quote
Old 01-10-2011, 06:44 PM   #26
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
aaronwer....try tightening the latch bolts.
Also have the same rattle that most folks are describing....when in reverse at a standstill....will inspect the engine area and see if it IS the same problem...thanks for the heads up yaris world crew!!!!.
frog13 is offline   Reply With Quote
Old 01-16-2011, 05:50 AM   #27
birdman
regular zip works for mine.
Old 12-03-2013, 07:40 PM   #28
Yarisstance
TURBO MUTT
Drives: 2007 Toyota Yaris 4dr Hatch
Here is a picture! HELP
Here I zip tied what i thought was the shift cable i really hope i am wrong as the rattle did not stop! Can any one point out the cable or upload a pcture please
Yarisstance is offline   Reply With Quote
Old 12-03-2013, 07:43 PM   #29
That is the cable. Check the exhaust heat shield as well, as the cable travels along it, and if any of the mounting screws have pulled through the aluminum it will rattle.
Old 01-03-2014, 10:58 PM   #30
jj422
Drives: Toyota Yaris 2009
Rattle be gone.
The information in this thread is awesome.When it gets warmer I will get rid of the rattle.Thanks for the info.
jj422 is offline   Reply With Quote
Old 01-04-2014, 03:47 PM   #31
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
I checked mine and the shift cable was under the wire support and unattached. Close to the exhaust. Is yours like that as well?
I think it makes more sense for the cable to be installed above the bracket, so the support would pull it away from exhaust. I could not move it enough and just zip tied it below the wire support. The access from above the engine was very tight.
Does it look like it's correct now?
jack black is offline   Reply With Quote
Old 01-04-2014, 03:57 PM   #32
Under is correct. The wire support is there to keep the cable from rattling against the underside of the floor. The TSB has you tie it to wire support as is reverse there is enough slack in the cable for it to vibrate against the support and make the rattling sound.
Old 01-04-2014, 04:38 PM   #33
jack black
jack black's Avatar
Thanks! There is still some knocking/rattling sound in reverse especially on cold engine. Maybe from somewhere else?
Old 05-11-2014, 04:26 PM   #34
Silverkarn
Drives: 2008 Toyota Yaris 2D
Anyone have a picture of what this looks like from above? I'd rather try to it without jacking the car up.
Also, if i do have to jack the car up, because its too low to crawl under it, where are safe points to use jack stands?
Silverkarn is offline   Reply With Quote
Old 05-11-2014, 10:42 PM   #35
jack black
jack black's Avatar
Didn't you see my picture above?
Old 05-11-2014, 10:59 PM   #36
Silverkarn
That's the view from the top? I thought that was the view from the bottom.
Anyway, thanks, i'll find this tomorrow in my car.
finally found the 5w-20 TSB... static808 DIY / Maintenance / Service 97 01-02-2013 07:28 AM
Toronto Canada meet June 16th second part of the day photos Ric n Sov's Vitz RS Photo-Video-Media Gallery 23 06-20-2007 02:22 PM
TSB for steering pull? vst DIY / Maintenance / Service 12 06-09-2007 03:40 PM
My New Yaris (First Car), About me, and my TSB Questions dlinkwit27 DIY / Maintenance / Service 1 06-03-2007 01:34 PM
Rattle fixed! Bretsuaz DIY / Maintenance / Service 32 03-30-2007 09:39 PM
