Old 08-10-2007, 12:27 PM   #19
yarispro
Drives: yaris sport 1.3
y como reseteo la compu pues?
yarispro is offline   Reply With Quote
Old 08-10-2007, 12:30 PM   #20
yarispro
ahhh ok ya entendi pana gracias.. disculpa que aya repetido de resetear la compu es que tengo problemas con mi compu..
Old 08-10-2007, 12:43 PM   #21
Fer.pa
Fer.pa's Avatar
Drives: Yaris HB
Send a message via MSN to Fer.pa
creo que se les olvido la parte del S-AFC
eso es lo q me falta carajo!
Super Yaris Panamá
05 HB - 2NZFE 1.3L Engine - 068 Super White - Aem CAI - Trd Oil Cap - Rev 17" rims -Toyo 205/40/17 wheels - Vibrant Front Strut Bar - Tein-S springs - KYB Gas Shocks - Header DC-S 4-1- Tenzo-r steering wheel- Pioneer Avh-P 5750
Fer.pa is offline   Reply With Quote
Old 08-10-2007, 01:23 PM   #22
yarispro
que es S-AFC?????
Old 08-10-2007, 02:13 PM   #23
carlosh
carlosh's Avatar
Drives: Yaris Sedan 2005 Motor 1NZFE
Send a message via MSN to carlosh Send a message via Yahoo to carlosh
Originally Posted by yarispro View Post
que es S-AFC?????
Si , que es S-AFC???
Yaris/echo 1NZFE NCP12
-> TEIN High-TECH spring, Tower bar Generic, HOTCHKIS Sway bar
-> TRD Performance air filter, Stage 1 Gripforce F1 clutch
carlosh is offline   Reply With Quote
Old 08-10-2007, 02:38 PM   #24
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
S-AFC = Super Air Flow Converter
Es un piggyback el cual puedes utilizar para afinar el air-fuel ratio de tu carro modificando la curva del combustible con exactitud y precisión.
Sorry pero no encontre un link en español
AFC Air Flow Converter
How does the AFC Air Flow Converter Work?
The A'PEXi Air Flow Converters work by intercepting the signal between the car's air flow meter and the ECU. The Air Flow Meter is the device that tells the ECU how much air is entering the engine so that the ECU can add the correct amount of fuel.
The ECU calculates the proper ratio of fuel to air for a stock, unmodified engine. Certain engine modifications can cause the dynamics of the engine to require more fuel. In this case, there are two common options for modifying the amout of fuel being input into the engine. One can either install larger injectors or increase the fuel pressure to the stock injectors is increased.
Since the stock ECU thinks that it knows how much fuel it is putting into the engine based on the stock injector size and the stock fuel pressure, changing either of these will result in increased fuel. You may get lucky and just pick the perfect injector or fuel pressure that gives you the perfect air/fuel ratio. You may also get lucky and pick this weekends winning lottery numbers. In either case I wouldn't bet the farm on it. The Air Flow Converter gives you the means to adjust the amount of fuel that the ECU injects into the engine by modifying the signal from the air flow meter. This is done a specific RPM levels. This way you can tell the engine that a certain amount more air is flowing into the engine as a specific RPM than is really entering the engine, and the ECU will add that much more fuel. Decrease it at another RPM level and the ECU will decrease the fuel into the engine.
Estas son unas fotos del aparatito,
la mia es de la primera generacion la cual ya esta descontinuada, la version mas reciente es la Apexi SAFC NEO
It's a Vitz!
Vic-2NZFE is offline   Reply With Quote
Old 08-10-2007, 04:19 PM   #25
carlosh
carlosh's Avatar
ta pretty el aparatito ese saee....
Cuando sea grande quiero tener uno de esos
Old 08-10-2007, 06:01 PM   #26
Kitt
Kitt's Avatar
cha tu si eres yeyeks fren yo toi trabajando en un aparatejo pa pone encima del timon. Este indica los cambios... les adelanto algo del bosquejo...
Old 08-13-2007, 07:55 AM   #27
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
Y como funciona Kitt? haber explicanos...
It's a Vitz!
Old 08-13-2007, 08:22 PM   #28
Kitt
Kitt's Avatar
bueno a ver... el LED se enciende dependiendo del cambio en el q este el carro, inclusive en reversa... Eso esta en la mesa de dibujo todavia, necesito conseguir o fabricar los solenoides para poder terminarlo...
Old 08-14-2007, 01:03 AM   #29
pensadorcritico
pensadorcritico's Avatar
Drives: Yaris Sedan 2006 (echo)
warning AEM/TRD intake
Estoy en busca de un sistema cool air intake y miren lo que encontré que piensan de esto
WARNING about AEM/TRD dealer intake! Please help with advice WARNING about AEM/TRD dealer intake! Please help with advice
pensadorcritico is offline   Reply With Quote
Old 08-14-2007, 10:02 AM   #30
yarispro
epale pana aqui hay un chamo que tiene el sistema aem instalado y por ahora como que le a salido todo bien porque no nos ha dicho nada..
Old 08-14-2007, 11:03 AM   #31
carlosh
carlosh's Avatar
Eso es para si se te olvida en que cambio vas??? como cuando aprendes a manejar?
Old 08-14-2007, 02:14 PM   #32
Kitt
Kitt's Avatar
O SEA man yo se manejar es solo un indicador man...
Old 08-14-2007, 02:28 PM   #33
black Ice
Bullshit!
black Ice's Avatar
Drives: Yaris HB 2004
ese es para q rindas 100km por galon si o q kitt jajajajajaaj
black Ice is offline   Reply With Quote
Old 08-14-2007, 02:39 PM   #34
Kitt
Kitt's Avatar
de hecho deberian ser 200
Old 08-14-2007, 03:19 PM   #35
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
Es es como un shift light bien guetto o que??
It's a Vitz!
Old 08-14-2007, 03:29 PM   #36
Kitt
Kitt's Avatar
no le llamemos ghetto sino home made jejejeje va a quedar bien solida ya la veran
Toyota Yaris S Mod jamal1984 Performance Modifications 10 01-07-2007 02:48 PM
