Old 08-11-2007, 12:21 PM   #19
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
Originally Posted by cm07yaris View Post
Glad to see you put the kaminari badges on! The spacers look great also! I'm running a 205/50 with +42 and I'm thinking about doing 5-10mm in the rear.
I THOUGHT I read that for us the smallest is 10 mm
Old 08-11-2007, 12:22 PM   #20
kimona
kimona's Avatar
Drives: 2014 White VITZ
Hey cm07yaris,
With 16x7's, ET42, and 205/50's, can you tell us how your set-up fits?
It would be a great reference point for those searching for wheels and tires.
Are you flush up front or a bit tucked?
How about the rear?
Old 08-11-2007, 12:23 PM   #21
No... I think he's +38 up front and +28 rear (with the new spacers).
Probably flush up front (but very tight...good he went with the 195's).
Like you, I'm curious where that rear rubber sits now... looks about flush in the photos.
yes on my rim/tire set up, and yes 38 front, 28 rear, and yes it's pretty flush now.
Last night I piled some adults (maybe about 500 lbs total) into the car, and the rear tires rub a TINY bit over extreme dips and such. Acceptable.
Any more spacing in the back would not work. The spacers came with 10mm longer studs -- I would think any spacer set would provide appropriate studs also?
As for the 'six threads is enough' comment, that's probably worthy of a separate discussion.
Old 08-11-2007, 01:38 PM   #22
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
thanks for the update, I wouldn't consider going more than 10mm then
SPONSORED BY
Old 08-11-2007, 06:54 PM   #23
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Originally Posted by kimona54 View Post
Hey cm07yaris,
How about the rear?
I am planning on posting pictures of my setup as soon as I get back from vacation and finish the install. I ran into a few mishaps during the past week or so. I received 3 of my 4 rims last week Thursday and the 4th was somehow separated from the rest. I got the 4th one this past Monday only to open it up and see that it had a slightly bent lip and unfortunately they were the last four rims in that color in the US. Long story short, 5Zigen agreed with my supplier to overnight ship a rim from Japan, I am not at home at the moment so I can't confirm this. I received my Megan Springs on Wednesday and got the the rear setup complete with rims, trd struts and shocks, and the megan springs. As soon as I get home I will install the front suspension and new 5Zigen lug nuts. I am just as anxious to get some pics up for everyone's comments, suggestions, and dislikes! Thanks!
cm07yaris is offline   Reply With Quote
Old 08-11-2007, 06:58 PM   #24
cm07yaris
http://www.ichibausa.com/5mmalwhsp6.html
Old 08-12-2007, 01:05 AM   #25
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
i think i'm gonna need this spacers..just don't kno how thick it would be.
i gotta see caliyaris and show him, maybe he can advice on which size.
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 08-12-2007, 01:22 AM   #26
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
Originally Posted by reznunt View Post
if you overkill with spacers, you might need extended lug nuts depending on your wheels, just fyi. but looks good with the 10mm!
oops, extended lug nuts = extended studs... wrong words as usual.
reznunt is offline   Reply With Quote
Old 08-13-2007, 09:03 AM   #27
smokinyaris
smokinyaris's Avatar
Drives: bad boy
so where can i order these thru or go to......
smokinyaris is offline   Reply With Quote
Old 08-13-2007, 09:29 AM   #28
Ichiba
5mm: http://www.ichibausa.com/5mmalwhsp6.html
H & R:
10mm: www.allsprings.com
Old 08-13-2007, 09:30 AM   #29
seanele, come by anytime!
Old 08-28-2007, 07:35 PM   #30
Terrorize
Toyota Newb!!
Drives: Yaris S Sedan w/ Aero Package!
Hmm...if its pretty much flush with the body kit/fender...will you hit it sometimes going over extreme bumps?? I'm worried about this...since the wheels are currently recessed into the wheel well at the moment...
I'm interested in doing this...i want the 10mm spacers as well..any problems with stock wheel setup? Like everyone else i like the wider stance look...esp. the rear.
Terrorize is offline   Reply With Quote
Old 08-28-2007, 07:42 PM   #31
brickhardmeat
Lonesome Cowboy
what offset wheel size are you running now? yes you might have some rubbing issues
SPONSORED BY
Old 08-28-2007, 11:57 PM   #32
There is this fine line where the rim is flush, but the tire angles inward just a little bit and you have the perfect match up. I've got mine where I only get rubbing under severe bumps and only with more than one person in the car -- I can live with that.
Also, the rubbing is into the plastic wheel well, not with the metal fender.
Old 08-29-2007, 12:43 AM   #33
Terrorize
Toyota Newb!!
Whew...that's good to know!!
I currently have stock wheels..and tires...going to upgrade maybe next summer..i'm doing suspension mods this year...
I like the idea of the spacers...and how they made the car have a wider stance...looks a bit better too
So i shouldn't have problems with stock 15" wheel and tires right?
Old 08-29-2007, 08:30 AM   #34
brickhardmeat
Lonesome Cowboy
again, it depends on how low you go, the offset of the wheels your tire size, all things will have to be considered
SPONSORED BY
Old 08-29-2007, 03:36 PM   #35
Lafiro
Drives: 06 Yaris Sedan
I forgot, anyone have pic of what offsets look like on the yaris? I forgot is the higher offset makes the wheel come out more or is that the other way around with a negative offset? Im confused now!!!
Old 08-29-2007, 03:39 PM   #36
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
the higher the offset, the more the wheels go inward toward the car, the lower the offset (and/or a negative offset), the more the wheels poke out.
Rear VITZ Emblem & Hatch Opener Painted Polar White. [pics] Chris07LB Cosmetic Modifications (Exterior/Interior) 39 05-04-2007 05:20 PM
