#19 |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
I know Ric N Sov has them check his garage, or check out the GTA meet pictures from Jun. I think there are some pics there!
#20 | |
![]() ![]() ![]() Drives: '07 Blazing Blue LB, '09 Jetta Join Date: May 2007
current: '07 Yaris LB - '09 VW Jetta ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi |
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
hahaha, thanks. i think photobucket made my pic pixellated tho.
#22 |
![]() ![]() Drives: 2007 Yaris Hatch Join Date: Jul 2007
Damn I dunno why the Tananbe's look lower then Teins
Kaeon - 2007 Toyota Yaris Hatch |
#23 |
There not on a stock set up!! 1.9 is the max i've seen!
#24 |
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
Cutting coils effects the spring rate....makes it harsher/stiffer for the same amount of travel. Think of your spring as a torsion bar....if you straightened it out and tried to twist it, (usng the same diameter rod) the longer the rod the easier it is to twist, shortening increases the force required to twist to the same degree of movement.
____________ Old School Cobble Jockey
#25 | |
What kind of car is that?
#26 | |
i got the Tein spring(finally..!!), and this time i want to keep it. the Tanabe DF i bought the other day from friend in Jersey, i sent it back..
#27 |
once settled, my DF's dropped a hair over 2" all around.
some people like myself actually measure these things before and after... |
#28 |
Any companies out there plan to make a more dramatic drop? or is this about it?
#29 |
Doubt it. Unless they package a spring/strut combo(matched set) for the front, and a spring/shock for the rear.
With DF's and over 25,000 miles on the stock struts/shocks, I haven't noticed any change yet in the ride, but I know these wont last forever. If looking to go lower then 2", Id just suggest coilovers. |
#30 | |
#31 |
For myself, I dropped my Yaris with 1,3" Apex and it's not as low as I wanted. Next summer, I'll buy TEIN coilover kit. Do not cut anything.
Do it My Way on The High Way
#32 |
![]() ![]() ![]() Drives: 2007 Toyota Yaris HB Join Date: Jul 2007
Has anyone installed Dampers on their Yari yet? I want to drop my Yari but also want the ability to adjust the ride height for daily commute and for highway runs.
Anybody recommend a particular brand? I was thinking of getting TEIN's Dampers. |
#33 |
...Actually, i might be talking about Coilovers instead of Dampers..... but which ever is used to adjust the height. : )
#34 |
Few members here have them..
Megan, Cusco, Tein, etc... Do a search on "coilovers" and you should see quite a bit. |
| New 07 Yaris S need advice on 18's and springs | OgDogg | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 48 | 04-27-2009 09:50 PM |
| Minimal Drop From Springs | blacksan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 05-15-2007 05:46 AM |
| Lowering Springs - Questions ~ AGAIN ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 01-16-2007 12:23 AM |
| FS: Spirit Lowering Springs 1.7" drop | xCookiE | Items for Sale by private party | 2 | 07-24-2006 08:29 PM |
