Old 07-07-2006, 11:36 PM   #19
casterqc
Originally Posted by TRD_Yaris
well, then you shouldn't spend a dime since it actually hurts your Caliper's ability to dissipate heat by painting with Old Fashion Paint.
Well...I say if your car is a daily driver, not a track car, there is no need to put that much money on brakes and calipers. My brother uses "Old Fashion Paint" for his brakes and never had any problem with it. I've decided to go with High Temp Paint just to be sure the paint doesn't melt...it cost me 10$!
I think the the money you spend on a car all depends on how you are using it.
If you're a daily driver and you are looking for something that will maintain your car look good...I say go for High Temp Paint.
If you're looking for performance because you're planning on driving your car harder than how you normaly should...then I say go with powdercoat or even better...high performance brakes.
casterqc is offline   Reply With Quote
Old 07-09-2006, 08:05 PM   #20
Rich Norman
Rich Norman's Avatar
Satin black or cast iron.
The blue Civic with red drums OH YEAH BABY !!!
Originally Posted by casterqc
I have a blazing blue metallic yaris liftback with 16" wheels.
I'm thinking about painting the drums and calipers so it keeps looking good with time ( rust, dirt, etc). The thing is that with the wheels I have you can clearly see the drums and calipers...I want it to have a good clean look!
Wich color would you pick: Blue? Red? or clear? (clear gloss made by vht for brakes and calipers).
I saw a black yaris with red drums and calipers and I think it looks good...but I'm not sure how it would look on a blazing blue one...
need your opinions
Rich Norman is offline   Reply With Quote
Old 07-09-2006, 09:59 PM   #21
weeze-dog
Drives: 2002 Ford Focus ZX3
You could powder coat it yourself. A friend of mine does it using his oven, he does whole wheels too.
Takes a powder coating gun and the powder, then bake it at 400 degrees for X minutes. There are some DIY guides online.
weeze-dog is offline   Reply With Quote
Old 07-09-2006, 11:33 PM   #22
hhcchen
stop staring my star perv
hhcchen's Avatar
Drives: 97 tercel
well...
you can always paint a portion of the drum in the same color as your caliber...
and leave the rest of the drum black...
that way, it can look as if there are caliber at the rear...
hhcchen is offline   Reply With Quote
Old 07-10-2006, 01:44 AM   #23
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Lets all pray he uses this oven ONLY for powdercoating!!
Old 07-10-2006, 02:39 AM   #24
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
it does look pretty good on your drums. After about a year, those drums would've looked pretty nasty. What type of wheels are you gonna rock? open faced rims definitely look better with painted calipers/drums.
oh, and powdercoating also requires "electromagnetizing" the metal so that the powdercoat bonds much better. I have a full write up on Powdercoating if anyone is interested. Cerametallic coating is basically the same but uses a blend of Ceramic and other heat insulating chemicals to "heat treat" certain metal parts like Exhaust manifolds, turbo outlets, etc.
or insulate heat out of stuff like a exhaust manifold heat shield, fuel rails, or intake pipes you want to keep from absorbing engine heat.
There are also heat dissipating powdercoats, which are usually "wrinkle" paints which helps metal dissipate heat off better. This works great for brake calipers, rotor hats, etc.
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 07-10-2006, 04:10 PM   #25
casterqc
here they are...16 inch 10 spokes wheels
[IMG][/IMG]
Old 07-10-2006, 08:59 PM   #26
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
very nice wheels!!
Old 11-15-2006, 12:38 PM   #27
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I got some of this stuff in red to do my calipers: http://g2usa.com/brake_caliper_paint.shtml
Any tips?
Old 11-20-2006, 10:04 AM   #28
Violin
Violin's Avatar
Tada!
lookin for car paint kty75 Cosmetic Modifications (Exterior/Interior) 7 04-26-2011 03:55 PM
Touch Up Paint? Chris07LB Wash, Wax, Detailing, Exterior Repairs 6 08-31-2006 02:37 PM
