Old 08-17-2007, 08:47 PM   #19
Nabisco
Nabisco's Avatar
Drives: '08 Honda Fit Sport
Send a message via ICQ to Nabisco Send a message via AIM to Nabisco
I mean this in the kindest way.
http://en.wikipedia.org/wiki/Obsessi...lsive_disorder
He that would live in peace and at ease must not speak all he knows or all he sees....
Nabisco is offline   Reply With Quote
Old 08-17-2007, 09:21 PM   #20
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
Originally Posted by Pavel Olavich View Post
I don't think you have to drop the tank....just take the back seat out and then it's very easy access. Since the tank doesn't have to be dropped, this maintenence is fairly easy to do.
yes there should be an access panel underneah the rear seat cushion. this is where the fuel pump and level unit is located. not really a big deal to change but if you dont seal it back up prerfectly you will have evap codes to deal with. just make sure you have less than half a tank if your going to do it. besides, i wouldnt worry too much about it unless you have some noticeable fuel pressure or hesitation problems.
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 08-18-2007, 02:20 AM   #21
caveatipse
Drives: 2007 Black Yaris
But how can a fuel filter never need changing, when by nature, a filter accumulates particles? Unless the fuel filter is there for no reason, it will eventually need changing, no? All filters do!
caveatipse is offline   Reply With Quote
Old 08-18-2007, 06:25 PM   #22
Christopher
Cobra
Drives: '07 3-door
Are you guys sure about this? I have never seen a car without of filter inline between the tank and the engine that will need changed. Sure all cars have a sock filter in the tank also. Chris
Christopher is offline   Reply With Quote
Old 08-18-2007, 10:09 PM   #23
drifto
drifto's Avatar
yes it should be changed at the recommended service interval. usually i would change mine at its first tune-up or major service, maybe around the 20-30k mark. but like i said its not something to lose sleep over if you havent done it yet.
07 Yaris LB 5spd
Old 07-09-2012, 06:56 PM   #24
PodRed
Drives: Red 2008 Yaris S 3dr liftback
I did a search and found this old thread that applies to my question.
I have just 16,000 miles on my 2008 Yaris, that I bought in Oct 2007.
It's due for an oil change and the _fuel filter_ came to mind. The reason is my commute changed dramatically last year, I now drive very long distances in the country with no gas stations until I reach my destination.
As a result I have to drive until my fuel light comes on and the last bar is blinking. Prior to the last twelve months I never let fuel level get below 1/3 of a tank remaining.
I would welcome comments to give me some peace of mind, as well as your thoughts in regards to changing it or leaving it be.
The car runs exceptionally well and has had frequent oil changes, air filter changes, etc, based on time, not mileage.
Thanks in advance. :)
PodRed is offline   Reply With Quote
Old 07-10-2012, 07:21 PM   #25
Lux
Lux's Avatar
Drives: NCP91
All Toyota automobiles use lifetime fuel filters. That means, by design, it will outlast your car. However, filter media become clogged prematurely from contamination through the filler, either by dirty refueling equipment or simply dirty fuel (like from a jerry can that has been sitting in your garage).
You should not change the filter unless you or a technician have diagnosed unequivocally that the fuel pump is suffering from poor output. However, that is no reason to ignore regular fuel system services... and I'm not referring to that snake oil garbage you pour into your fuel tank. A genuine fuel service involves either feeding a pressurised fuel-detergent mixture directly into the fuel rail and running the car from it without the fuel pump, or removing every injector for a reconditioning.
Old 07-10-2012, 07:50 PM   #26
PodRed
Thanks for the excellent advice. Very informative.
Cheers :)
Old 12-28-2012, 07:32 PM   #27
jamielm
Drives: 2003 Yaris VVTI
Hi there,
Apologies for bringing up an old thread, but I thought that it would be better than creating another thread. I have a 2003 Yaris (only recently purchased), and unfortunately ran out of fuel. I was on my way to the Petrol Station after purchasing the car, and prematurely broke down.
Since then I have been having some issues when trying to start up the car (on some occasions it can fire up almost instantaneously, on other occasions it can take up to 10-15 cranks).
I know that I am probably jumping the gun, but I believe that after reading this thread, this could be the reason why this intermittent problem keeps occurring. Is there any way of replacing the in-tank Fuel Filter? If so does anyone have any advice on how to do it/a roundabout quote for parts/labour?
Or could it perhaps be just cleaned, and no need for a replacement to be put in? My car is a Yaris Colour Coll. Vvti 5 Door Hatchback (1299cc, 2003). After reading I am a little confused, no-where online seems to sell Fuel Filters for my model. Do they come as part of the Fuel Pump/Fuel Gauge Sender Unit, or art they actually in built in the Tank? As I said, I'm still a little fuzzy. Thanks in advance for any information.
I hope this is OK with people, sorry again to jump onboard this thread.
Kind regards,
Jamie.
jamielm is offline   Reply With Quote
Old 12-28-2012, 09:45 PM   #28
Originally Posted by jamielm View Post
Hi there,
Kind regards,
Jamie.
Take a look at this thread: http://www.yarisworld.com/forums/showthread.php?t=42906
The fuel filter is located within the sender assembly and can be replaced. Based on your thread where you describe the issue, I would agree that you should check the fuel filter.
low gas mileage? yrsdrgn General Yaris / Vitz Discussion 30 01-17-2019 03:26 AM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
damaging or no--cabin air filter roxy84 DIY / Maintenance / Service 3 06-29-2007 01:17 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 10:49 AM
fuel filter ias205 General Yaris / Vitz Discussion 15 05-14-2007 11:02 AM
