Old 09-13-2007, 01:16 PM   #19
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
YUP! well, I'll be buying another pedal assembly to try this out on unless anyone can confirm otherwise, because i am pretty sure this will work on any other dbw models because it is the same standard...
http://www.mustangforums.com/m_37925..._1/key_/tm.htm
If anyone is in the process of being down there or taking theirs apart would be cool to check this out... ill actually make another post when im done doing this mod as well...
Old 09-13-2007, 06:09 PM   #20
KSIbucky
KSIbucky's Avatar
new engine
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
Old 09-13-2007, 06:10 PM   #21
KSIbucky
KSIbucky's Avatar
no dont try this you really could mess up your car
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 09-14-2007, 10:56 PM   #22
Wow good find there, I don't know how similar our pedal assembly is, but it should be similar...
Old 09-15-2007, 01:15 AM   #23
Nexus1155
Drives: Audi
i thought it should be similar but sadly its a thing of magnetics and electronics -_-
Old 09-15-2007, 12:50 PM   #24
i think it's really simple... there ARE quite a few oem ECU made for the 1nz-fe with a wired throttle body.
Old 09-15-2007, 01:28 PM   #25
Nexus1155
Drives: Audi
didn't know that many cars came with the 1nz-fe, but i confirmed that the echo throttle body and assmebly will work....but what about the ecu?
edit: damn
Applications:
Toyota Yaris/Echo
Scion xA/ist
Scion xB
Toyota Vios
Toyota Raum
Toyota Porte
Toyota Platz
Toyota Auris
Toyota Fun Cargo
Toyota Premio
Toyota Allion
Toyota Sienta
Toyota WiLL
Toyota Probox
Toyota Ractis
Toyota Corolla Axio
Toyota Corolla Fielder
Old 09-17-2007, 07:01 PM   #26
i'm taking a guess you can use the ecu from a scion xA??
BUT.. i'm pretty sure you will have to redo the whole wiring harness anyways...
Old 09-17-2007, 07:02 PM   #27
Nexus1155
Drives: Audi
I don't think so... I think they use different coding as like ones 32 bit and one isnt in some maps... but I'll have to check it out... see if they have one at a junkyard... I'm aiming to find an Echo and grab the pedal assmebly and throttle body with cable from there. that would probably be the easiest car to find there...
edit*
Different intake setup, different exhaust and routing...
Different ECU 32 bit vs Scion's 64 bit...
Different transmission C50 vs Scion's C150...
Tree 1 - Yaris 0 gabagooo General Yaris / Vitz Discussion 19 04-25-2007 05:24 PM
