Old 10-19-2008, 07:31 PM   #19
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
funny hearing all the THEY SUCK talk. maybe if installer had used proper hardware this would never had happened....
Old 10-19-2008, 07:33 PM   #20
ChinoCharles
Drives: LB
Does the Weapon install guide call for using those springs? Did they even send one?
Come to think of it I don't think I've got mine on... hmmmmm.
Old 10-19-2008, 07:38 PM   #21
ROCKLAND TOYOTA
TRIM HUNTER
^^ KOU and i had this discussion this afternoon. it needs the springs...........
Old 10-19-2008, 07:38 PM   #22
ChinoCharles
Drives: LB
I have to change my oil tomorrow anyway. Dammit, I was so ready to be done with the big ratchet...
Old 10-19-2008, 07:41 PM   #23
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Like all the previous have said, this probably would not have happened if it was properly installed.
Old 10-19-2008, 07:42 PM   #24
ROCKLAND TOYOTA
TRIM HUNTER
Originally Posted by Malaya1221 View Post
with this particular setup, i don't get the spring issue...maybe someone could enlighten me...
what so different about this setup????
Old 10-19-2008, 07:44 PM   #25
ChinoCharles
Drives: LB
Without the springs, it isn't like the play between the header and center pipe is gone. It is still there, just without the constant push outward. I'm kind of confused myself to be honest.
Old 10-19-2008, 08:00 PM   #26
Thej3sta2
Thej3sta2's Avatar
Drives: Soon to be LFA
I just want to here how the damn thing sounds like that Loud As F___ im guessing
Thej3sta2 is offline   Reply With Quote
Old 10-19-2008, 09:14 PM   #27
kou
Drives: 08 lb
the springs are to hold the pipe against the header so when the motor move's it is not trying to pick up and put down the entire exhaust system,there is movement in every direction with the springs. without springs the torquing back and forth will fatigue the metal and crack.dont blame the manufacture for your own mistakes. i have been using this for over a year and it still looks as good as the day i got it.
Old 10-19-2008, 09:23 PM   #28
ROCKLAND TOYOTA
TRIM HUNTER
over a year and been on 2 yari........
Old 10-19-2008, 09:55 PM   #29
ChinoCharles
Drives: LB
Thanks for the clarification kou.
Old 10-19-2008, 10:02 PM   #30
kou
Drives: 08 lb
your welcome, just want to make sure that everyone knows that this can happen to any header overtime without the springs,toyota put them there for a reason.
Old 10-19-2008, 10:23 PM   #31
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
got it and i'm glad that yours is still in good condition!
it looks like u r an expert on this, so is it fair to ask that when fabricating a header back exhaust or turbo exhaust, the weld will not hold because of the vibrations, movements and weight of the entire exhaust system unless a spring bolt is used to bolt them on?
Old 10-19-2008, 10:23 PM   #32
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Another reason to buy a torque damper for the engine.
eco is offline   Reply With Quote
Old 10-19-2008, 10:34 PM   #33
kou
Drives: 08 lb
header back exhaust should always have some kind of flex joint so that the is some play.turbo is another story as alot of the manifolds are shorter and cast pieces with extra support brackets for the weight of the turbo and down pipe but after that there should be a flex joint.
Old 10-20-2008, 04:53 PM   #34
Malaya1221
Malaya1221's Avatar
thanks kou.
Old 10-20-2008, 05:00 PM   #35
Malaya1221
Malaya1221's Avatar
have the nitto mid-pipe with the weapon r and while installing it using the oem bolt spring, the screw was all the way to the end of the treads but it still had a gap(fit was not snug) so comes the air leak!
Old 10-20-2008, 05:33 PM   #36
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
Are We Still Stuck With the 4-1 Headers? Sabretooth Performance Modifications 31 02-20-2009 08:57 PM
DC sports header installed. largeorangefont Performance Modifications 41 09-20-2007 09:14 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
Who got that weapon header? Galavoxx Performance Modifications 1 12-04-2006 09:11 PM
