Old 11-09-2008, 04:30 AM   #19
metalshark
MetalShark
Drives: 2008 Yaris LB
Both yours and the Dynomax 1777 actually fit better up into the stock heat shield better than the USDM pumkin muffler. After 15,000 miles my Dynomax is getting a little louder.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 11-11-2008, 10:36 AM   #20
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Yea, my muffler sits right up in the channel near the framerail. Everything back there is covered in heatshield, like the car was made for this size muffler.
Old 11-11-2008, 10:59 AM   #21
33lam
Drives: The C-One Yaris
Send a message via MSN to 33lam
great sound! Love it!!
33lam is offline   Reply With Quote
Old 11-11-2008, 12:43 PM   #22
TheSilkySmooth
TheSilkySmooth's Avatar
very nice vvrroom. I want a boy to put a turbo can on MY 3 dr. Yaris for me. + I like the gray wheels. I want to have a nice muff too like everybody
-sonja
Old 11-12-2008, 02:17 AM   #23
DerKaiZeRs
-YaRiS OwNeR-
DerKaiZeRs's Avatar
Drives: YRS Sedan
nice.....
DerKaiZeRs is offline   Reply With Quote
Old 11-12-2008, 10:05 AM   #24
Thej3sta2
Thej3sta2's Avatar
Drives: Soon to be LFA
lieky
Thej3sta2 is offline   Reply With Quote
Old 09-23-2009, 03:49 PM   #25
GnomeBody
AD&D Dork
GnomeBody's Avatar
Drives: 07Liftback/07sedanS
Do you know how many CFM this muffler flows? I cant seem to find any info on it.
Mods: K&N filter, Megan Coilovers, Ultra Racing 19mm rear sway bar, Sun tachometer, Window Tint.
GnomeBody is offline   Reply With Quote
Old 10-03-2009, 08:26 AM   #26
posaunemeister
Drives: 2008 Yaris S LB - MM
Here's a pic of my axleback: 2 1/4" Dynomax Super Turbo Muffler (I was too impatient to wait for a 2" DSTM, so I purchased one from a local Advance Auto Parts store for $50. It's not the lighter, single-wall $20+ dollar version. I hacked off the muffler with a reciprocating saw (w/ a metal blade) and drove it to the muffler shop where the tech welded on a pipe configuration that would allow such a large muffler to fit under my car. And then I took it off and painted the entire axleback with a high heat, high gloss black paint. I love the end result.
posaunemeister is offline   Reply With Quote
Old 10-03-2009, 01:44 PM   #27
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Several Yarii around Dallas have removed the pumpkin muffler and simply run a straight pipe from the axle-back coupling to the exhaust tip. Sounds really good, and doesn't seem to affect performance negatively. Obviously, its a weight reduction, and it appears that the pumpkin is mainly a noise-reducer, so not sure if it would have any emissions effect (I doubt it.)
A dyno run needs to be done to determine if it helps/hurts performance, but that would be very simple to do a with/without pair of runs.
In Texas, the car would probably pass inspection if it passes the tailpipe sniff test, unless the tech decides to look for the muffler and knows that its missing. Even then, it would probably pass, but that's the only problem I can see, legal-wise.
Anyone have more experience with this?
Old 10-03-2009, 03:26 PM   #28
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Actually in Texas if a vehical is newer than 1996 when they started using OBD2 in cars they don't use a sniffer. Also if you remove your muffler in Texas you should fail an inspection if the inspector looks at your exhaust
Old 10-03-2009, 04:38 PM   #29
ozmdd
ozmdd's Avatar
Lil red, it must be different out in FW. Here in Dallas Co., we have the tailpipe sniffers no mater what the year. We're one of the EPA smog counties, so it a little more stringent. We have the lame California-type low-emissions gas too. Cleaner, but less HP (teeny-weeny bit, albeit.)
Also, LRR, you would still have a muffler and 2 cats in the midpipe section, so I'll bet a really clean weld job would get by a lot of inspectors. If they ask, just say "the muffler is right there in the middle! " :)
Your idea of either keeping a stock muffler set-up in the garage for inspections or clamping/welding a hollowed-out muffler body around the straight pipe is the best idea.
Old 10-03-2009, 04:43 PM   #30
lilredrocket
Slowy getting there
Drives: 08 Liftback
I'm not saying you are wrong but I am a certified state inspector and I have done inspections in both Denton and Tarrent counties and never used a tailpipe sniffer for inspections unless the vehical was older than 1996 or the OBD2 link was not reading.
Old 04-28-2010, 12:56 AM   #31
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
So if I move to Austin my supercharged Yaris would still be illegal?
5% Tint Rear | Micro Image LED Ignition Light Kit
Old 04-28-2010, 09:10 PM   #32
lilredrocket
Slowy getting there
Drives: 08 Liftback
Shouldn't be... I'm not 100% sure they have emissions testing there. It's not a state wide deal it is more county-city level. But there is a safty inspection across the state. There are 2 members that are boosted in TX not sure if either one has had to get an inspection yet
Old 12-12-2010, 12:06 AM   #33
darkMINI
Drives: 08 hatch
I used the little $25 Dynomax muffler and installed a Harley baffle to tone it down nicely. The baffle also adds a little back-pressure that may be lost in the high-flow muffler. Not sure if it matters much in that respect.
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
darkMINI is offline   Reply With Quote
Old 12-04-2012, 12:04 PM   #34
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Just installed this very muffler along with some 2" resonator-back piping, and I have to say that I love the sound and performance so far.
Old 07-03-2014, 01:59 PM   #35
robbadobba82
Drives: 2007 Toyota Yaris Hatch
So to get this on with clamps (Don't have access to a welder). I would just need a 2-2.5 adapter+clamps?
robbadobba82 is offline   Reply With Quote
