Old 01-30-2012, 04:21 PM   #19
Originally Posted by clarkemode View Post
Has anyone successfully added heated side mirrors to their Yaris? If so, can you share your experience?
I haven't seen any postings of someone actually doing the install, but I replaced my side view mirror glass with ones that had LED arrows that shine through when the turn signals are on. For all intensive purposes it is the same process to install and wire them (with the exception of the end point being a couple of terminals over on the connector in the under dash fuse panel).
The most difficult part of the process of adding mirror heaters would be not breaking the glass. When I pulled the mirror glass off of the plastic backing to swap mine over, I broke one of the mirrors. Fortunately my LED ones included new glass, so it was not an issue, but if you were going to install heaters on the back of the existing glass, you would need to be very careful.
Old 01-30-2012, 04:29 PM   #20
Originally Posted by CrankyOldMan View Post
I also found them with lots of different suffixes (i.e. A0, J1, D2, etc). Does anyone have a guess what the color codes are?
Here are the color codes and descriptions from the EPC:
D0 - Super Red, 3P0
A0 - White, 068
F2 - Yellow, 5A6
C0 - Black, 209
J2 - Blazing Blue, 8T0
D2 - Dark Red, 3Q8
J3 - Grayish Blue, 8T1
B1 - Medium Silver, 1F8
A1 - White Pearl, 070
B0 - Silver, 1E7
B8 - Gray, 1G3
Old 01-30-2012, 09:38 PM   #21
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Excellent! Thank you.
Old 02-14-2012, 06:08 AM   #22
dobbiedoo
Dobbiedoo
dobbiedoo's Avatar
Drives: 2009 5 door Hb Yaris
Thumbs up Heated Mirrors
I have installed heated mirrors and they work quite well. I purchased heaters and extra mirror glass in case there was any glass breakage, there was. The cost for the parts were about $20 for each glass and about the same for the heaters, I wired mine in parallel the current draw is under 2 amps I did not use the defroster,I got a lighted switch rated at 6 amps. The company name is Burco glass, just google. The 2009 has 2 wires on each door that you can use but you still have to run wires to the fuse panel. BTW the heaters are not big enough to cover the whole glass. When removing the glass use a 2 inch paint scraper to pry the glass out of the holder it is held in place with some sort of sticky putty, someone recommended using butter knives, I dont think thery are wide enough. There is a lot of rambling hope you can make some sense. Good luck
dobbiedoo is offline   Reply With Quote
Old 02-14-2012, 08:24 AM   #23
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Would any Scions have heated mirrors? If so, can't we use those?
Old 02-19-2012, 05:27 PM   #24
09sedan
Drives: 2009 yaris sedan
my 2009 sedan (Canadian market) was built in november 2008 ( dealer told me, which also means i have no more bumper to bumper warranty ) would it have heated mirrors or no? would it also have the rear abs problem?
09sedan is offline   Reply With Quote
Old 02-19-2012, 05:37 PM   #25
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
All rear abs assemblies are the same, so it MAY have this problem. It's not difficult to go back there with some grease and coat the connector to eliminate the issue.
Old 02-19-2012, 05:48 PM   #26
09sedan
wasnt the design changed in the 08 and up models? (sorry for going off topic)
Old 01-26-2016, 05:23 AM   #27
bairjo
Here is how I did it on my 2010.
https://www.youtube.com/watch?v=5pkbGxqhYZI
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 02:40 AM
adjusting the side mirrors??? brpnagger General Yaris / Vitz Discussion 4 07-02-2007 03:07 AM
Side curtain airbags not available? arothman New YARIS Purchase Forum 18 06-15-2007 03:46 PM
blue side mirrors yrsdrgn Photo-Video-Media Gallery 15 04-12-2007 11:03 AM
side mirrors got615 Cosmetic Modifications (Exterior/Interior) 0 05-09-2006 01:28 PM
