Old 06-12-2010, 02:47 AM   #19
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up T-SB-0068-09 February 19, 2009 Transverse Engine Mount - Abnormal Noise and Vibration
Many many thanks to CTScott for getting these!!!
T-AC001-07(HVAC Odor )
T-AC003-07(Blower Motor Noise & Vibration )
T-BO002-07(Windshield Wiper-Washer Performance Improvement )
T-BO011-06(Parking Brake Lever Dust Boot )
T-EG010-07(M.I.L. ON DTC P0011, P0012, or P0016 )
T-EG032-07(Accessory Drive Belt Noise (Revised) )
T-EG035-06(Excessive Sulfur Odor (Revised) )
T-EG040-07(M.I.L. ON DTC P0335 Only )
T-EG048-07(M.I.L. ON DTC P043E, P043F, P2401, P2402, & P2419)
T-EL001-07(IG1 Relay Freezing )
T-EL002-07(Charging System Warning Light ON )
TS-AU001-06(Audio Quick Reference Guide (Revised) )
T-SB-0026-08 (Trunk Lid Full Open Position Improvement)
T-SB-0027-08 (HVAC Evaporator Drain Blockage)
T-SB-0038-08(Cylinder Head Cover Baffle Precautions)
T-SB-0053-08 (Alignment Pin Installation during Transmission Transaxle)
T-SB-0065-08 (Blower Motor Noise &Vibration)
T-SB-0067-08 (Noise from Auxiliary Port with External Device)
T-SB-0120-08 (ABS M.I.L. ON DTC C0210 or C0215)
T-SB-0138-08 (Permanent-Type Protective Wax Coatings)
T-SB-0142-08 (Upper - Lower Windshield Tick Noise)
T-SB-0197-08 (Tire Pressure Warning System Activation )
T-SB-0200-08 (Automatic Transmission Serial Number Locations)
T-SB-0201-08 (MY Yaris Pre-Delivery Service)
T-SB-0260-08 (Remanufactured Automatic Transmission Serial Number)
T-SB-0288-08 (Front Seat Squeak Noise)
T-SB-0301-08 (Engine Serial Number Location)
T-SB-0302-08 (Special Service Tools)
T-SB-0304-08 (Upper Instrument Panel Rattle)
TS-BO017-03(Trim Garnish Loose (Revised) )
TS-EG018-06 (ILSAC GF-4 Engine Oil Recommendation)
TS-EL003-07(Supplemental Restraint )
TS-EL009-07(Programming OEM Wireless Door Lock Remote Transmitters )
TS-EL010-07(WIRELESS TRANSMITTER & Programming Guide
TS-PA001-07(Refinishing Replacement Bumper Covers )
TS-SS002-07(TECHSTREAM ECU FLASH REPROGRAMMING PROCEDURE)
TS-ST005-01 (VEHICLE PULLING TO ONE SIDE)
TS-SU007-06(Shock Absorber Replacement )
TS-TC003-07(Driveshaft Assembly Replacement )
TS-TC010-07 (World Standard Automatic Transmission Fluid )
TS-TR-0061-W (2008 VIN Decoding)
TS-TR-0062-W (2009 VIN Decoding)
single-zip file download coming soon...
Etimago,
pls do add this important TSB on the list:
on Acceleration
T-SB-0068-09 Transverse Engine Mount - Abnormal Noise and Vibration on Acceleration
--du2efs
ricepower is offline   Reply With Quote
Old 06-24-2010, 01:36 PM   #20
rslyk
Drives: 2007 YARIS 3 DR HATCHBACK
No and if you talk to Toyota "HELL" no.....I was amazed at how many of the
things on this list I had a problem with and didn't know it....The only solution
is a picket sign INFRONT of a Toyota dealership saying "I AM A DISSATISFIED
TOYOTA OWNER" Toyota has had a loss of confidence by the American consumer
and thier answer is to ADVERTISE that they are a company of integrity. The
right of a consumer to picket a dealer is paramount....that dealer, if he is
smart will not let a dissatisfied consumer stay dissatisfied. A dealer can not buy
advertising that will over come a picket. From first hand experience.....don't ask
me how I know...that is my opinion, every one has one.
rslyk is offline   Reply With Quote
Old 06-28-2010, 06:23 AM   #21
fujiwaru
fujiwaru's Avatar
Drives: 08 Toyota Yaris Sedan
thanks for posting this!!! really helpful!!
- Arvin
fujiwaru is offline   Reply With Quote
Old 08-03-2010, 01:50 AM   #22
birdman
Hackers wanted for Yaris w/o curtain air bags crash tests would be more like it.
Old 08-21-2010, 12:38 PM   #23
yarrr
Drives: 07 sedan
PAGES NOT FOUND! GASP
Old 01-23-2011, 06:26 PM   #24
zuberio
Joined 3/08 ... really
zuberio's Avatar
Drives: '07 Sedan
My AC does the odor thing, my gps has noise on the AUX in, and the trunk has hit my head several times.
Aaaaand I'm out of warranty. This sucks.
zuberio is offline   Reply With Quote
Old 02-24-2011, 07:08 PM   #25
Yo Yo Yaris
Yo Yo Yaris's Avatar
Drives: Sleek, black, stylish yaris
wow...a treasure chest full of goodies!
Who Else Wants CHEAPER Motor Insurance?
Compare quotes across reputable motor insurance companies
in Singapore at Motor Insurance Singapore
Yo Yo Yaris is offline   Reply With Quote
Old 03-05-2011, 07:27 PM   #26
Brianr4
Drives: 2008 Yaris 3dr Hatchback
Does anybody know of a home fix for the a/c stink?
I am just out of warranty, but do have the extended warranty and Toyota certified used warranty.
Brianr4 is offline   Reply With Quote
Old 03-05-2011, 09:43 PM   #27
You can start with checking the condensate drain hose to see if it is blocked. It is located under the front left corner of the passenger carpet. If you are lucky the stink is just due to it being plugged. If it is not plugged and the stink is due to the metal incompatibility issue of the TSB, then the only full resolution will be to replace the evaporator.
Since you have the extended warranty, I would see if you can get it checked out under that.
Old 04-28-2011, 03:56 AM   #28
bB2NER
My Box and Her Egg
bB2NER's Avatar
Drives: 05' Scion xB / 08' Yaris 3dr
If they don't fix it under warranty you can try this. This stuff works wonders for removing the funk and smell.
http://www.autogeek.net/1z-einszett-...freshener.html
bB2NER is offline   Reply With Quote
Old 07-25-2011, 09:07 AM   #29
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
CLUNK NOISE FROM FRONT SUSPENSION TSB-0055-11
Some 2007-2011 model year Yaris vehicles may exhibit a noise from the area that is heard under acceleration/deceleration, when braking, or when driving over an uneven surface. NEW FRONT LOWER SUSPENSION ARMS, CROSSMEMBER ,and NO.2 FRONT LOWER SUSPENSION ARM BOLTS(2).......
This repair is in effect for 36 MONTHS OR 36,000 MILES......
ROCKLANDTOYOTA is offline   Reply With Quote
Old 09-01-2011, 03:49 AM   #30
RogueYaris
Drives: 2015 Abs Red
I have an extended warranty.
Does it cover the stuff that says "36 MONTHS OR 36,000 MILES"?
Also, I only get fuzz when my mp3 player is plugged into the aux and powered at the same time. I remember seeing something about it but can't remember if it's under a TSB or not.
RogueYaris is offline   Reply With Quote
Old 09-01-2011, 12:59 PM   #31
Hershey
We also have the clunking noise from the front of the '08 Yaris sedan . Seems to be from the passenger side . Notice it when pulling out of an uneven surface such as parking lots ( higher slope ) onto a lower road . This has been going on for over a year . Tried to get a service to look at it awhile ago before the TSB for the U.S. and service manager said NO! This is a TSB for CANADA , so not needed . Feel like calling that service manager back and tell him there's a TSB for here now .
Old 09-01-2011, 01:02 PM   #32
Hershey
As for under the extended warranty . Very likely it's covered . Here's the online brochure that shows all parts covered . It's under suspension . http://www.toyotafinancial.com/consu...S_Platinum.pdf . This is the PLATINUM plan , go here for other warranty plans , http://www.toyotafinancial.com/consu...ProtectionPlan and click on VIEW BROCHURE . We plan on taking the '08 in soon for inspection . Still clunks on occasion .
Old 09-01-2011, 02:09 PM   #33
Hershey
How many hours would it take for replacement of both arms if needed ?
Old 09-01-2011, 02:55 PM   #34
Hershey
The TSB instead of a RECALL is a way for TOYOTA to save money and preserve the confidence of current and potential buyers . The '07s > '09s are very likely to be beyond the 3 year / 36,000 mile warranty and that puts the financial burden on those owners . Shame on you TOYOTA !
Old 09-01-2011, 03:37 PM   #35
RogueYaris
Companies don't generally do recalls unless it's a life threatening defect.
Old 09-01-2011, 03:42 PM   #36
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
Rockland- do you have a copy of tsb 0055-11? It would be nice to see if it applies to my vehicle.
NZ-FE Vios is offline   Reply With Quote
New Yaris look? carnage08 Australia 7 10-19-2008 01:06 PM
