Old 10-18-2020, 07:02 PM   #1
kimona
kimona's Avatar
Drives: 2014 White VITZ
ET40 would be a better fitment with 205 rubber.
Old 10-27-2020, 12:23 PM   #2
06032
Drives: 2008 Hatchback
I see folks using Mini Cooper wheels. The 16"s I like have an offset +46-48. Is this in the realm of possibility and with what size tire for a flush look, with and without a TRD spring?
Another option I've found is a Sparco 16" wheel (from a Miata) with a 195/55/16 tire. Will it fit with or without the TRD springs?
06032 is offline   Reply With Quote
Old 10-27-2020, 04:13 PM   #3
kimona
kimona's Avatar
^^^ 16" Mini wheels are generally 16x6.5, ET48. They will work very well with 205/50/16 rubber on stock suspension or with the modest TRD drop.
Old 10-27-2020, 09:27 PM   #4
06032
Thanks, Kimona!
As to the second question, many can be found with the 195/55 rubber. Will it work for the time being?
Old 02-02-2021, 10:59 PM   #5
06032
Anyone know if Mini 16" wheels (ET48) with 205/50 tires and TRD springs/shocks can still accept H&R 10mm spacers in the rear and not rub? I'd like to push them out a tad for aesthetics and it 'appears' there's room.
With this setup, the fronts do rub just a bit at full turn. Any solution for this?
Old 02-07-2021, 05:24 PM   #6
spoonzz
Drives: 5D YR 2012 Auto
Hey all, I ended up finding super cheap stock 15x5.5" alloy wheels from the ZR model (i'm in Australia) which I painted black. Also I'm not sure what they ZR models are called in other places but basically the top model.
Now I'm not sure what tyre size to get. Someone suggested 185/55/15. Stock for these wheels are 175/65 but I'm not sure what to get. I just don't want anything to make the car feel sluggish.
Any suggestions?
spoonzz is offline   Reply With Quote
Old 02-07-2021, 07:57 PM   #7
kimona
kimona's Avatar
^^^ In the US, OEM is 185/60/15.
Old 02-09-2021, 05:04 AM   #8
spoonzz
Thanks, I may as well go with that then.
Old 02-11-2021, 11:17 PM   #9
Financial Mistake
Drives: 2006 YRX 5D HB
Hey guys
Does this offset guide apply to all model hatch back NCP10 to NCP130?
Looking at 15x7 TE37sl in staggered offsets
+34 front & +24 rear
Last edited by Financial Mistake; 02-11-2021 at 11:27 PM. Reason: Left off wheel sizing
Financial Mistake is offline   Reply With Quote
Old 03-24-2021, 10:14 AM   #10
Rashdawg
Drives: 2010 Toyota Yaris 5Door
I am just getting into autocross and getting close to replacing my old tires with something slightly better but still an All Season tire for now. Wish there were more options in All Season 15s. Right now looking at Kumho Ecsta PA31 195/55/15.
I think 195 should be the max width I could run on stock rims? Anyone run 195/55/15s on the stock 15X5.5 rims?
Rashdawg is offline   Reply With Quote
Old 03-24-2021, 11:33 AM   #11
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I ran 195s and 205s on the stock rims (alloys) without issue, though I didn't drive really hard in corners and such. No issues, but I suspect the 195s would be better than the 205s for autocross. I bet the 185s would be even better than the 195s.
Old 03-24-2021, 08:36 PM   #12
myfirstyota
3 Yaris and counting..
I run 205/50/15 on stock alloy rims and tein stech springs. Other than the tire guys complaining they were hard to get the beads seated, all is good
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 04-23-2021, 07:59 AM   #13
Hotwad
Drives: 2012 3 Door 5 speed Yaris L
Max width on 15’s before needing to modify?
Hey all, I intend on doing some autocross in my 2012 Yaris. Next big purchase is rims/tires. What is the max width I can get away with on a set of 15’s before I have to start modifying to avoid rubbing?
Hotwad is offline   Reply With Quote
Old 05-23-2021, 04:13 AM   #14
OzDriver
Drives: Forester XT
Hi all
New member from Australia looking to purchase a 3dr hatch as a daily driver. Will be keen to apply a few basic handling/suspension mods. I'll want to lower it modestly, perhaps an inch or so. I've trawled the wheel threads for some great inspiration.
Looking at:
ROTA GRID 16x7 +40
ROTA SLIPSTREAM 16x7 +38
With modest (1-2") lowering and sensible/standard diameter rubber would I run into rubbing issues with either of these? I note the +40 would be closer to OE offset. Any advice much appreciated!
OzDriver is offline   Reply With Quote
Old 05-23-2021, 06:02 AM   #15
stidnam
Drives: Starlet
Assuming you'll be using a 205 tyre. You shouldn't rub with either a +38 or +40
stidnam is offline   Reply With Quote
Old 05-23-2021, 06:09 AM   #16
OzDriver
Drives: Forester XT
Yup - looks like 205/45 would be the ideal on a 16x7
Old 05-23-2021, 06:33 AM   #17
stidnam
Drives: Starlet
At that size, 60kph would be showing as 58.3 on the speedo.
205/50 would read 60.3 on the speedo when doing 60kph.
Old 05-23-2021, 06:44 AM   #18
OzDriver
Drives: Forester XT
Interesting thanks - that is better. I'd seen 205/45 mentioned often.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
