#379 |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
It seems that my car cannot make up its mind what it wants to do. Some days .. the ABS/Emerg light is on and other days it doesn't show its face. I will just ignore it I guess .. and see how that works out.
#380 |
It'll just get worse and worse. The fix is so easy, why ignore it?
#381 |
I am not a car guy. I know how to check my oil .. and that's about it. So .. fixing it will be something that I may get the dealer to do. But the dang lights won't stay on, so the dealer won't touch it.
#382 |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
from the sounds of it your sensor is at the point where there is some corrosion but the pins are still intact and no serious damage has been done. it may get to the point where the only thing possible to do is to replace which is much more $$$
#383 |
![]() ![]() Drives: 2007 Yaris Sedan Join Date: Oct 2008
^^^ I agree with this.
edmscan, you really should take a look at it while you still have time to protect the connection before it's completely corroded apart. All you have to do is clean the salt spray and sand off the connector, and then seal it back up with dielectric grease. It takes no more than 10 minutes and will save you all kinds of headaches. The dealer will charge you for an hour's labour, so that'll be $90-110 for a very simple task. Take a look at this pic for what the sensor looks like: http://www.yarisworld.com/forums/sho...&postcount=232 |
#384 |
thought they didnt use salt out there?
#385 |
![]() Drives: Orange Yaris Hatchback Join Date: Feb 2012
The ABS and brake light appeared today not impressed. I retrieved the code and it was 33 for right rear sensor. Pulled the rear wheels off to get better access. Took a while to get the electrical connector off the back of the sensor. I ended up using a medium cotter key split in half. I put it in the lower part of the connector and turned while pulling on the connector towards the center of the car. Blew my mind when I got it off this plug has no rubber seal of weather proofing at all WTF... I dried them both out with a hair dryer and filled them with vasoline. Drove it down the street and BOOM!! it's fixed. When it's not -14 out I will rig up some boots to cover the connectors. They should at lease supply us with some rubber boots that can be slipped over these connectors to prevent the moisture.
#386 |
I have great news .... the local Toyota dealer is going to fix my ABS (!) brake problem, under extended warranty. The extended warranty coverage for my car was purchased by the original owner, and it apparently does cover the ABS (!) issue. So I am looking forward to getting my car finally fixed.
Edit: .. got my ABS (!) issue fixed today at the Toyota dealer. It was good to finally get the problem resolved. The best thing is that it was all covered under ECP warranty. Last edited by edmscan; 02-14-2013 at 08:01 PM. |
#387 |
![]() Drives: 2006 Yaris Join Date: Oct 2009
I have an 06 and just had to clean the sensors for the 2nd time last night. But the bad news is on the passenger side the plug fell completely apart. So I need to replace the ABS sensor wire (part 89516-52090) and the speed sensor (part 89544-52040).
Two questions; does anyone know a site that will ship to Canada and has the parts for a good price. The dealer cost is freaking crazy and more than double what i have found from sites in the US which won't send items north of the border. Second question, does anyone have DIY for changing the speed sensor? |
#388 |
![]() you will need a press...at least that's how i removed my hub. i can maybe send it to you for 100$ shipped from US. Last edited by enviri; 03-02-2013 at 09:23 PM. |
#389 |
All I know is that when the dealer fixed my speed sensor issue (both left and right sides) it took them about 2-3 hours to complete the job. So it doesn't sound like it is a simple 10 min job.
#390 |
![]() Drives: Yaris Hatchback LE Join Date: Jul 2007
owner of 2007 LB yaris, had rust proofing done when it was bought new from DVN dealership.
I just got this stupid ABS & (!) lights on problem about few weeks ago, after some googling i found this thread. I have a service appointment booked and will talk to them to see if they will do a good will pricing for me, if not, i'm not planning to fix it. |
#391 | |
Hi,
Can you tell us which dealership is this in Toronto? DVN wants total of $940 to rplace both rear sensors, they said the cost of both sensors is $240......... Quote:
#392 |
Drives: 2008 Yaris Join Date: Jul 2013
ABA wiring sensor replaced
First off let me thank everyone for posting such good information on checking, preventing and replacing in all of the above posts!
![]() I've followed the instructions and have removed both sensors, the first was dirty, but intact, the second....not so lucky. So I managed to switch out the old, broken, wiring and sensor (I'll call the male end) but I'm a bit lost on the other side (female) end. I had a few pins that were broken off (tons of sand/salt/snow in Winnipeg) and I'm not sure what part or process to use to replace the "female" side? I wasn't able to find anything mentioned in the previous posts on a DIY...any advice? I've been taking photos as I've gone along and I hope to post them all once I've completely finished to help others. I'll admit I'm not very handy, but I'd rather not pay the dealership for a job that I can do myself! |
#393 |
jb48
Drives: 2008 hatchback automatic Join Date: Oct 2013
Now I have a dilemna!
I bought a used (97000 km) 2008 Yaris HB a month ago and it`s my sole everyday vehicle (my other one is a 1984 Suzuki 650 motorcycle). So far so good, no problem at all. In addition to everyday transportation, I use my car for delivering mail to mailboxes in rural area. I read all the 22 pages of this thread and now i have a dilemna: do I take preventive actions to address the potential problem by asking my mechanic to clean and grease the ABS connections when he`ll install my new winter tires or is it better to do nothing per popular proverb <if it ain`t broke, don`t fix it>? |
#394 |
Take it apart and grease it with dielectric grease before it's too late.
#395 |
![]() Drives: 2007 Yaris Join Date: Sep 2011
I've had the ABS & "!" light coming on intermittently since Christmas, and then it went solid for most of the winter so I suspected corrosion. Scan revealed C0210 (right rear speed sensor circuit).
Yesterday it was finally warm and dry enough to take a wheel off and have a look. Turns out that one of the two pin sockets on the harness was crusted up with green corrosion. And I can see why it happened, the plastic housing of the connector had a crack in it that let water in. Being as I'm a tightwad, I scraped out as much of the crust as possible with a small sewing pin and flushed out the debris with alcohol spray and compressed air. Added a tiny spot of grease in the hole and plugged it in. Cleared the codes by jumping the DLC and the warning lights are now off. I know this is a temporary repair, so the next time the light comes on I'm going to just replace both rear harnesses. |
#396 |
![]() ![]() Drives: Hatch Join Date: May 2009
Can somebody help with a question? I'm trying to do the rears. Does that clip on top actually get removed, or is it a molded part of the connector? I lift the clip with a screwdriver, then try to pry to connector back with another screwdriver and the connector doesn't want to slide off easily. The connector is somewhat loose because I can actually slide it back and forth a tad. However, there is significant resistance to sliding the connector off. Am I just being too timid about prying on the connector to pop it off? I just don't want to break it. Thanks,.
