Old 07-02-2012, 05:41 PM   #1
joe keeney
Drives: yaris 2 door hatch
I got a 2009 camry also never a problem. Never took it back for B/S recall. Better a bad Toyota than a good Ford or Chevy what ever that crap fait makes.
joe keeney is offline   Reply With Quote
Old 10-10-2012, 04:53 AM   #2
YarTrek
Aygo Crazy
YarTrek's Avatar
Drives: '08 Blazing Blue LB MT
The window switch recall is in. 7.43 million vehicles including the Yaris.
YarTrek is offline   Reply With Quote
Old 10-10-2012, 10:41 AM   #3
STC
"LibertyRides!"
STC's Avatar
Why I purchase manual cars with manual windows
Cheers!
~ Mark ~
Old 10-10-2012, 08:15 AM   #4
NEexpat
Drives: 2009, auto, 4dr LB
^ Here is a link to the story.
NEexpat is offline   Reply With Quote
Old 10-10-2012, 08:59 AM   #5
auxmike
auxmike's Avatar
They will just rub on some high temp grease . That will probably just attract dust and screw up the switch over time. I'll pass, thanks!
Old 10-10-2012, 08:59 AM   #6
auxmike
auxmike's Avatar
PS now I have to hear people in work tell me 50x there's a recall on my car....
Old 10-10-2012, 09:20 AM   #7
david_827
Drives: 07 Yaris Sedan
you and me both its getting annoying.....
david_827 is offline   Reply With Quote
Old 10-10-2012, 02:24 PM   #8
403RS
#yyc
403RS's Avatar
Drives: BSP '07 RS 5dr LB
This.
ugh. haha.
403RS is offline   Reply With Quote
Old 10-10-2012, 09:28 AM   #9
auxmike
auxmike's Avatar
Then there's that one jerk "I thought they were reliable, they sure have a lot of recalls"...
Old 10-10-2012, 09:29 AM   #10
NEexpat
Here is some more information from the Toyota USA Newsroom
The MSNBC story posted above mentions,
That, in fact, is now the case, with the NHTSA targeting an additional 800,000 vehicles, including some Yaris subcompacts from the 2007 to 2009 model years, as well as the entire 2008 Highlander Hybrid SUV run.
And the story I linked from Toyota just mentions 07's and 08's. But the NHTSA includes 09's.
So who knows, I'll wait and see if I get something in the mail.
Old 10-10-2012, 10:11 AM   #11
auxmike
auxmike's Avatar
Fluorine grease, hmm... Wonder where we can get some .
Old 10-10-2012, 10:18 AM   #12
Fluorine or Fluorinated grease is pretty common in the aerospace industry. It is typically used between Titanium or super high precision parts. Bicycle shops sell Finish Line Extreme Fluoro grease in little tubes for about $15 to $20.
Old 10-10-2012, 03:11 PM   #13
kou
Drives: 08 lb
I wish this came out 2 weeks ago when mine started smoking and i had to replace it.
Old 07-05-2013, 10:21 AM   #14
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
New recall July 2013
I haven't seen no posts on this so I'll put it in the right spot.
http://pressroom.toyota.com/releases...aris+july2.htm
http://www.toyota.com/owners/web/pag...ources/recalls
http://www.reuters.com/article/2013/...0F91AT20130703
http://www.cnbc.com/id/100862449
Killchain is offline   Reply With Quote
Old 10-11-2012, 06:19 AM   #15
GianniVRS
Drives: JDM Vitz RS 2008
Does this (Window switch problem) concern the JDM version VITZ or just the EU / USA markets?
GianniVRS is offline   Reply With Quote
Old 10-11-2012, 08:22 AM   #16
ciscobear
Drives: Toyota Belta
Recall of six models Vitz and Belta Notification number 3036
, October 11 start date recall
For the vehicle part of the six models Vitz and Belta, I reported to the Ministry of Land, Infrastructure and Transport following the recall of content on 10 October 2012.
Illustration where improvement
One. Status of the problem
Some of the power window switch on the driver's door, grease for lubrication of the switch is not uniformly applied, that the lubricity is deteriorated grease is carbonized by (spark) arc generated in the contact portion at the time of switch operation have. Therefore, there is a possibility that the sliding switch is deteriorated, and the contact malfunction worn early.
Further, when applied to a commercial lubricant like trying to improve the sliding switch failure may cause the switch to melting.
2. The contents of improvement
And replace it with a switch board coated with a heat-resisting grease, about what to check all vehicles, the power window switches, malfunction is confirmed, but otherwise, grease the heat resistance at the contact.
Also, about what the inspection above, was applied to the heat-resistant grease, Then, if malfunction occurs, we replace the power window switch.
http://toyota.jp/recall/2012/1010_4.html
Check the page to see if your car is affected.
ciscobear is offline   Reply With Quote
Old 12-08-2012, 01:28 PM   #17
charles nelson
Drives: red Liftback
My dealer said that I would be receiving a recall letter in about two weeks. It has now been over six weeks. Has Toyota decided not to inform owners about the recall?
Update...of course, I just received the recall letter...6 weeks after my dealer informed me about it.
charles nelson is offline   Reply With Quote
Old 04-20-2013, 05:49 PM   #18
yarisitis
yarisitis's Avatar
Drives: 2008 Yaris LB
For those who have had their Yaris' fixed for the power window switch recall, what were your experiences? Did you only take your car in when you noticed the window exhibiting the "notchy/sticky" operation or did you take it in regardless of that? I'm assuming they have to remove the door side panel to get to the internal window parts? Did the service people do a good job, did they mess anything up or break anything in the process?
I want to take my car in for this recall but I'm a little hesitant as to if it's really necessary and also I'm scared they might end up messing something up in the process.
yarisitis is offline   Reply With Quote
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Toyota Temporarily Suspends Sales of Selected Vehicles redglare45 Off-topic / Other Cars / Everything else Discussions 0 01-26-2010 06:33 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
Toyota recalls vehicles over faulty engine Lizardboy General Yaris / Vitz Discussion 1 07-18-2006 07:07 PM
