Old 10-29-2010, 05:53 PM   #379
AEM
Sold at MI too!
Old 10-29-2010, 10:52 PM   #380
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Yes Garm, I mentioned you! My guru. lol. Bring those zage kits in! Let's do this
Old 10-30-2010, 01:00 AM   #381
haha "Guru", I just learned from other people, I think we all do.
Focus, no one ever asked a question about boost controllers before.
"the truth is out there" -- if you know how to Google.
Old 10-30-2010, 08:40 PM   #382
Focus_Sh1ft
Focus_Sh1ft's Avatar
I have a bit of a conundrum...
My car is stuck in open loop all of the sudden. I have no idea why it is, but now I can't boost because it goes LEAN. Anyone have any ideas why it suddenly decided to stay in open loop? My thought is it has something to do with driving cycles and the ECU seeing boost, as this is the longest I've driven without pulling terminals off the battery. I'm sure I could probably do just that and it would reset, but this is certainly a curious case. No CELs either, and my turbo timer is getting feedback from the AFR sensor still.
Old 10-31-2010, 12:28 PM   #383
Focus_Sh1ft
Ok this situation is baffling, but incredibly awesome. My car is still doing the same thing. I pulled the AFR plug just to make sure the ECU throws a CEL, and it does. So... Something is happening that's forcing the car into open loop without any CELs! This is an optimal situation, and I wish I could figure out why it's happening for future reference. I have no idea where to even begin looking though.
I'm going to just tune the car instead of resetting the battery. If it swaps back to closed loop at some point - no biggie.
EDIT: As soon as I plugged my FIC back in and started the car, the issue resolved itself. I'm still clueless as to what I just witnessed, but I would love to find out. There must have been some criteria the engine failed to meet to throw itself into closed loop. The catch would seem that whatever it is doesn't cause a code though...
Oh and also - I was reading the service manual and noticed the AFR sensor heater operates between .9 and 10 Amps. A code is thrown if the current drops below .8A. Could it be possible to greatly limit the current that reaches the heater? My thought is that maybe, just maybe, we could limit its performance enough to prevent the AFR sensor from functioning correctly, thus putting the car in open loop.
Old 11-02-2010, 07:08 PM   #384
Focus_Sh1ft
I'm assuming no one understands what the hell I've been talking about lol.
Anyways, there must be something wrong with my AFR sensor. Started the car up today, and it did the open loop thing. It started open, warmed up, went closed, then around 115F water temp it opened again.
Pulled my FIC bypass plug, put it back in, problem solved. Drove to class and got P2238 when I was almost there. The car went open loop, I cleared the code, and back to closed. On the way home, no code but it just suddenly got stuck in open loop again. The whole thing is so strange, but I can't be bothered with crap like this.
I've pulled my AFR sensor plug and am going to tune the car in open loop. I should have done this awhile ago, instead of messing around with the FIC. This is tried and true, and a CEL that doesn't cause limp isn't the end of the world.
Old 11-02-2010, 08:57 PM   #385
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Sounds very similar to my problems. My car stayed in closed loop but my factory O2 sensor was going wacky. While driving it was OK but when hot at idle it was very slow to respond. Sometimes it would go so lean it would dye out. I think the location of the o2 had something to do with it. Mabe if it was located before the turbo it would be OK. I have removed the o2 sensor and tuned in open loop. Much better now. Still need some bigger squirters though.
Old 11-03-2010, 07:57 PM   #386
Focus_Sh1ft
WOW I should have tuned the car like this sooner. It's soooo easy. Not to mention it does in fact feel like it drives better.
Honestly, I think this is the way most people should consider using. Besides having a constant CEL, the only other very slight downfall is a SMALL loss in fuel economy. If you tune the car around 14.7 out of boost, and richer during boost, the loss will be minimal though.
Also - just got my cheapo manual boost controller today (Joe P, ball and spring type). Since I'm tuning I feel a little more comfortable using it, so I'll install it tomorrow. Should be interesting to see what happens with spooling once I get it set to the right psi.
Will post up my tune once I'm thoroughly satisfied with it. Should be very helpful for all future Zage users, but only if you're tuning the car in open loop.
Old 11-04-2010, 12:28 AM   #387
^ Excellent! I got five more Zage kits in today.
Old 11-04-2010, 06:37 AM   #388
Freedan
Drives: 2010 Yaris Bayou Blue 3DR Lift
Freedan is offline   Reply With Quote
Old 11-04-2010, 12:20 PM   #389
Focus_Sh1ft
So anyone remember how I said the Zage BOV has a sweet, unique sound? No, I was wrong. I have BOV flutter lol... But it sounds soo cool
Currently looking into it... Having flutter means the BOV is set too soft I think?
Old 11-04-2010, 02:08 PM   #390
^ so it isn't closing tight enough, right?
Old 11-04-2010, 10:23 PM   #391
PETERPOOP
PETERPOOP's Avatar
I read somewhere that its the air recirculating and pushing the turbo blades backwards. someone was saying that it isn't THAT bad on a small amount of boost?
Old 11-07-2010, 10:12 PM   #392
pimp my yaris
C'est la vie
I think peterpoop is right. The flutter sound is compressor surge [air going back through turbo blades]. IE: the bov may be a little tight. Mine was set to loose and my engine kept dying out because it was leaking out to much metered air and I went way rich. I tightened up the spring and now I get some flutter before I get the air rush sound when it opens. But now it almost never dyes out. I dont think a little flutter will hurt as long as when your on the gas hard you hear it open when you let off. Its hard to imagine the whole automatic trans. situation.
Old 11-12-2010, 12:07 PM   #393
Focus_Sh1ft
I've been playing around with my manual boost controller the last few days and haven't seen any noticeable improvement in spooling unfortunately, but I'll keep at it.
Was wondering about this though.... If my PCV hose has a kink in it, that would cause blow-by and oil in the intake, right? I'm thinking that's the reason I found oil in the intercooler. Looks like it could also be related to my P0101 code.
Old 11-12-2010, 12:18 PM   #394
cdydjded
Drives: Yaris LB Turbo
A manual boost controller does not improve & was never intended to improve spooling. A MBC is to raise boost period. As for the oil in the I/C, the only way to get oil there is from the outlet of the turbo. You need to thoroughly clean you entire system to pin point exactly where it is coming from. After you clean the system & you find oil again in the I/C, then the problem lies within the turbo itself. I know you have the Zage kit but dont you if you used there pan. If you did, like I said many times before, it doesnt work. If you didnt then there could be problem with either the oil feed you have (too much psi) or the oil return (not flowing enough)....
cdydjded is offline   Reply With Quote
Old 11-12-2010, 12:27 PM   #395
cdydjded
Decided to go through the entire post to see if you used the pan, based on what I found on page 7 you did. The pan is the issue, you cant have the oil from the turbo flow back into the engine below the oil level line, it has to be above the oil level line. Your problem of oil in the I/C lies there. Pimp has a similar problem of a small amount of smoke during start up. His return is also below the oil line. Once you guys put the return higher you problem will disappear....
Old 11-12-2010, 12:32 PM   #396
cdydjded
Oil return
Left pic incorrect way, pic on right correct way
FS: Autometer Cobalt 6170 Boost Gauge Nexus1155 Items for Sale by private party 2 02-02-2011 04:08 PM
Multiple cylinder misfire under boost LtNoogie Forced Induction Forum 13 11-02-2009 04:44 AM
Fill up with Super before starting your boost project LtNoogie Forced Induction Forum 5 12-01-2008 06:41 PM
Supercharger Selection and Limiting Boost Nexus1155 Forced Induction Forum 1 12-01-2008 03:51 PM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 02:42 PM
