Old 11-10-2018, 09:49 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by tmontague View Post
Yup keep the resonator for sure, it's a well flowing 2 5' open pipe iirc and it does a lot to remove the rasp
I have a question for ya.
Before I found the Megan axleback- and was going to use that other muffler I got - I had talked to an exhaust shop. They said that I should remove the flanges at the muffler and end of the midpipe and have on continuous pipe, bent over the axle. I don't really like the idea of hacking the end off the Megan and welding directly to it. What would you do in this case? If the Megan is designed to attach to stock Yaris exhaust, it must be a smaller diameter, wouldn't it. Would this small area of smaller diameter cause a restriction in flow?
Old 11-11-2018, 12:47 AM   #2
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
My exhaust shop did this as well. Cut the flange off and did a solid 2.25” from the resonator. I haven’t had to remove it so I cant comment of serviceability once it’s all solid
Old 11-11-2018, 09:00 AM   #3
06YarisRS
Yeah, the exhaust shop said that it just eliminates another point where leaking can happen, which definitely makes sense to me. This shop only uses aluminized pipe and does not mandrel bend, but this Yaris will never see the salty roads of winter. I also think that 2.25" will give good flow even though it's crush bending.
I bet it would make removing the pipe a little more difficult, or even impossible if it's welded, but it can always be cut again and rewelded if need be.
Old 11-11-2018, 11:11 AM   #4
The exhaust shop i went to also welded everything solid. Personally I'm not a fan. The gaskets with spring bolts add a section where it can flex under stress. This is one of the reasons my muffler weld snapped after 3 years when I was at the track.
I also like to be able to remove the exhaust in pieces if I need to service anything. I hate not being able to do thatvwithba solid one piece exhaust.
Old 11-11-2018, 11:26 AM   #5
06YarisRS
Good points for sure. I'm going to think about this a bit more before I move on it.
Old 11-11-2018, 11:31 AM   #6
^ all of this.
I am currently welded solid as a repair was done which unbeknownst to me involved cutting out the flange. I hate the solid setup. I had been in the habit of swapping in my Tanabe Medalion for the summers, but no longer can. Now it just hangs useless in my basement.
Your hands just become tied once welded in.
Sent from my EML-L09 using Tapatalk
Old 11-11-2018, 11:56 AM   #7
06YarisRS
Exhaust Straight Talk...
Well, looking for opinions.
Here is my current setup:
Eastern Catalytics Midpipe which is large diameter until the resonator, then narrows down. This currently attached to the OEM Yaris, very restrictive, muffler. Question to you all: If I just bolt the Megan racing to the Eastern Catalytic midpipe, will it provide good enough flow. If I am only going to gain an almost imperceptible amount of power, does it really make sense to replace from the resonator back with large diameter pipe? I mean if I'm not going to feel a difference, is it really worth it. Maybe it would make a big difference. I also don't want cause the engine problems - in the long term - with too much backpressure. I suppose I could do this and then down the road, upsize that section of pipe.
Thought and opinions appreciated.
Old 11-11-2018, 02:04 PM   #8
ArmstrongRacing
Data doesn't lie
I honestly wouldn’t mess with it yet. You’re still using a stock exhaust manifold so that pipe diameter reduction after the resonator likely isn’t your biggest issue.
I’d say just bolt it all up and drive it for a while. Try to sell off your 1nz parts and recoup some money, then revisit this in the future.
Old 11-11-2018, 02:48 PM   #9
06YarisRS
Excellent advice that I will follow, for sure. Thanks!
Old 11-11-2018, 02:50 PM   #10
Fully agree, it wont make a large difference and since you tend to like to keep the rpm's down this will keep the torque in that range.
As Tom said, revisit it down the road if need be
Old 11-11-2018, 02:55 PM   #11
06YarisRS
Yes, I was thinking that too. I suppose the true benefit of a freer flowing system comes into play when the engine is outputting at higher RPM. Thanks.
Old 11-11-2018, 03:08 PM   #12
DarkShadowFox
Can you make one for the 2015 liftback because i am poverty :D ?
Old 11-11-2018, 11:14 PM   #13
06YarisRS
Exhaust Pipe Sizing
Thought I'd do a little reading about proper sizing for exhaust. For now I am just going to leave the 1.75" midpipe (from the resonator to muffler flange) and bolt up the Megan axleback. However, at some point down the road, I'll likely do an upgrade on that section of the midpipe.
Here is a table for reference. I am not sure how accurate this is, but it talks about flow through a "straight" section of pipe. According to the table (based upon a HP output of ~130), I should use a 2" pipe. I think The Barber said he had great success with a 2" resonator to muffler flange upgrade. Considering that I have the 1.8L engine and there are bends, turns etc in the pipe, I would upsize to 2.25", which jives completely with what everyone here is saying.
Link: http://www.exhaustvideos.com/faq/how...pipe-diameter/
Old 11-13-2018, 07:31 PM   #14
ArmstrongRacing
Data doesn't lie
I had this wild idea that we should all take similar photos with our cars for TS group photo I can edit together. We just need to decide on a pose
Old 11-13-2018, 07:51 PM   #15
06YarisRS
100% behind this!!! Would be awesome.
As an aside, the badges have been processed through Heathrow.
EDIT: After watching your videos, Tom, I think one - complete with tunes - is in order for the TS group. Maybe we should send you clips too!
Old 11-14-2018, 01:45 AM   #16
ArmstrongRacing
Data doesn't lie
That would be even better! Clips of each person with their car, maybe saying your name and location, then some driving/racing footage, wrenching footage, washing footage....then I could put it all together and make it my channel trailer
Old 11-14-2018, 10:42 AM   #17
TSportblack
Drives: Toyota Yaris TS
Hi.
I read your Thread and I,m speakless about your work of the 2ZR-FE swap!!! Congratulation!!!!
Greez from Germany
Pj
TSportblack is offline   Reply With Quote
Old 11-14-2018, 11:40 AM   #18
06YarisRS
Originally Posted by TSportblack View Post
Hi.
Greez from Germany
Pj
Thanks! It was a very fun, yet sometimes challenging, project. I could not have done it without the help of the other guys on the site, but you already know that since you read the thread.
I saw pictures of your car in your other post. I love everything about it! Please send me your front and rear bumper covers. I MUST have them!
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
