Old 04-13-2007, 10:10 AM   #1
Black Yaris
der Zeck
Black Yaris's Avatar
Official YARIS Wheel & Tire Guide
WHEEL BOLT PATTERN PCD = 4 x 100mm
CENTRE BORE = 54.1mm
OEM wheel sizes, offsets (ET), and tyre sizes (diameter in inches):
14x5, ET45, 175/65/14 = 23.0
15x5.5, ET45, 185/60/15 = 23.7
16x6, ET51, 195/50/16 = 23.7
17x6.5, ET51, 205/45/17 = 24.3
TRD Option 18x7.5, ET42, 215/35/18 = 23.9
With stock suspension, you may safely fit many tyres from 23.0 to 24.3, +/-3%.
__________________________________________________ _______
Recommended offsets (ET) and tyre widths (mm):
ET35+ = 175-185
ET38-ET40 = 175-195
ET42-ET45 = 195-205
ET45+ = up to 215
Here is an excellent and easy to use wheel and tyre fitment guide:
http://www.rimsntires.com/specs.jsp
Optional tyre sizes (diameter in inches):
*Commonly recommended replacement sizes
Fitment depends on wheel width, offset, and suspension mods.
175/65/14 = 23.0*
185/65/14 = 23.5*
195/65/14 = 24.0
195/60/14 = 23.2*
205/60/14 = 23.7*
215/60/14 = 24.2
175/65/15 = 24.0
185/60/15 = 23.7*
195/60/15 = 24.2*
195/55/15 = 23.4*
205/55/15 = 23.9*
195/50/15 = 22.7
205/50/15 = 23.1* (Most lowered applications)
215/50/15 = 23.5
225/50/15 = 23.9
195/50/16 = 23.7*
205/50/16 = 24.1*
215/50/16 = 24.5
195/55/16 = 24.4
205/45/16 = 23.2* (Most lowered applications)
225/45/16 = 23.9
205/45/17 = 24.3*
205/40/17 = 23.5* (Most lowered applications)
215/40/17 = 23.8
215/35/18 = 23.9*
225/35/18 = 24.2
205/40/18 = 24.4
Staggered fitments:
1. Staggered offsets are common in Japan. These applications even out fitment front to rear and are purely for appearance. Tyre size generally remains constant front to rear. Staggered offsets preclude tyre rotation. Recommended maximum stagger is 10mm.
Example: FR, ET45//RR, ET38
Example: FR, ET42//RR, ET35
2. Staggered tyre widths are less common, especially on front wheel drive cars. These applications even out front to rear fitment. They are not recommended for the track, but as an appearance option they are safe under normal driving conditions. Staggered tyre widths preclude tyre rotation.
Example: FR 205/55/15//RR 225/50/15
Example: FR 205/50/16//RR 215/50/16
Example: FR 205/40/17//RR 215/40/17
3. Wheels spacers are another option to even out fitment front to rear. Maximum recommended rear spacer width is 10mm. Tyre rotation is still possible.
Example: FR, ET42//RR, ET42 with 5-10mm spacer
Old 04-13-2007, 10:18 AM   #2
Awesome! Now we have a place to refer people for those daily questions
Old 04-13-2007, 10:38 AM   #3
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Here's a cut & paste from an Excel spreadsheet I made up a while ago to help determine various tire sizes. Both models' sizes are included (as there is a 3.41% difference in diameter from the base to the RS model!). This doesn't take into account the ratio between wheel widths and tire widths.
Base Model with 175/65/14:
HTML Code:
	Width	Aspect	Wheel	Diameter	Circumference	Difference
	(mm)	(%)	(in)	(mm)	(in)	(mm)	(in)	(mm)	(in)	(%)
Orig.	175	65	14	583.10	22.957	1831.86	72.121	--	--	--
+1	185	55	15	584.50	23.012	1836.26	72.294	4.4	0.17	0.24%
	185	60	15	603.00	23.740	1894.38	74.582	62.5	2.46	3.41%
	195	55	15	595.50	23.445	1870.82	73.654	39.0	1.53	2.13%
	195	50	15	576.00	22.677	1809.56	71.242	-22.3	-0.88	-1.22%
	205	50	15	586.00	23.071	1840.97	72.479	9.1	0.36	0.50%
+2	195	45	16	581.90	22.909	1828.09	71.972	-3.8	-0.15	-0.21%
	195	50	16	601.40	23.677	1889.35	74.384	57.5	2.26	3.14%
	205	45	16	590.90	23.264	1856.37	73.085	24.5	0.96	1.34%
	205	40	16	570.40	22.457	1791.96	70.550	-39.9	-1.57	-2.18%
+3	205	35	17	575.30	22.650	1807.36	71.156	-24.5	-0.96	-1.34%
	215	30	17	560.80	22.079	1761.81	69.362	-70.1	-2.76	-3.82%
	215	35	17	582.30	22.925	1829.35	72.022	-2.5	-0.10	-0.14%
	225	35	18	614.70	24.201	1931.14	76.029	99.3	3.91	5.42%
	225	30	17	566.80	22.315	1780.65	70.105	-51.2	-2.02	-2.80%
RS Model with 185/60/15:
HTML Code:
Orig.	185	60	15	603.00	23.740	1894.38	74.582	--	--	--
+1	195	50	16	601.40	23.677	1889.35	74.384	-5.0	-0.20	-0.27%
	195	55	16	620.90	24.445	1950.61	76.796	56.2	2.21	2.97%
	205	50	16	611.40	24.071	1920.77	75.621	26.4	1.04	1.39%
	205	45	16	590.90	23.264	1856.37	73.085	-38.0	-1.50	-2.01%
	215	45	16	599.90	23.618	1884.64	74.198	-9.7	-0.38	-0.51%
+2	205	40	17	595.80	23.457	1871.76	73.691	-22.6	-0.89	-1.19%
	205	45	17	616.30	24.264	1936.16	76.227	41.8	1.65	2.21%
	215	40	17	603.80	23.772	1896.89	74.681	2.5	0.10	0.13%
	215	35	17	582.30	22.925	1829.35	72.022	-65.0	-2.56	-3.43%
+3	205	35	18	600.70	23.650	1887.15	74.297	-7.2	-0.28	-0.38%
	215	30	18	586.20	23.079	1841.60	72.504	-52.8	-2.08	-2.79%
	215	35	18	607.70	23.925	1909.15	75.163	14.8	0.58	0.78%
	225	35	18	614.70	24.201	1931.14	76.029	36.8	1.45	1.94%
	225	30	18	592.20	23.315	1860.45	73.246	-33.9	-1.34	-1.79%
Wheel width to Tire width Ratios:
HTML Code:
Tire Width	Wheel Width in inches, and the wheel/tire ratio
mm	inches	5	5.5	6	6.5	7	7.5	8
175	6.890	72.57%	79.83%	87.09%	94.34%	--	--	--
185	7.283	68.65%	75.51%	82.38%	89.24%	96.11%	--	--
195	7.677	65.13%	71.64%	78.15%	84.67%	91.18%	97.69%	--
205	8.071	61.95%	68.15%	74.34%	80.54%	86.73%	92.93%	99.12%
215	8.465	59.07%	64.98%	70.88%	76.79%	82.70%	88.60%	94.51%
225	8.858	56.44%	62.09%	67.73%	73.38%	79.02%	84.67%	90.31%
235	9.252	54.04%	59.45%	64.85%	70.26%	75.66%	81.06%	86.47%
Hope this helps, and adds to the information already provided!
Z
2006 Red Blitzed RS 5-door
Old 04-13-2007, 11:05 AM   #4
Black Yaris
der Zeck
Z
you know some of those tire size you have in there do not yet exist... The tire sizes I have posted above are common and are easy to get ahold of for the common person, if a new tire size is made ANYONE PLEASE contact me so that I can edit the post to I can get the corrected information out to the people! But that is a nice spreadsheat ya got there Z
Old 04-13-2007, 11:12 AM   #5
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
You're right... I checked out 1010tires.com: The 30 series tires don't exist, and one of the 35 series tires don't... at least on that site. But ALL of the +1 and +2 sized combinations I listed (all of the 40 series tires and bigger) are there, which almost 99% of people would be considering anyhow (except spkrman & his huge 20"s!). So ya... for regular sizes, they exist.
I'll post a link so the people can download the spreadsheet if they want. I'll have to do it from home though b/c I'm firewalled at work!
Old 04-13-2007, 12:02 PM   #6
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Thumbs up
I love this, Heil the Tire Nazi!
SPONSORED BY
Old 04-13-2007, 12:45 PM   #7
Black Yaris
der Zeck
funny thing is, Ich spreche Deutsch!
Old 04-13-2007, 01:06 PM   #8
Funny thing, may be related or not.. My current tires are 0.8% smaller (or larger, can't remember) than stock, according to the Toyota Thailand specifications. But there is about a 5% discrepancy between my speedo and the speed reportd by my GPS unit. i.e when the speedo says I am going 100km/h, the GPS says I am going 95. Now, as far as I understand the GPS should be as accurate as can be, seeing as it calculates speed based on the actual rate of movement of the vehicle, not a wheel sensor.
What do you guys make of this?
Old 04-13-2007, 03:34 PM   #9
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Your correct about the GPS being far more accurate. The thing is, with my stock tires/wheels, my speedo was 3% off. If your was the same, combine that with your .8% difference and your getting close to your 5% discrepancy.
Black Yaris- Nice thread, very helpful! I'll reference tire/wheel PM's here from now on.
Old 04-13-2007, 10:39 AM   #10
ChinoCharles
Drives: LB
Now this is one gangster-ass thread... an instant classic.
Old 04-13-2007, 10:46 AM   #11
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
The fact that there's such a huge difference in circumference between the base model and the RS model (more than 3%) has always made me wonder... like if they have different speedometer gearings...?! Weird, isn't it? And since the base model has smaller tires, it should mean it can accelerate faster than an RS can!
Old 04-13-2007, 10:54 AM   #12
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
[QUOTE=Doc Zaius;74847]The fact that there's such a huge difference in circumference between the base model and the RS model (more than 3%) has always made me wonder... like if they have different speedometer gearings...?QUOTE]
The speedos are not gear driven. I really doubt the calibrations are different.
Old 04-13-2007, 10:46 AM   #13
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
can't imagine a yaris with 20' wheel
the_boss is offline   Reply With Quote
Old 11-02-2009, 12:44 AM   #14
Omu
Drives: 2009 Yaris
Like 4 years old kid wearing papa's shoes...
Omu is offline   Reply With Quote
Old 04-13-2007, 08:25 PM   #15
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
ncie thread!!! I love it!
-- Blen
Old 04-14-2007, 01:22 AM   #16
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
This should be emailed to every new member,or better yet,a private message.
eco is offline   Reply With Quote
Old 04-14-2007, 08:23 AM   #17
Black Yaris
der Zeck
Now where are the pix? huh?
Old 04-14-2007, 08:30 AM   #18
brickhardmeat
Lonesome Cowboy
It will be a little while, wheels and tires are coming seperately and then I'll have to get them mounted and balanced. I doubt I will even have the wheels by next weekend as they aren't even shipping out until next week. I'm so tired of waiting for stuff. I promise I'll post some pics. My photographer is "on call" for a Yaris photo shoot.
not sure how accurate this really is but anyway might make a nice addition to this thread....
http://www.wheelweights.net/
SPONSORED BY
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
