Old 03-11-2014, 02:17 PM   #1
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
yea, by .125 of a sec.
They only thing about that is, he pulled it off in his first run.. I had to do it on my 5th run... So he is fast and he can pull it of within 3 runs, which I am sure he is used to, going to a bunch of national events through out the states.
-Derrick-
Old 03-11-2014, 03:42 PM   #2
andres3165
Drives: Yaris to be
Found this, kind of cool :
https://www.facebook.com/SCCASoloSTF#!/SCCASoloSTF
Andres
andres3165 is offline   Reply With Quote
Old 03-12-2014, 11:02 AM   #3
andres3165
Drives: Yaris to be
So if I were to buy a ideal yaris to prep for STF, would the new 2014 L 3 door M/T be the best option?
If not which one?
Thanks
Andres
Old 03-12-2014, 11:39 AM   #4
ilikerice
ilikerice's Avatar
per numbers.. I would say yes.
its only 2 pounds lighter. 2 inches shorter. about 1 inch longer. more aero dynamic front... according to those numbers, it is better.. not by much though..
Same suspension, same motor.... If I could trade out my yaris for the new one, I would. But I have already molested mine, so its mine to keep forever
-Derrick-
Old 03-12-2014, 11:49 AM   #5
ilikerice
ilikerice's Avatar
If you do go with the 3rd gen yaris, get the SE... look for rear disc instead of the drums.. not that its that much better, but it looks better, lol
-Derrick-
Old 03-12-2014, 12:02 PM   #6
andres3165
Drives: Yaris to be
Thanks , see you in a few days
Andres
Old 03-12-2014, 12:06 PM   #7
Jason@SportsCar
The SE also has a quicker steering ratio.
Old 03-12-2014, 12:43 PM   #8
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Ideally the best car is Yaris sedan.
Its several inches shorter in height so the CG is lower and the frontal area is lower, its 2 inches longer and it weights a few lbs less. You also have the smaller front swaybar so inside spin isn't as much of a problem.
Old 03-12-2014, 12:56 PM   #9
Jason@SportsCar
Agree. One day I would love to build an H Prod sedan, just need to find a cheap donor chassis.
Old 06-08-2014, 01:42 PM   #10
andres3165
Drives: Yaris to be
Based on recent results I still think there is a lot to get from the Yaris which in STF prep version my get better power/weight ratio than my Mazda2, enough to compete with the powerful newcomers like the 2.3 Focus and pf course Mazda 3
Do you have documented data on those numbers, like weight and stuff between sedan and hatch ?
Thanks
Andres
Old 06-14-2014, 02:58 PM   #11
xnamerxx
0-60 in slow
xnamerxx's Avatar
Most of the numbers are available online like weight and wheelbase and height etc but I don't have any exact numbers.
Personally I would go with a Scion XD if you could get the weight down to the 2400lb range which I don't know if thats possible. Motor is good for well over 140hp on a Mustang Dyno, and it uses the same chassis as the Yaris with the lower roofline of the sedan, plus is has awesome gearing.
Old 03-17-2014, 04:02 AM   #12
ilikerice
ilikerice's Avatar
Scott was cool. saturday was close battle for 4th for me and him. I blame the lack of coffee and sleep Sunday was a bit more tough, Running the couse backwards definitely favored other cars more so than the day before.
I left saturday morning at 245am and got there at 630. I didn't calculate gas so I ended up running with a little more than half a tank of gas in the car. Silly me. There was NO open gas stations after I got off the interstate so Coffee was out of the question. When I got there it was pitch black, so I had to swap tires, check in, and get teched within an hour. Walked the course a few times. I ran 2nd heat and worked 5th.
All in all it was fun. I will post up pictures and results, I came in 5th out of 14 in STF.. Was fun. Will be doing this again and again and again.
Scott said he was moving back to San Diego here soon.
-Derrick-
Old 03-17-2014, 08:11 PM   #13
andres3165
Drives: Yaris to be
Yes hes a very nice guy , I put him to work , and he learned how to remove his rear shocks... ;)
Andres
Old 03-17-2014, 08:38 AM   #14
ilikerice
ilikerice's Avatar
I was almost disqualified on day 1. I was taking a nap during heat 3 and assumed that I would be up with in an hour. Apparently I slept much longer than I wanted. luckily I told some guys from my region that I was taking a nap so when they were calling my name for worker check in for heat 5, they ran over to wake me up.. That was a close one.
Here are the results, just click on the class you wanna see
http://sololive.scca.com/
Andres.. stick with the mazda2.. It is set up very well. Keep me posted on your results with the Ice Bag
-Derrick-
Old 03-17-2014, 11:31 AM   #15
xnamerxx
0-60 in slow
xnamerxx's Avatar
Congrats on the trophy finish.
Scott is registered for the California events so I'll probably see him next month.
We have another Yaris that's going to register for the Pro and National next month. He managed to put another whopping on me this weekend also. Since I didn't do very well this weekend, I decided to take 2 of my runs that were within a 10th of each other and put them side by side, just to get a nice visual representation of how much a single mistake can cost you.
https://www.youtube.com/watch?v=rA-hTu0O60A
Old 03-17-2014, 07:16 PM   #16
justjesus
justjesus's Avatar
Drives: 2008 Liftback
that's awesome. good thing your pals came to get you!
Is it Alvin? I signed up for Sunday in the Yaris. I'm going to get my butt handed to me, but oh well. I need the practice, as I've been away far too long.
Old 03-17-2014, 07:34 PM   #17
xnamerxx
0-60 in slow
xnamerxx's Avatar
I believe so, he's been pretty good about attending every event so I would imagine he's gonna be there.
Nah, you're fast enough that if you put down a respectable time, you should have him.
Old 03-17-2014, 03:09 PM   #18
andres3165
Drives: Yaris to be
You guys were awesome, had a blast, nice to meet you .... going to Blytheville
Andres
How many posts till ChinoCharles locks this thread? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 9 04-14-2009 05:54 AM
Reported posts ChinoCharles Suggestions - Feedback - Questions 10 09-25-2007 07:48 AM
