Old 01-26-2011, 03:19 PM   #433
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by Yoda View Post
How boost you gonna run?
I am trying to tune the engine myself so I am trying to make a nice tune on 9psi only for now and with the Cam timing disconnected so Fully retarded.
After I get the numbers with the 9psi tune, I will activate the VVti and play around again for the best numbers I could achieve.
After that I will leave the VVti on and up the boost 1 psi and tune until I am satisfied with the power end :)
Old 01-26-2011, 05:23 PM   #434
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Nice taking your time with it. I gonna try to get mine tuned tomorrow have to call around for the right price
Old 02-19-2011, 01:53 PM   #435
Parmas
Parmas's Avatar
Here are the latest updates of the engine bay.
- Complete Oil Custom Catch Tank
- Turbo Oil Pressure Gauge
- Added a 3 Gauge Interior Setup
Tuning is almost done. The only thing that remains is tuning on variable camshaft positions
For now I kept low boost (11psi) to verify that the engine holds easily up to 6500rpm. But I am feeling that off boost the engine can improve much more since the camshaft is rather retarded than advanced.
I didn't dyno the engine yet and didn't even try a track time so I cannot post any exact numbers. Also still need to install the much awaited NST crank pulley. The mechs are a bit busy lately so I have to wait for next 2 weekend for another update...
Old 02-19-2011, 03:19 PM   #436
that looks nice.
So you have a separate oil pressure for just the turbo? That looks like a lot of adaptors stacked up! :)
Old 02-20-2011, 12:06 PM   #437
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Love that intake!
Old 02-21-2011, 02:00 PM   #438
Focus_Sh1ft
Focus_Sh1ft's Avatar
Looks great man.
Old 02-21-2011, 02:08 PM   #439
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Everything looks so clean! I'm just wondering if it leaks.
Old 02-24-2011, 03:50 AM   #440
Parmas
Parmas's Avatar
For now it isn't leaking and I am not worrying that it would eventually.
Thanks for the comments
Old 03-03-2011, 01:30 PM   #441
Parmas
Parmas's Avatar
The idle problem was solved! Last night I dreamed that the idle motor of the 1NZ is the same like the 2ZZ and well it was infact!!!
The problem was the idle control motor not working for a reason now idles like a charm!
Dyno date is expected to be within about 3 weeks and I hope it will be the final tune! I am eagerly waiting for numbers!
Old 03-04-2011, 06:24 PM   #442
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
Looks great! You've come a long way with this project. Cant wait to see the dyno numbers.
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 03-08-2011, 05:55 AM   #443
Parmas
Parmas's Avatar
Yesterday I had my car started and noticed it was running different without changing the base map. Noticed the AFR showing stoich on all loads and rpm.
Done a free-air calibration and it could not get it calibrated. Checked with the manual and it is probably the sensor damaged.
The manual stats that for turbo charged engines the sensor must be mounted 12-16 inch from the turbine outlet. Could it be the issue?
Sensor was only used for 2 months.
What are your experiences?
Old 03-08-2011, 07:15 AM   #444
It could be because it's too hot any closer than 12-16 inches. Was the reading changing at all?
Old 03-08-2011, 11:46 AM   #445
Yoda
Yoda's Avatar
What kind of afr gauge you have? You can pull it out and test it.
Old 03-08-2011, 01:10 PM   #446
Focus_Sh1ft
Check continuity maybe?
Old 03-08-2011, 02:46 PM   #447
Yoda
Yoda's Avatar
i kno for my aem you can test it with some carb cleaner and a rag
Old 03-08-2011, 05:02 PM   #448
Parmas
Parmas's Avatar
The sensor is connected directly to ecu and I can see the values on the Ecu software.
The sensor is Haltech, like the ecu and the reading change slightly from 14-15 on all loads and also when engine is off.
Old 03-09-2011, 09:04 AM   #449
If it's still reading 14-15 with the engine off, either your software is clamping the sensor or it's gone bad.
Old 03-10-2011, 11:59 AM   #450
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
mine is 4-5 inches from my turbo in my wrx, its worked for 2 years, i believe i need a new sensor now.
as for the sensor reading when the car is off that is normal. the exhaust the piping is that afr, if you leave it on it should slowly slowly dissipate.
free air calibration requires you to remove the sensor from the down pipe in fresh air.
can always try replacing the sensor, i believe most use the 5 or 7 wire bosch. can get them at a decent price mostly.
Scubaru Steve is offline   Reply With Quote
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
