Old 11-26-2018, 06:35 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Badge
Looks as though the badge is going to require some modifications to fit on my car. The original TS grille seems to be more of a 'square' honeycomb and mine is more of a vertically elongated honeycomb. So, I'll be thinking about ways to adapt it to fit. A little disappointing, but definitely solvable. I'm wondering if a really strong RTV sealant would be adequate.
I thought I might buy a knockoff TS grille but the only honeycomb style grilles on eBay appear to be the same as mine.
Sorry, gentlemen, I thought these would be a direct fit, snap on item - at least for Sam and me (hatchbacks). If anyone has any suggestions about how to afix the badge, I'm all ears. Thanks.
Old 11-29-2018, 12:23 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by 06YarisRS View Post
Badge
I looked up the badge part number on toyodiy.com and it's only for the 1st gen Vitz (Echo in the US/Canada). There is/was a TS badge for the Euro ZSP90 (75312-52060) but I don't show any hits on the gargler for places that have it available for purchase. That also assumes you have a compatible grille for it (only available on JDM 05-08 RS or EURO 06-08 TS models). That said, I'm still going to try and rig something up to put it on mine. =)
Old 11-29-2018, 03:44 PM   #3
06YarisRS
Yeah, I couldn't find anything other than the ones I got. It actually isn't too bad for installation, at least for my grille. I would have used WeeYari's suggestion about epoxying a plastic bolt to it and using a plastic nut to secure it, but I'd already 'glued' it on.
Looks like your badge arrived. I look forward to seeing it on your car when you get the opportunity to install it.
Old 11-26-2018, 07:59 PM   #4
How about knocking enough clip off to allow it to sit flat on grill. Epoxy a nylon bolt onto the back of badge. Tighten into grill with nylon nut.
Sent from my EML-L09 using Tapatalk
Old 11-26-2018, 09:03 PM   #5
06YarisRS
Excellent suggestion WeeYari. Before reading this, I went out and attached the badge. As you suggested, I removed a couple of the clips. Then it would sit flush and stay put, but not strongly affixed. I put large globs of RTV sealant on the clips, then went around behind and applied more rtv, basically creating a big blob that connected all of the remaining clips. Since it's cold in my garage, I gently used my heat gun to warm the rtv. When this cures, the grill would come with the badge if pulled hard enough.
Here are a couple pics. Sorry about the quality. Crap camera and bad lighting.
Here's a better one taken outside.
Old 11-26-2018, 10:08 PM   #6
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Awesome!
Old 12-06-2018, 08:12 PM   #7
06YarisRS
Picked up my sway bar and A/C manifold gauge kit and the fittings needed to attach to the R134 can. Required an R134 can tap, flare to male pipe half union and pipe coupling.
I nearly gave myself a hernia lifting the vacuum pump out of the box. Man, that's a solid pump!
Holding 30" of vacuum after 90 minutes. I'm confident that the system is leak free. Will put a 45 minute vacuum on the system tomorrow, then fill with refrigerant ~15 - 17 oz, or about 1 and slightly less than 1/2 cans. EDIT: looks more like 13 - 14 oz of R134 All this, just in time for winter. At least the system will remain uncontaminated. I didn't want to leave any air/moisture in the system.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
