Old 11-05-2008, 12:06 AM   #37
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
how do I jack up my yaris? I work at a auto repair shop...so...chassis lift on the toyota reccomended lift points....muahahahahah.
as far as tires...i wouldnt ever over inflate a cheap OEM equipment radial...thats just me though. I have worked at dealerships before and I have seen the results of over and under inflating said cheap tires. most tires wear evenly at 5-10 pounds under max pressure rating.
Old 11-05-2008, 03:10 PM   #38
nemelek
DWEED
nemelek's Avatar
Originally Posted by b_hickman11 View Post
This chart is for a 6 wheel Dodge rather than a 4 wheel Dodge, correct?
No. This chart is the Dual (6 tire) 1 ton 4X4.
The last post was for a 2004 3/4 ton 4X4 which weighs 7,000 pounds. I think the 1 ton is 500 pounds heavier.
Old 11-06-2008, 10:02 PM   #39
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Nice!
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 11-06-2008, 11:52 PM   #40
touroxin
touroxin's Avatar
Drives: 2008 Yaris 5M Blazing Blue HB
Yeah, boy that would be helpful!
Anyone who has a digital camera, a Yaris (HB or Sedan), and knowledge of the jack points... Please post a picture of said jack points so Voodoo22 and I can verify the jack points on our cars??
Thanks fellow Yaris owners!!!
touroxin is offline   Reply With Quote
Old 11-07-2008, 11:18 AM   #41
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
I can tell you two facts about tire rotation wear from personal experience and some engineering research:
FWD vehicles suffer significantly more wear to the front tires than the rear for three reasons: engine/tranny weight, steering wear, acceleration/braking wear (depends on the driver). Rotation will definitely aid in equalizing this wear between the 4 tires.
Modern steel belted radials shold only rotate in one direction, and do risk delamination/belt twisting when run on the opposite side of the vehicle, though the risk varies greatly depending on vehicle type, tire sidewall height and inflation pressure. Often the tire will not fail, but the lateral belts can become "curved" in the original rotation direction, and then resist flex in that direction when reversed. On larger tires (33" on my Jeep) this can result in a noticeable wave in the tread. Also, I have seen tires blow-out after being installed (used) without knowing the original rotation, although that could have been caused by a number of other factors too.
Bottom line: Rotate your tires regularly if you prefer to replace all 4 at once and want to get the maximum mileage from your tires. don't rotate at all if you don't mind replacing 2 at a time or don't care if 2 of your tires still have more tread left when you replace them.
NEVER cross-rotate modern radial tires, directional or not. :)
Old 11-07-2008, 12:19 PM   #42
b_hickman11
Drives: 08 Sedan
So it sounds like you are saying that tires have a mind of their own....or maybe even a computer chip that tells what side of the car it should be on??
Old 11-07-2008, 12:20 PM   #43
nemelek
DWEED
nemelek's Avatar
The rear jack up point is 4 inches in front of the license plate. 1st picture using a 3 ton floor jack.
The side jack up points are between V notches close to the front and rear tires. 2nd and 3rd picture using the car jack. The cheapest car jack I have ever used.
The front jack up point is about 32 inches from the front bumper using a 2 ton floor jack. The 3 ton jack was hard to fit under the car. Remember to use parking brake when jacking up the front.
When I rotate tires I'll use the 2 & 3 ton jacks on one side of the car at a time. I don't think that I'll ever have the need to jack up the front or rear tires at the same time. These pictures are from a 2008 hatchback.
Old 11-07-2008, 02:23 PM   #44
touroxin
touroxin's Avatar
Great!!!
Thanks!!!!!
Old 11-09-2008, 01:05 PM   #45
touroxin
touroxin's Avatar
I think the Sedan is the same, it is just that the rear jack point is in the middle instead of more to the passenger side.
Old 12-27-2008, 03:39 AM   #46
PenquinZ111
Drives: RC yRs LB
i use a lift. since i do work a at dealership
PenquinZ111 is offline   Reply With Quote
Old 12-27-2008, 08:36 AM   #47
i just use the side jack point closer to the front of the car (behind the front wheel) and jack it all the way up....i do one side at a time for rotation.....
so rear passenger --> front passenger and front passenger --> to rear passenger then i do the same for the drivers side...
this way i only have to jack up once per side and it works whether you have direction tires or not....
Old 11-14-2010, 11:19 AM   #48
justlkn
Just installed winter tires on the Yaris, using a trunk jack.. I have a lift in my shop, but really hate lifting vehicles with no frame.. Pickup trucks are easy.. what would one use for lift points on a yaris.
justlkn is offline   Reply With Quote
Old 11-14-2010, 11:57 AM   #49
^ same as the jack points. My car has been on a lift more times than I can remember. If you don't want to mess up that lip underneath, insert a slotted block to preserve it.
Old 11-15-2010, 04:40 AM   #50
N3misiS
N3misiS's Avatar
Drives: Yaris T1 1KRFE
WHy dont you ask for help at a tire place and put the car on the lift, my dealer does it free...
It saves a lot of frustration....
its quicker.
“Do or do not... there is no try.”
N3misiS is offline   Reply With Quote
Old 09-23-2011, 01:31 PM   #51
wolfywho
wolfywho's Avatar
Drives: 2011 3-Door Liftback
If I lift up the front from the center lift point using a floor jack, and I want to put the front of the car on jack stands, where would I place the jack stands? Are there front side lift points, like the rear side lift points? Thanks!
wolfywho is offline   Reply With Quote
Old 09-23-2011, 01:38 PM   #52
You would have to put the jack stands where the jack points are on the pinch seam behind the front wheels.
Old 09-23-2011, 03:43 PM   #53
wolfywho
wolfywho's Avatar
Thanks CT. Are those pinch seams pretty strong? Almost seems like you could bend those with the weight of the car sitting on them.
-wolfy
Old 09-23-2011, 03:50 PM   #54
-wolfy
They are actually meant to be supported by a slit block, like the top of the OEM jack, as opposed to being supported by the edge. Prior to getting my lift I would lift the car from the center point and use my old jack stands under the seams. My jack stands have narrow tops, so I couldn't use the slit hockey pucks that I use when jacking at the seams. There is a bit of paint chipping on my seams from my stands, but no signs of deformation. With my lift, I actually lift it by the four pinch seams, but my lift has 6x6 pads with 1/4" thick rubber, so the pressure is well distributed.
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
Yaris Crashed! elsteverino889 General Yaris / Vitz Discussion 13 11-06-2006 02:59 AM
