Old 12-04-2008, 04:43 AM   #37
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Cmon people I want to see these headers fabricated
Old 12-04-2008, 11:38 AM   #38
richardholdener
Drives: 2008 Yaris hatch
We are going forward with the first production run of the long tube header and mid pipe. We will have the following options: Cat, resonator or both
richardholdener is offline   Reply With Quote
Old 12-04-2008, 11:55 AM   #39
jkuchta
Drives: 2007 Yaris hatch (red)
What material will the parts be made from? Also, will the cat be a bolt on affair (i.e. replaceable)?
jkuchta is offline   Reply With Quote
Old 12-04-2008, 01:20 PM   #40
thepoche
thepoche's Avatar
Drives: Toyota Yaris CE
I can't find where he said it, but I believe it will be mild steel. I would of prefered stainless cause things rust easily here in Canada.
thepoche is offline   Reply With Quote
Old 12-04-2008, 02:08 PM   #41
richardholdener
The header will be made from mild steel with Jet Hot coating-we are also looking into cost difference for stainless steel. Cat will be bolt on (replaceable)
Old 12-04-2008, 04:03 PM   #42
jkuchta
I am VERY interested in a stainless version.
Old 12-04-2008, 11:31 PM   #43
WolfWings
WolfWings's Avatar
Okay, after doing some research I'm fine with the Jet Hot coated mild steel version if stainless turns out to be prohibitive.
And are the cat/resonator options all on the midpipe?
Old 12-05-2008, 05:51 AM   #44
PHXDEMON
PHXDEMON's Avatar
I'm down for cat only. Screw the resonator. That's what a muffler is for.
Old 12-05-2008, 04:34 PM   #45
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
does it fit the seddan?
DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
t0m4s is offline   Reply With Quote
Old 12-05-2008, 07:03 PM   #46
richardholdener
The header will definitley fit the sedan, but not sure about length of mid pipe-anyone know difference in length of exhaust system between hatch and sedan?
Old 12-06-2008, 01:42 AM   #47
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
I think i just realized that i am the only sedan owner on this list. What problems do i run into richard? I would love to just bolt to a axleback and call it a day.
anonymous user is offline   Reply With Quote
Old 12-06-2008, 02:03 AM   #48
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
any idea on a month when it will be done?... jw
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 12-06-2008, 02:24 AM   #49
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
same with manifold
Old 12-06-2008, 11:37 AM   #50
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
If I screw in the O2 anti-fouler will this header pass emissions test? I live in Texas and They will use my OBD2 port to check for emissions. So aslong as the header doesn't throw a CEL I will buy it later on.
Old 12-06-2008, 11:44 AM   #51
richardholdener
The header itself will not throw a CEL-but the second oxygen sensor is an issue. If it can be fooled with anti-fouler then there should be no problem. If the header is run with a cat-then it will likely pass a sniffer test as well but the system is offficially for off-road use only.
Old 12-06-2008, 11:44 AM   #52
richardholdener
We plan on having the header and mid pipe bolt to the axle back.
Old 12-06-2008, 12:35 PM   #53
lilredrocket
Slowy getting there
Drives: 08 Liftback
Ok because texas only uses a sniffer on 96 and older cars so as long as the O2 sensor is reading ok, the check engine light isn't on, and its not pouring out black smoke Ill be fine. Unfortunatly I will have to buy this later I'm saving all the pennies I have for the intake mani.
Old 12-08-2008, 05:54 AM   #54
PHXDEMON
PHXDEMON's Avatar
any Idea when the header will be done? I need to know how long I have to save my money before I start spending it on other mods
Official Richard Holdener who wants to buy an intake manifold list kou Performance Modifications 385 03-27-2009 11:29 AM
Long Tube Header Dyno results & Photo richardholdener Performance Modifications 59 11-26-2008 05:27 PM
Long Tube Header kou Performance Modifications 2 11-18-2008 01:15 AM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
