Old 08-04-2006, 09:31 AM   #37
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Originally Posted by Sp33dY
6 inch = 15cm! That still way higher than it looked in the pics on page 1! I'd of thought part of the undercarriage or side chassis sills/frame would sit lower than the front bumper! Thanks Chris :)
Crap, there is the lower plastic "skid plate" that does hang a bit lower... its the plastic pannels that keep junk from coming up into the engine bay.
Chris07LB is offline
Old 08-04-2006, 10:32 AM   #38
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
What about needing a front end alignment?
The last car I installed struts/springs on was my 88 beretta and it needed an alignment badly when I was finished.
07WYarisRS is offline
Old 08-04-2006, 11:06 AM   #39
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
Drives: 07 Red Yaris S & 95 Miata
Chris07LB, how is the ride compared to stock? That's my only concern. I know it'll be harsher, but how much harsher?
Don Neudecker
Ad Compositor Extrodinaire
"The instructions are inside the box." - My I.T. Dept.
Lizardboy is offline
Old 08-04-2006, 03:04 PM   #40
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Originally Posted by Chris07LB
Here ya go... tape tells it all.
SWEET. I measured mine today stock and I have almost the same exact measurements on the S. and from the front ground effect from the ground is 8 almost 9 inches. So if lowered it would be almost 6 to 7 like your LB. I thought that was weird.
slvryaris is offline
Old 08-05-2006, 01:29 AM   #41
johnnyfive
johnnyfive's Avatar
got my springs in today, long work day tomorrow, but ill try and sneak out early and throw them on, otherwise ill have measurments, and photos of them on the S sedan sunday after noon :)
johnnyfive is offline
Old 08-05-2006, 05:11 AM   #42
slvryaris
slvryaris's Avatar
Right on. I got my wheels and everything now. Just waiting to put them on. Let me know how it goes and we definitley want to see some pics. I wanna see how low these things are gonna ride.
Old 08-06-2006, 10:56 PM   #43
johnnyfive
johnnyfive's Avatar
install on the S Sedan is done, with one thing to add. If you have ABS you will need to desconect the abs sensor clip from the rear torsionbar to get the travel needed to remove the rear springs (the sensorline on the front is removed with the breakline clip)
the clips are attached just infront of the brake drums, and use a 10mm bolt
another side note, wear gloves...i have always thought that "gloves were for wussys"?... and have always prefered the greater feal of hands on working. but i got a fairly serious cut in my palm when a wrench sliped removing the top nut, and hand slid onto the sharp surface of the wiper cowel area (not bone revealing though ) would have probably worked better if i was using a box wrench with a droped box (not sure how to explain it) instead of using a combination wrench with just the slightly angled box end.
but 4 stiches later and the job is done, and the bottom of the front lip sits just 5.5" from the roadway, get full lock to lock turning, and no tire rub at speed, or on rough road, and the stance looks 100 times better
before:
after:
next thing on my list is buying a pair of mechanics gloves :)
ohh, and then rims :)
Old 08-07-2006, 11:11 AM   #44
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
So what is the ride like? How much harsher is it than stock.
Don Neudecker
Old 08-07-2006, 12:03 PM   #45
Chris07LB
Chris07LB's Avatar
Will be updating original post with my ONE WEEK, 600 Mile later review with AFTER pictures, of the Tanbe DF210's.
Stay tuned.
Old 08-07-2006, 12:53 PM   #46
ChinoCharles
Drives: LB
Hot.
ChinoCharles is offline
Old 08-13-2006, 06:27 PM   #47
Chris07LB
Chris07LB's Avatar
< > BUMP 4 Updated AFTER Pics in Original Post < >
Old 08-26-2006, 02:21 AM   #48
03Z33
03Z33's Avatar
Drives: TCR10
Just finished mine tonight... thanks for the helpfull write up!
I actually didn't have a 6mm allen key that can fit under the metal tray, so I ended up removing the wiper motor and metal tray to get full access to the strut cap from the top... it doesn't take very long at all and I was able to quickly pop the struts out using the impact
Pics coming soon.
03Z33 is offline
Old 08-26-2006, 09:07 AM   #49
slvryaris
slvryaris's Avatar
Just finished my NF drop up yesterday with the 215/40/17 tires. There has been no rubbing at all with just me in it. Me and a friend installed them and if we didnt bs all day it probably would have took about an hour and a half. Chris the write up was very very very helpful and was crazy cause it was like word for word. Here is an after pic.
Old 08-26-2006, 09:53 AM   #50
Chris07LB
Chris07LB's Avatar
HOTT YARIS BRO!
Glad the How-To was useful... I enjoy doing them.
Old 08-26-2006, 10:10 AM   #51
03Z33
03Z33's Avatar
Drives: TCR10
Looking good! It's funny that we both ended up installing them on the same day Your drop actually looks about the same as the DF210's on my Hatchback... and the Axis wheels fit the car VERY Well
03Z33 is offline
Old 10-01-2006, 10:13 AM   #52
manborn
are u still 34/39?
manborn's Avatar
Drives: flint mica yaris s sedan
DF or NF for s sedan? 1st priority is ride. so which 1?
also with these springs, what tire/wheel setup is best for no rubbing even with 4 seats used (170lbs per person)?
manborn is offline
Old 10-02-2006, 04:28 AM   #53
paultyler_82
if the ride comfort is 1st priority, go with the NF's
paultyler_82 is offline
Old 10-10-2006, 10:29 PM   #54
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Just finished my df install (well about an hr ago....) nothing like putting your yarr back together with a halogen lamp..
I'll snap some more pics tomorrow morning and post them.
will work for parts
vodkalush is offline
Tanabe Strut Tower Bar Install & Review [pics!] Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 04-07-2022 07:46 AM
Springs - Tanabe DF210 or Tein S Tech andylai2k Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 06-10-2007 09:22 PM
Tanabe DF & Strutbar install mcdaddy DIY / Maintenance / Service 18 05-03-2007 09:57 PM
TANABE DF210 SPRINGS AVAILABLE!!! C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 08-05-2006 12:28 AM
Spring Install Price redglare45 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-30-2006 08:32 PM
