Old 08-24-2006, 04:12 PM   #37
pauljk
Drives: Yaris LB automatic
Originally Posted by Polar_Yaris
You guys can check out the "technicial Talk" section, we have a similar issue there........
Polar_Yaris - can you give us a link, please? I don't see it.
I've noticed something similar on occasion at 60mph, but it's subtle, and I wasn't sure if my Rostra cruise control was doing it or not. Interesting to find others have noticed it too.
pauljk is offline   Reply With Quote
Old 08-24-2006, 04:31 PM   #38
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
I think that post is already removed due to the layout changes on this forum before. However, if you're speaking of the humming sound, I think there still no fix to it from Toyota yet.
GabL is offline   Reply With Quote
Old 08-24-2006, 05:57 PM   #39
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Originally Posted by Violin
I get a very faint mmmm...mmmm...mmmm at 70 mph. I can't feel it but can hear it. I'm not sure I would have ever noticed it if I hadn't read this.
Thats a good description of what I am hearing as well.
Old 08-24-2006, 06:09 PM   #40
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
again, tire pressure / balance etc fixed my other car before
mikeukrainetz is offline   Reply With Quote
Old 09-02-2006, 09:00 PM   #41
dandj
Drives: 07 Yaris sedan auto
Question
I think I'll play with the tire presures. I just moved mine from 36 to 44 psi and seems to be worse. This would indicate a lot of misbalanced or bad tires for so many to have the exact problem.
dandj is offline   Reply With Quote
Old 09-03-2006, 12:19 AM   #42
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
It's nothing to worry about it simply harmonic noise thats why most people notice it at about the same engine speed.
All engines produce harmonic vibrations some more then others and some at different speeds.
Try riding a V twin motorcycle at 80mph and you will know what I'm talking about.
My Laser has a harmonic vibration at 60mph and again at 110mph
my VLX had a harmonic vibration right at 55 but only in 4th gear (more engine load)
It's an econo box built light and rigid for a bigger car feel with a small engine. Most of the harmonic noise comes from the counterbalancers and timing chains as well as the transmission gears. If a person was to completely blueprint and balance the engine perfectly you could eliminate most of the vibrations but in any econo box your going to get some harmonic noise/vibrations.
FWIW My yaris and every other yaris had the exhaust rattle in reverce while not under load. It does this because of the torque load on the engine twisting against the exhaust and engine mounts
Old 09-25-2006, 12:45 PM   #43
GoZO
Drives: Yaris 3 Door
Originally Posted by GoZO
Mine sounds like a piece of metal vibrating against another piece of metal. It occurs in 2 second intervals when I am between 70 - 80 MPH.
It sound like it is coming from the shifter boot / parking break area. I removed the cover while I was driving but it is coming from underneath the metal.
Ugh.... Might be time for the dealer service guy to ride with me.
Well I finally had enough of this sound and took in the Yaris.
They fixed the noise.
Notes in the workorder.
"Found Heatsheild was out of adjustment. Raises and inspected made some adjustments to heat sheild on exhaust. Test drove again no further abnormal noise heard"
GoZO is offline   Reply With Quote
Old 12-03-2009, 10:21 AM   #44
RUBBERDIPSTICK
Drives: Toyota Yaris Base Sedan
Bump. I have the same problem a humming/vibration coming and going at short intervals when traveling at 68-72 mph. I have 69k miles on my 2007 5 speed sedan.
Any resolution yet?
RUBBERDIPSTICK is offline   Reply With Quote
Old 09-29-2010, 12:16 PM   #45
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
up
ricepower is offline   Reply With Quote
Old 09-29-2010, 12:59 PM   #46
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Keep in mind we have a Yaris and not a Lexus. But the problem lies in the inline four. At higher RPM you will feel an engine vibration. Add to that, there are probably resonant or harmonic frequencies that will amplify that. The inline four above two liters has a balance shaft to help reduce engine vibration. Add another thing, a light weight body that lacks sound insulation or damping. The body has resonant or harmonic frequencies that will make vibrations more apparent.
To get rid of the vibration, make your next car one with an OHC V6.
Old 10-28-2010, 10:43 AM   #47
echaru
PsychMobile
echaru's Avatar
Drives: '10 Yaris 5Dr Blazing Blue
Just bought my Yaris. Got the same humming problem mmmmm....mmmmm....mmmmm... 60mph and up. But when I go faster 70mph+, the noise is not noticeable. Anyone found the fix yet?
so...UP
echaru is offline   Reply With Quote
Old 10-28-2010, 11:26 AM   #48
yaris-me
Learn to Relax
so...UP
Keep in mind that you bought a Yaris, one if the cheapest cars on the market. If you want to get rid of the hum, buy a more expensive car with more insulation and a V6 engine.
Old 10-28-2010, 12:31 PM   #49
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
yea, the hum is just tire noise, all tires have a speed where they make a little more noise, it has to do with the frequency of everything going on. It is not a bad thing, and the only thing you can do to quiet it is add a few hundred pounds of insulation.
Colin Chapman disciple
Old 10-29-2010, 03:30 PM   #50
echaru
PsychMobile
echaru's Avatar
So if everyone with Yaris is having this problem then I can rest easy tonight.
Old 02-05-2011, 04:42 PM   #51
jadsnca
Humming noise
Originally Posted by Polar_Yaris View Post
Ricko, I am not 100% sure, however I have own quite a few 4 Cyl cars and none of them have that kind of problem. Well, I think most of my problems are related to the Automatic Tranny. I have not hear anyone complaint about their 5-speed Yaris. I picked auto because i am getting lazy......
I just bought a 5 speed manual and I got that humming noise too when driving at highway speeds above 90 kms/h. Never experienced that with any other 4 cylinder car.
jadsnca is offline   Reply With Quote
Old 02-05-2011, 04:44 PM   #52
jadsnca
mmmmm.....mmmmm.....mmmmm
That's exatly what mine sounds like< it goes away if I stop giving it gas or if I stick it in neutral.
Old 02-05-2011, 04:46 PM   #53
jadsnca
New tires< noise still there
I just got new tires installed and balanced and that mmmmm.....mmmmm.....mmmmm is still there< its not the tires.
Old 02-06-2011, 08:46 PM   #54
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
I think the noise is harmonics. Mine "went away" after I installed my Tanabe exhaust. :)
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
2007 Yaris Unveiled at 2005 SEMA Show YarisBueller General Yaris / Vitz Discussion 0 01-12-2006 05:28 PM
