Old 01-23-2009, 11:31 AM   #37
otterhere
Drives: 2008 Yaris 3-door Meteorite
I wouldn't be TOO embarrassed... As Mark Twain said ("Reports of my death have been greatly exaggerated."), so -- methinks -- have the "great mileage" claims on the Yaris. Toyota advertises it at 29 city/34 highway, or maybe 36 (can't remember), and I imagine that's pretty close to the truth of the matter.
otterhere is offline   Reply With Quote
Old 01-23-2009, 12:14 PM   #38
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
I put my stockies back on for winter and get 2mpg more than I did with my 17s,which made me feel pretty good.
Heavier tires,stop and go traffic and cold winters take milage down.Also look at the vent setting,if it is in the defrost position your compressor will run to dry the air,using more fuel,and it will do it most notciable at stop lights.
After getting my car realigned last week I also have gained another mpg,and am back up to 35 mpg for highway travel.
when I drive all city travel,with defrost or AC on with the17s I average about 25mpg,i have a heavy foot at stop lights......
But coming from a gas guzzling hot rod to the yaris.......this thing is sipping gas......GTO ate up 15 gallons in 3 days,and that was only about 140 miles tops......much happier.
Old 01-23-2009, 01:17 PM   #39
otterhere
Originally Posted by bzinn 1 View Post
IAlso look at the vent setting,if it is in the defrost position your compressor will run to dry the air,using more fuel,and it will do it most notciable at stop lights.
Ah-ha! I've been wondering about that. Because I have to defrost it most mornings (ice on windshield), I generally just leave the vent open (in the recirculate position). I wasn't sure what effect this might have on mileage?
Old 01-23-2009, 01:48 PM   #40
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
With the previous car ('03 Corolla), I changed original 15" to 17" and did not affect fuel economy at all. It was 32 mpg before 17" rims and 32 mpg after rims. 17" was much heavier than 15". I had a lot harder time carrying 17" from my condo to the parking lot.
My friend had '07 LB, 90% city driving, lots of short trips and idling, and still was getting 25+ mpg.
20 mpg seems to have something wrong to me.
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 01-23-2009, 05:10 PM   #41
XYaris
Drives: '09 Yaris LB
1. Its a manual (so no overdrive issue )
2. I do have to defrost a lot ( the yaris windows like to fog up and its winter )
3. I talked to a few local dealers. One cool one said he doesnt think anything is wrong. That if the car was throwing a code the check engine light would on. duh. So I would assume that if the lambda or other sensor was bad this would trigger a code. He also said that the engine not being broken in at all may make a difference as well. Im gonna drive it as is until the first oil change which is a new debate altogether.
Should I wait until 5k to change the oil for the first time? especially with these concerns?
I have recently pulled of almost 25 mpg so that makes me feel better.
Thanks yall for your advice and concern.
XYaris is offline   Reply With Quote
Old 01-23-2009, 07:09 PM   #42
brendenr89
Drives: 1993 Del Sol Si
maybe, just maybe it's a bad fuel filter??
brendenr89 is offline   Reply With Quote
Old 01-26-2009, 02:25 PM   #43
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
1. Check your tires and set to 32psi or the average of 32 and max sidewall rating.
(mine were under inflated at dealer pickup, but not quite low enough to trip the TPS)
2. Change the oil (perhaps going to a lighter weight synthetic for the cold weather) and make certain not to overfill it. (between the lines on the dipstick, NOT over the top line)
3. Borrow a scanguage or get a passenger for a weekend to watch your shifting.
If you don't upshift quick enough, ride the clutch, or spend too much time in 3rd or 4th (even in the city) your Mpg will suffer. 20 or more years ago you often needed to get the revs high in lower gears to get an economy car moving well. You don't need to do that with a Yaris. Try it for a week or more and see what happens.
SpaceShot is offline   Reply With Quote
Old 01-26-2009, 10:59 PM   #44
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Mmmm, maybe. I NEVER make ANY 4-holer pull hard below 2,000rpm, including my Yaris, and I seldom rev over 3500, but I still get excellent mileage. The first thing I did was run up the tire pressure to sidewall max -2lbs, and resumed my usual driving style, ie don't slow down for corners, never floor it, read traffic so that I don't have to slow down any more than absolutely necessary. Works for me.
Old 01-27-2009, 02:13 AM   #45
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Lead foot. Get yourself a scangauge and get the lead out. You'd be surprised how much you can let up on the gas and still maintain speed.
Old 01-28-2009, 11:33 AM   #46
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
I'm currently doing about 50km (30 miles) to a bar right now.
firemachine69 is offline   Reply With Quote
Old 01-28-2009, 01:48 PM   #47
TLyttle
TLyttle's Avatar
I prefer 8 beats to the bar myself...
The accuracy of the fuel gauges was discussed awhile ago, and the consensus was, don't depend on them, use them as a rough guide only.
Old 01-28-2009, 08:40 PM   #48
minicorolla
Drives: 2008 Sedan White
And I'm bitchin' about 36 MPG
minicorolla is offline   Reply With Quote
Old 01-28-2009, 10:39 PM   #49
firemachine69
I was in that boat for a while... And while accurate in the testament, mine seems to now evenly spread mileage between the first and sixth bar.
I'm now averaging 25-27mpg. ALOT better.
Old 01-29-2009, 10:50 AM   #50
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
My crappy mpg is due to the engine never getting to operating temperature during the winter,my Scangauge tells me that i need to drive at least 5-6 miles at highway speeds to attain temps in the 180's and most of my driving these days is all city driving for no more than 20 minutes at a time. I'll see how it improves on an upcoming trip to Florida.
Old 01-29-2009, 11:18 AM   #51
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
well i hit my worst on 7 bars /36 liters.. i only did 450 kms...winter weather though but i think this is the worst ever for me.
Old 01-30-2009, 10:57 AM   #52
otterhere
"The first thing I did was run up the tire pressure to sidewall max -2lbs, and resumed my usual driving style."
Okay, I give; what 2 pounds under sidewall recommendation? I'm far from my car now...
Old 01-30-2009, 11:50 AM   #53
TLyttle
TLyttle's Avatar
Depends on the tires, different makes have different limits...
Old 01-30-2009, 12:42 PM   #54
otterhere
I've got my standard 15" (2008 2-door liftback) inflated to 38... Were at 26 when I got around to checking them (after buying it "new")... Expect to see some improvement in mpg at this level.
-Mileage Thread- -Log your mileage, year, model, color, any problems here... Kal-El DIY / Maintenance / Service 317 07-20-2016 10:07 AM
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 08:38 AM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 12:32 AM
