Old 01-25-2009, 04:55 PM   #37
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
I said it earlier.... try picasa and it's free. It will at least open the files and allow you some control.
Old 01-25-2009, 10:51 PM   #38
Anything and everything you know about RAW vs jpeg. Thanks.
RAW, as the name indicates, is the raw unprocessed data straight from the image sensor. The jpg files are processed and compressed, and thus are not as "pure" as the RAW file, but they are far easier to work on, so it's always a compromise between convenience and image quality.
Old 01-31-2009, 08:10 PM   #39
Black Yaris
der Zeck
Black Yaris's Avatar
someone on here will know this.....
when working with a RAW image in photoshop, I want to crop a photo down then do other editing.....but I have not figured out to apply the crop
Old 01-31-2009, 08:17 PM   #40
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Adobe has it's own conversion for RAW.
A RAW is not a JPEG. Rule number 1359 of photography.
firemachine69 is offline   Reply With Quote
Old 01-31-2009, 08:22 PM   #41
SailDesign
Drives: .
In Adobe RAW, which is what P'Shop will throw you into with a RAW file (hopefully), you cannot do anything much but adjust settings - contrast, exposure, gamma, etc. Then you have to go into Photoshop itself to crop and do all the other fun stuff.
Old 01-31-2009, 08:26 PM   #42
Black Yaris
der Zeck
well there is a button to crop in Adobe RAW.... I can select the area to crop, but I do not know how to apply that crop
here is a pic of what I am talking about
Old 01-31-2009, 08:42 PM   #43
SailDesign
Drives: .
OK - that will crop the whole RAW file, and you wil not get it back - ever. To use it, simply lay out the crop on the screen as you show, and push the "Open" button. your file is now permanently cropped
If you take the uncropped file to P'shop itself, you can crop using "hide" and the cropped part is hidden in the .psd file, but you can save the cropped version as a jpeg. If you ever want the cropped area back, you can get it back, or go to the original RAW file again.
Old 01-31-2009, 10:09 PM   #44
Black Yaris
der Zeck
ok got it
Old 02-01-2009, 10:16 AM   #45
SailDesign
Drives: .
SailDesign, if i may correct you. As long as the original RAW file has not been overwritten you can keep changing everything you want as many times as you want. What happens in PS when you open a RAW file it will create a configuration file that corresponds to a specific RAW file, this config file will have the settings you used to modify your RAW file. To go back to the original unaltered RAW file you simply delete the config file and thats it. Also the cropping will only be applied when the Save command is issued.
Good enough! Thanks for the correction.
Old 02-01-2009, 10:26 AM   #46
SailDesign
Drives: .
speaking of i should try and fabricate something
Yeah - you should. Stop typing and start making!
Micro Image Open House FEB 7 cali yaris California 387 03-04-2009 09:01 PM
Open Pods . A review. nurburgring Performance Modifications 3 05-19-2007 01:21 PM
MY pAsssenger side door wont open webmaster DIY / Maintenance / Service 11 04-24-2007 07:43 PM
Please open the DOOR CAREFULLY! Rahxephon Off-topic / Other Cars / Everything else Discussions 34 12-21-2006 08:25 AM
Cannot open the driver door when unlocking from the outside. Rahxephon DIY / Maintenance / Service 10 12-02-2006 09:18 AM
