Old 09-05-2006, 02:55 PM   #37
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
After typing that, I figured out a simple way to remove it from the FRONT of the emblem.
Old 09-05-2006, 11:36 PM   #38
ChinoCharles
Drives: LB
Originally Posted by Chris07LB
**Sure, I can do that........ you are thinking of a cheesburger or chicken burger for dinner tonight....... small frosty to wash it all down..... and maybe, just maybe splurge on a Biggie fry **
Was I close to reading your mind Charles?
It was chicken lo mein, fried rice, an egg roll, a McFlurry and a hi-c. Most other nights you would have been right, though. I needed my doseage of MSG.
And let me guess... you're on a liquid diet?
Old 09-06-2006, 08:08 AM   #39
Chris07LB
Chris07LB's Avatar
I'm lucky if I get to kick a few back a month lately.. damn work.
Old 09-06-2006, 09:19 AM   #40
ChinoCharles
Drives: LB
I'll slam one for you next time I'm out.
Old 09-07-2006, 08:33 PM   #41
Jfoofoo
Jfoofoo's Avatar
Drives: 07 Yaris HB Meteorite Metallic
Originally Posted by Katana
Dammit mine is black, so no painting for me...
you can paint it polar white or red?
Jfoofoo is offline   Reply With Quote
Old 09-07-2006, 08:34 PM   #42
Jfoofoo
Jfoofoo's Avatar
Mr. Chris07LB can you share that with the rest of the class?
Old 02-25-2007, 05:28 PM   #43
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
How? And how did you remove the rear?
Tanabe DF, Debadged, stripped, Black emblems
Nimble is offline   Reply With Quote
Old 02-25-2007, 06:01 PM   #44
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
sexy!
-- Blen
Old 02-25-2007, 06:11 PM   #45
Chris07LB
Chris07LB's Avatar
Removes easy.
Little heat, and grab an edge with fishing line, and carefully and slowly start to work your way around the emblem.
There are no nuts holding it from the back side, just two pins to keep it positioned correctly on the hatch.
Good luck.
Old 02-25-2007, 06:20 PM   #46
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
how do you "re-glue" it back onto the trunk?
Old 02-25-2007, 06:22 PM   #47
Chris07LB
Chris07LB's Avatar
3M body tape. Its the thinnest strongest double sided body tape around. Used for holding body kits and spoilers on.
Old 02-25-2007, 06:31 PM   #48
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
i'm assuming you can cut it to the desired shape then tape it onto the back of the emblem?
Old 02-25-2007, 06:40 PM   #49
Chris07LB
Chris07LB's Avatar
Stick it on....................... cut it to the shape using a new razor................ pull off backing................... correctly alight.............. stick, and your done.
Old 02-25-2007, 06:41 PM   #50
The Ho[]y Tape
The Ho[]y Tape's Avatar
Send a message via AIM to The Ho[]y Tape
I'm strongly considering doing this to mine. I just bought one in Meteorite Metallic. If I do it we should do a step by step on mine for everyone. I live in Jersey too.
The Ho[]y Tape is offline   Reply With Quote
Old 02-25-2007, 06:52 PM   #51
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
You beat me to it! I too was considering this but wasnt sure of the look. I like that a lot. I might try this when I shave the other badges off.
jdubau55 is offline   Reply With Quote
Old 02-25-2007, 06:58 PM   #52
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Thanks Chris. I'm looking into painting my Netz badge and rear toyota badge metallic blue to match the blue/black theme of the car even though car shell is white interior and rims will be blue and black.
Old 02-25-2007, 07:32 PM   #53
Nimble
You know I ended up popping off the entire front badge with a bit of force, and once I got it off, I finagled the chrome part off and actually just put the dull, black plastic part back on and it matches pretty good on my black car.
Tonight was project night so I also removed the entire rear wiper assembly and plugged the hole, and removed the rear badge and sanded it to get ready to paint it black this week.
Old 02-25-2007, 07:35 PM   #54
Chris07LB
Chris07LB's Avatar
Ill be giving my flat black rear emblem away soon.... something in the works.
Response from Toyota Driver New YARIS Purchase Forum 22 09-04-2006 07:44 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
