Old 04-13-2009, 07:17 PM   #1
mrbond
mrbond's Avatar
lol oh the things you can start when you take off parts of your car.
- A Toyota Yaris
- A whut Yaris?
Old 04-13-2009, 07:26 PM   #2
MGargano
Drives: 2009 Yaris Hatchback
Ordered one from the same guy before everyone else snatches them up! Fingers crossed! http://cgi.ebay.com/ebaymotors/ws/eB...m=170320582267
MGargano is offline   Reply With Quote
Old 04-13-2009, 08:36 PM   #3
pismo61
Drives: 2012 SE
I did this on a 2006 Toyota Tacoma.You needed the cruise control stalk,a jumper wire for inside the steering wheel,a piece that snaped into the side of the steering wheel for the stalk to stick out of,and switch for the clutch.The tacomas are all pre wired.I got the info on a Toyota forum web site pictures and all.It was about 120.00 for all parts.Cant remember the exact forum but its a popular one.Searched it toyotanation.com in the tacoma area.
pismo61 is offline   Reply With Quote
Old 04-13-2009, 10:31 PM   #4
Treyz
~ ambient one ~
Treyz's Avatar
I have no idea how if these new systems work the same as older models, but I do know that on those older models, there was a vacuum canister inside the engine bay for the cruise control. So there deff may be an extra part needed, but again, that was for cabled lder models.
No idea if the rule has changed for DBW.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 04-14-2009, 03:14 PM   #5
elmo
WFO
elmo's Avatar
Drives: 2008 hb
i hope this works i really miss CC
fingers crossed XXXXXXXXXX
elmo is offline   Reply With Quote
Old 04-14-2009, 03:26 PM   #6
firebob
Drives: 09 yaris
I was going to say something about needing a new peace of plastic for the back of the steering wheel or the steering column depending on where this mounts but pismo61 got to it first.
I did a bunch of searching and it looks like the automatics just need the new plastic and the switch. I’m not sure on the manuals but we will see soon.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 04-14-2009, 03:28 PM   #7
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Hi
If it works on your Toyota Yarises, does anybody then know if it will be the same for an European model Toyota Yaris?
If I should buy the Cruise Control kit in Denmark the price is about $600 plus install, but it´s a kit with some extra. I know on the Toyota Avensis from 2004 or so untill 2008 you only need the stalk, two screws and two wires.
Regards Steven.
Danish Yaris is offline   Reply With Quote
Old 04-14-2009, 03:42 PM   #8
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
For the plastic piece ... do you mean where the stalk comes out of? Couldn't you just dremel/drill a hole?
devinlamothe is offline   Reply With Quote
Old 04-14-2009, 03:46 PM   #9
anexrx7
Drives: 08 MM HB
Alright guys, I got one for you in the mean time while you're waiting for your parts. Does anyone have a junker switch available? Or any sort of electronic experience? The reason I ask is you could possibly "build" one to experiment. I would jump on it on my car, but I'm only on vacation for 9 more months 7000 miles from my car... Let me know if you guys are interested because I can still help, I do that stuff for a living.
anexrx7 is offline   Reply With Quote
Old 04-14-2009, 04:03 PM   #10
tk-421
tk-421's Avatar
Drives: 5D-07-LB
PK, this has your name written all over it.
Old 04-14-2009, 04:33 PM   #11
since this is DBW, im pretty sure toyota has removed one of the units that control the cruise control.
PK, if you have time, could you look at the complete wiring of the cruise control ? does it end at some place where there should be a box, but it isn't there??
also, the last thing i know, that if i got the cruise control from Toyota (back in late 06), i would not have gotten the OEM cruise control system...
Old 04-14-2009, 08:28 PM   #12
MGargano
from what i saw in both the EWD and the Cruise Control diagram is that everything is there. The stalk enables the inputs of the ECM that in turn tell the ECM cruise control is enabled. Now does it mean that option is always available or does it have to be enabled at the dealer we will know when we get the stalks. The diagram says the ECM already has the programming necessary for cruise control the stalk seems to be missing for a complete circuit.
As for the steering column trim , there is an outline for the placement of the stalk
Should this work for the 5-speed and auto trans. alike? Or would the 5-speed require something else?
Old 04-14-2009, 08:40 PM   #13
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
the 5 speed uses the clutch switch and brake switch while the auto uses the gear position sensor and brake switch.
ooh, that may be a problem, haha, I crimped off my clutch switch for the remote starter, maybe I can make a bypass switch instead of leaving it crimped off
Old 04-14-2009, 08:54 PM   #14
AlexNet0
AlexNet0's Avatar
cant help you there i have no clue how your remote starter is connected sorry
I was just thinking out loud. I basically removed the clutch switch and the starter is permanantly enabled, not just when the clutch pedal is pressed. When i do this, if it works, I will have to install another switch.
Old 04-14-2009, 08:46 PM   #15
MGargano
Does this mean, if all goes according to plan, that I'll need something other than the eBay stalk to make this work? This is assuming, of course, that the eBay stalk does what we all hope it will.
Old 04-14-2009, 06:12 PM   #16
firebob
Drives: 09 yaris
Just form the reading that I found all the wiring is there and the ECM dose the rest if you have the switches.
Old 04-14-2009, 08:53 PM   #17
MGargano
ok thanks. Fingers crossed that this goes as planned!
Old 04-15-2009, 01:41 PM   #18
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
...because i hate waiting for shipping, i stopped into the dealer to see the cost on this. $125 for the stalk, and if needed, either $44 or $16 for the jumper. then again, this isn't a tacoma; do we need it?
and the moral of the story: wait for the shipping!
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
