Old 05-07-2009, 12:00 AM   #37
ChinoCharles
Drives: LB
Ok, call me stoopid but what does missing second mean? You don't get the transmission into second gear crisply so you slow down while you're off the throttle?
very nice and congrats on the 1/4. about you missing second is it possible you weren't clutching all the way in, you know in the heat of the moment you're not going all the way in?
It isn't that, but...
you grind the piss out of it for a second (generally that slows people down too).
YEP! The stick will just jam on you halfway, but you've already started to let the clutch go and GRRRKKKKKKK fail. Its my presumption that this is caused by the engine bucking around and screwing with the linkage. Sound about right?
I think they Yaris has pretty TALL gears. At least compared to the other FWD cars I've raced in
Did I just hear you say you were going to swap a 6 speed? Maybe my problems with the gearing are actually rooted in that open diff.
I installed a boost gauge and GUESS WHAT?! 6 psi in third. What that means I don't know, but taking it to a dyno just jumped up the list of crap to do. I'm considering getting the following:
http://www.bulletproofautomotive.com...il.php?ID=5196
http://www.bulletproofautomotive.com...il.php?ID=5195
http://www.bulletproofautomotive.com...il.php?ID=5203
That should help put a little more power to the ground. We shall see...
Two more things... one, I looked back at my slips and realized I ran a .0000 reaction time on one run. LOL, it was the 2.2x 60' run where I missed second. Its the one that got away. That and I got 34 MPG on a tank where I ran @ the track. Yaris FTW.
Old 05-11-2009, 02:18 PM   #38
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Is this the quickest USDM car so far?
If there's one thing I learned from drag racing, it's the fact that i'm not the quickest shifter in the world, but atleast i don't break trannies and gears. :)
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 05-11-2009, 02:41 PM   #39
ChinoCharles
Drives: LB
Documented. That RWD Drift Yaris would kill Garm and I both, but if you don't post the slip it don't count!
Old 05-11-2009, 02:46 PM   #40
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
Did bulletproof confirm the C-One damper will work on the USDM NCP91 cars (since it's not listed to the JDM version either according to C-One)?
Russelt3hPirate is offline   Reply With Quote
Old 05-11-2009, 02:58 PM   #41
ChinoCharles
Drives: LB
I'll e-mail them and ask. I'll let you know.
Old 05-11-2009, 02:59 PM   #42
probably shifting too fast...or that the tranny is hot from punishing it...
i take it you've never drag raced...
nice times though chino...but it always sucks when someone else can drive your car faster than you can...
Old 05-11-2009, 03:02 PM   #43
Russelt3hPirate
l33t3st Asshole
that's the best, it proves you have some free mods you can still do.
aka. learn to drive chino!!
Old 05-11-2009, 03:02 PM   #44
ChinoCharles
Drives: LB
It won't last long. I'm getting better.
Don't forget I beat his 60' on that run by .2 seconds. If I could put a good front and back half together I think I can run a 14.6-14.7 @ 6 psi. That isn't bad if you ask me.
Old 05-11-2009, 03:07 PM   #45
Russelt3hPirate
l33t3st Asshole
the last post sounded like you already had talked to them about everything and had the stuff on order.
Old 05-11-2009, 03:09 PM   #46
ChinoCharles
Drives: LB
Noooo, I did talk to them but I talked to Garm too and he convinced me to try the torque damper first and see how that goes before I make the leap to the tranny mount. From what I hear (another member here has it) it pretty much makes the car undrivable under about 2,000 RPM.
However, it should fit. Bulletproof was a vendor here back in the YW stone age and they pushed those products hard, but like I said I'll double check.
Old 05-11-2009, 03:20 PM   #47
Russelt3hPirate
l33t3st Asshole
please do, as everywhere else it says it's not designed for the NCP91
here it is installed on the NCP13, if you want to be the $300 guinea pig I wont stop you.
Old 05-11-2009, 03:25 PM   #48
ChinoCharles
Drives: LB
OHHHH I get what you're asking now.
THAT part. I've got the Nitto version coming this week.
Old 05-11-2009, 03:41 PM   #49
Russelt3hPirate
l33t3st Asshole
that's the one i've been talking about.
the other two parts you have listed fit no problem as long as you're ok with the NVH. (C-One lists those for the NCP91).
Old 05-11-2009, 05:27 PM   #50
i had Energy Suspension polyurethane mounts on my xrs and it was perfectly driveable....just transferred more engine vibration thru to the steering wheel and chassis and stuff....but in no way was in uncomfortable or remotely undriveable.
sure stopped the wheel hop when launching...
Old 05-11-2009, 05:40 PM   #51
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
I think they Yaris has pretty TALL gears. At least compared to the other FWD cars I've raced in (tC, xB)
Agreed. I didn't have too many problems when I went to drag a few weeks ago...but my car is also a lot slower than your's and Charles'.
Wanted: Forced Induction
Old 05-11-2009, 06:22 PM   #52
Russelt3hPirate
l33t3st Asshole
no you're right i never drag raced, not really my thing and i find it punishes the car too much, im more of a circuit kinda guy where my front wheels actually turn side to side lol.
3 30 minute sessions WOT isn't less punishing. (it is cooler though).
Old 05-11-2009, 06:27 PM   #53
Russelt3hPirate
l33t3st Asshole
i was referring more to the clutch/transmission punishment. but hey my suspension takes a beating when im hugging the kerbs
you don't shift while on the track? haha.
i know you bang through the gears coming out of the corners.
unless you're autoxing where it's a 1-2 shift and that's it.
either way, just glad people are getting out there. :D
Old 05-11-2009, 06:28 PM   #54
ChinoCharles
Drives: LB
Tires came in today. If the stars align and my torque damper gets here tomorrow I MIGHT run tomorrow, but if not it'll be Tuesday. I want that 100 MPH trap!
Vitz (1st Gen) Tid Bits Airknight General Yaris / Vitz Discussion 1 03-09-2017 04:24 AM
My JDM Yaris..(Vitz Rs Wannabe) ^^ davinelika Photo-Video-Media Gallery 20 10-05-2010 08:08 AM
A German Yaris/Vitz/Echo ;) we-to-11 Photo-Video-Media Gallery 5 06-27-2007 08:26 PM
JDM Vitz Parts!! MC-BPT Sponsors Classifieds Area 20 06-20-2007 02:44 PM
Whats the Diff between a JDM Vitz vs A US Yaris vs an Asian Yaris. nurburgring General Yaris / Vitz Discussion 5 03-23-2007 09:03 PM
