Old 09-09-2015, 07:26 PM   #37
MUSKOKA800
MUSKOKA800's Avatar
I'm running 1zz injectors with my Blitz set-up. I do get a 'Too Rich' code in the winter, likely due to choke but have no CEL spring, summer or fall.
Old 09-09-2015, 09:25 PM   #38
AzianCuz
conundrum562
AzianCuz's Avatar
Drives: Toyota Yaris 2007 S
I hope I don't get that...
BLITZ SC | CERAMIC 6301 BEARINGS | MICRO-IMAGE CRANK | NST PULLEYS
TRD 71C THERMOSTAT | 1ZZ INJECTORS | TB SPACER | BLITZ SRI
NGK PLUGS, COILS & MAF | DC HEADERS | CUSTOM 2.25" EXHAUST
GTSPEC STRUT BAR, MID & 4-PT LOWER BRACES
TANABE FRONT & WHITELINE REAR SWAY BARS W/ POLY BUSHINGS
TBW SKID PLATE | FULLRIVER AGM BATTERY | MOBIL 1 EP + PROLUBE
AzianCuz is offline   Reply With Quote
Old 09-10-2015, 08:29 AM   #39
not to hijack this thread but where are all of you guys sourcing your blitz S/C's from? It looks appealing to do down the road vs a T/C due t much less work required t install a S/C. I'm curious to the price and what it all comes with
Old 09-10-2015, 08:42 AM   #40
MUSKOKA800
MUSKOKA800's Avatar
Bought mine used from an Edmonton member several years back.
Old 09-10-2015, 08:45 AM   #41
AzianCuz
conundrum562
AzianCuz's Avatar
Definitely worth it in my opinion if you are going to drive the car until the wheels fall off.
Price is around $3000-$4000 now a days, depending on where you get it from. It is sourced straight from Japan, the kit is a Complete Bolt on but I found out from the installation that you need a tighter belt and added the 1zz injectors to make it run efficiently, Since I have other performance parts. But I believe the kit should run fine if you have everything stock, so far I love driving this car now and it picks up pretty quick for a Yaris ha-ha.
I got my S/C from A1-Motorsports and you can negotiate pricing. Took about (3-4 Months) to get...
If you are planning to go (SPEED RACER) then no the kit is not worth it, but if you're trying to get an extra boost and a better driving experience with Fuel Efficiency then yes it's worth it. In the end to each their own. But I love it!
Old 09-10-2015, 04:03 PM   #42
KTS
KTS's Avatar
Drives: Vitz RS
I am experiencing audible ping/detonation even with 1zz injectors.
My only mods are a K&N filter in the stock air box and a Fidanza flywheel along with an aem water/meth kit.
My afr at wot are around 10.5 and still I hear the audible ping/detonation.
I am using ngk7 plugs and 95 octane fuel.
When I check ing advance using techstream it is reading in the single digits at wot when I hear the ping/detonation.
Can someone suggest what is causing this. I do have a check engine light on related to the egr thingy on the intake side of the head which was removed for the s/c install.
Thanks
KTS is offline   Reply With Quote
Old 09-10-2015, 05:20 PM   #43
Thanks for the info Azian, looks like i'll be saving up for an S/C down the road...
Old 09-12-2015, 06:51 PM   #44
MUSKOKA800
MUSKOKA800's Avatar
Watch for a used one. I paid CA$1600.00 for mine and that included complimentary extra aftermarket goodies.
Old 09-12-2015, 09:04 PM   #45
Wow, that's a damn good deal. The msrp in my opinion isn't worth it, but $1600 is great
Old 09-16-2015, 08:53 AM   #46
AzianCuz
conundrum562
AzianCuz's Avatar
Yeah just look around bro, I'm sure you can find really cheap ones, I personally wouldn't get a used kit but if you know your cars and can fix parts yourself by all means. But I am loving the ride and throttle response. Everyday I try to keep myself from stepping on the pedal hard ha-ha!
Drive regular, Drive regular
then VROOOMMMMMMMMMMMMMMMMMMMMMMMMMM!!!
Old 02-10-2016, 10:16 PM   #47
AzianCuz
conundrum562
AzianCuz's Avatar
Lightbulb 2007-2014 TOYOTA YARIS L4 1.5L 1497cc 1NZFE
Good evening my fellow YARIS-ians,
I was wondering if anyone used this injector before? They claimed it flows at 1497cc and I am wondering if that's overkill for us? FYI I upgraded to the 1ZZ and it's working but I just want to know, if it can get me more gains I might switch over.
Anyways see link below and as always appreciate all feedback:
http://www.fiveomotorsport.com/fuel-...toyota/?v=3880
Old 02-16-2016, 06:21 AM   #48
alias06
Drives: 2008 Red Toyota Yaris
That link shows fuel injectors that are matched for a 1nz meaning that they flow the same for each injector so that each cylinder will get the same amount of fuel, which should then result in a smoother running engine, I doubt that you'd get any kind of beneficial results by just switching over to them. The fuel injectors themselves do not flow 1497cc. It would be overkill for the 1nz, the 1497cc that they are referring to is most likely the engine size of the 1nz, 1.5L or approximately 1500cc (1497cc). Also the 1zz injectors already flow more than the 1nz injectors, reverting back to 1nz injectors would be pointless in your application...
alias06 is offline   Reply With Quote
Old 02-19-2016, 11:25 AM   #49
AzianCuz
conundrum562
AzianCuz's Avatar
Appreciate the feedback, that's what I figured, I was like isn't that much flow over kill lol. Anyways thanks again and btw the 1ZZ injectors from that site works GREAT!!!
Old 04-29-2016, 06:31 AM   #50
Gorilla
Gorilla's Avatar
Drives: Vitz & Supra
Guys are celica 2zzge injectors recommended for sc 1nzfe or 1zz sufficient?
Gorilla is offline   Reply With Quote
Old 04-30-2016, 10:11 AM   #51
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I use 1zz injectors in my Blitz'd Yaris. I run a AFe short ram intake and don't have any problems going lean with the 1zz injectors.
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
