Old 05-27-2009, 02:04 AM   #1
Swallow
Swallow's Avatar
Drives: Yaris Sedan YRS
Originally Posted by Jeemee View Post
Mine too has a strange noise coming from engine bay. It's random and sounds like a really bad CV Joint. Like a pop sort of. Never figured out what it was. Is yours similar sounding?
Is yours sound like a heavy thing jumping up and down when you pass over pavement upward bulges?
ONLY YARIS !
Swallow is offline   Reply With Quote
Old 05-26-2009, 12:18 AM   #2
supmet
Drives: 2007 4 Door Yaris
My engine rattle comes from the air filter. The inlet tube(the kinda spirally black plastic piece in front of the actual air box) is loose(broken?) and vibrates against the airbox with the engine vibration. I'm gonna epoxy it some day, but I'm pretty lazy.
I also have the rattle from the TSB, but that one is clearly coming from the dash, not the engine.
Old 05-27-2009, 02:03 AM   #3
Swallow
Swallow's Avatar
Thank you 4 ur reply. But unfortunately, I checked it that was not my case.
ONLY YARIS !
Old 05-27-2009, 10:14 PM   #4
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
I don't think so. Never realized how hard describing sounds are. I don't know what it could be.
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
engine swap update Adriaan Canada 5 03-03-2009 06:21 PM
