Old 07-08-2009, 06:04 PM   #1
mrbond
mrbond's Avatar
So what's the update? How exactly did you get it to work?
- A Toyota Yaris
- A whut Yaris?
Old 07-08-2009, 06:13 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
it involves resistors.. the tC guys had the same problems (07+) that were all corrected with simple radio shack purchases :) look up AEM FIC in the tC forums on www.scionlife.com
Old 07-09-2009, 04:40 PM   #3
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Tamago, I was looking into the resistors mod but it looks like the problems this mod fixes is a random misfire between 3k-4k rpm... Not quite the problems we've read here about the FIC.
I'm getting curious bout the FIC as I will be getting one soon...
My idea is to try to install it on the NA car and see if i can get it to work... If I do... I can start thinking about the FI possibilities....
Would this be a good idea at all? Try the FIC first on the NA car? My logic is that if I can get it to work NA, it should also work with FI.
cdydjded: Any updates on your progress?
Old 07-08-2009, 09:51 PM   #4
saplaymate
saplaymate's Avatar
Drives: 08' HB
I love this thread
0 - 60 in 3 shifts
saplaymate is offline   Reply With Quote
Old 07-09-2009, 05:49 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
what was garm's issue? i thought it was missfiring.
Old 07-09-2009, 06:40 PM   #6
CASTREX
CASTREX's Avatar
Was it Garm?
Old 07-09-2009, 08:29 PM   #7
I had a misfire and a blinking CEL above 5000 rpm, and the car wouldn't idle for more than a few seconds before dying.
Old 07-09-2009, 09:43 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
blinking CEL comes from misfire code.
what diameter intake did you have you MAF mounted in?
Old 07-09-2009, 09:47 PM   #9
we tried 2" piping, that was too small, so we opened it up with some piping from a Subie (pretty sure), and that seemed to work pretty well, except for the problems.
Old 07-10-2009, 12:36 PM   #10
CASTREX
CASTREX's Avatar
...So the resistors mod could actually work to fix that misfire problem, but leaves the bad idle problem still to be address.
Well... will see how it goes.
I will attempt to install the FIC on the car NA. If it works then I will be saving for some real power mods...
Tamago, any inputs on how to get the FIC to work on my car will be highly appreciatted.
Old 07-10-2009, 12:38 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
you want to buy mine? PM me.
Old 07-10-2009, 12:37 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
most likely the bad idle came from an insufficient tune exacerbated by the odd MAF housing diameter. i had idle issues as well that i was able to tune out over a little bit of time.
Old 07-10-2009, 12:40 PM   #13
cdydjded
Drives: Yaris LB Turbo
Im 100% sure that Garms problem was the injectors that he had installed. Resisters are not needed. My problem was "installer" (me) hooked up some of the wires wrong the first time.
cdydjded is offline   Reply With Quote
Old 07-10-2009, 12:47 PM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
we all did ;)
Old 07-10-2009, 12:51 PM   #15
CASTREX
CASTREX's Avatar
So you got it running already?
And why would the TC (320cc) injectors be a problem? What would you advise instead? The OE injectors should max out pretty quickly after 5psi of boost or so...
Old 07-13-2009, 06:40 PM   #16
cdydjded
You can only go +20% larger injectors without the ECU going crazy, its a common problem on newer cars
Old 07-13-2009, 06:51 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
1zz injectors are the answer :)
Old 07-13-2009, 07:05 PM   #18
CASTREX
CASTREX's Avatar
That sucks... as it would limit the power badly.
I thought the +/- 20% was the amount of variance that the stock ECU could handle... but with a FIC I was expecting to be able to handle even larger injectors. At least that's what AEM says...
Didn't you ran TC injectors on th xA as well?
I wonder if the TC injectors would be a good fit for the 2ZR-FE (1.8L) engine on a boosted application.
I haven't been able to find what the CC rate is for the OE injectors on this engine so I can't tell what is the flow difference.
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
AEM FIC works in Yaris......Sort of cdydjded Performance Modifications 32 12-06-2009 01:58 AM
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 05:52 PM
AEM UEGO Wideband ONLY $220! 365Motorwerks Sponsors Classifieds Area 0 11-22-2008 11:02 AM
2007 Toyota Yaris Hatchback AEM Intake KenAEM Performance Modifications 6 03-24-2007 11:47 AM
