Old 05-28-2009, 08:08 AM   #1
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
near fort lauderdale, but not for long-- planning on moving to south carolina for a temp position
Old 05-28-2009, 08:30 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
ah! i'm downtown ft laud!
interested in hub spacers with free installation?
Old 05-28-2009, 09:03 AM   #3
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
A grippier tire allows the car to enter the corner at a higher speed, maintain a higher cornering speed, and allows you to get onto the throttle sooner on the exit.
If your crap tires have never lost grip, then perhaps you aren't on the tire's limit yet.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 05-28-2009, 09:12 AM   #4
regal
Its not a tire issue, when I toss into a turn the whole car's momemtum flies foward pushing me into the steering wheel, Its like the entire body of the car is pushed foward like being rearended. With my other cars Civic, Jetta, BMW, etc you enter a turn pushed back firmly in your seat.
Old 05-28-2009, 09:24 AM   #5
SailDesign
Drives: .
That sounds simply as though you are hitting the brake instead of the throttle pedal. Is there another way you can describe this that might help us understand.
Also, you ask about what else a tire does other than grip. The sidewalls are very important, and tire pressures play into the eway they behave in cornering - hence all the beating of dead horses about tire pressures. A flimsy sidwall (like most OEM tires) will be lovely and comfy, but distort under cornering, allowing the tire to "scrub" and produce understeer. Higher pressures help with those, but stiffer sidewalls on better tires do more.
Old 05-28-2009, 09:25 AM   #6
cleong
cleong's Avatar
How are you entering corners, on power or off power? It is usually recommended to finish all your braking in a straightline, and feather your throttle through the turn until you reach the apex where you nail it to the floor.
On the other hand, the Yaris's seat is particularly high, which may amplify the G-forces beyond what you are familiar with. Physics remain the same regardless of which car you're in.
TRD Blue brake pads
DC Sports header
Old 05-28-2009, 10:07 AM   #7
regal
Agree on the seat, Need to find a way to lean it back.
Old 05-28-2009, 09:43 AM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
trail braking in a smaller FWD car seems to help VERY much with rotation
Old 05-28-2009, 10:05 AM   #9
scape
scape's Avatar
@ tamago,
downtown ftl is nice ;D although riverfront has changed a bit over the years, bit more run down now haha
Old 05-28-2009, 10:07 AM   #10
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
the flooring at the apex is the most important part...
Its a Chao!!!
Old 05-28-2009, 11:03 AM   #11
scape
scape's Avatar
is engine braking recommended at all before the apex while going into a sharp turn?
Old 05-28-2009, 11:04 AM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
depends on many factors.
alignment setup
tires being used
tire pressures
what gear you're in/how fast you're going
sometime swing by the shop i'll take you for a spin, show you what i'm talking about :D
Old 05-29-2009, 10:20 PM   #13
jkuchta
Drives: 2007 Yaris hatch (red)
Never enter a corner with the clutch pedal depressed.
jkuchta is offline   Reply With Quote
Old 05-29-2009, 04:33 PM   #14
regal
how much toe out is recomended in the rear?
Old 05-29-2009, 04:44 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
if you can get 0 toe, that's ideal. i'm running 1/8" toe out each side
Old 05-30-2009, 11:07 AM   #16
regal
What about these ULTRA RACING rear under braces seems these would firm up the rear and help with the understeer?
Old 05-30-2009, 05:03 PM   #17
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
If you want to waste your money, sure.
If you want to spend it on something that will help, get their 23mm rear sway bar, a performance alignment and shim the rear hubs.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
