Old 06-13-2009, 04:10 PM   #37
EdgarTRD1.8
Drives: SR5 Hatch Back 82' 3TC 1.8
Send a message via MSN to EdgarTRD1.8
Which TB you put on it??? I know someone told it but check if the TB port match because you'll have a restriction over there, remember it will suck air from a 1.75" or something like that in the stock port of the 1nz vs if you port to 2.25" like the 1zz or the TB you used. If you don't port will not gain too much.
EdgarTRD1.8 is offline   Reply With Quote
Old 06-13-2009, 06:00 PM   #38
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Es el throttle de Corolla o Matrix 1.8 no XRS
I Drive a 129whp Yaris ;)
Old 06-14-2009, 05:28 AM   #39
EdgarTRD1.8
Ok yo estoy haciendo una ara~a en aluminio pa ese throttle despues te envio par de pics... y estaba pensando hacer spacers en plastico y aluminio...
Old 06-15-2009, 12:23 AM   #40
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Me avisas cm va ese proyecto
Old 06-26-2009, 04:11 PM   #41
2bad4u
Drives: 06 Toyota Vitz RS
I had a Brospeed on my 98 Civic, too. I bought it in 2004, I think. Well made, inexpensive, too.
I paid about US$112 installed, great sound will post youtube asap, just trying to do the tb swap this weekend hoping to pickup a 1zz tb at any of the local used parts shops if not I'll get it from Garm, set up with the swap already.
2bad4u is offline   Reply With Quote
My DynaPack Dyno Results. PETERPOOP Performance Modifications 63 03-10-2009 06:02 AM
TS/Xd Long Tube Header & Intake dyno results richardholdener Yaris TS Talk 21 01-06-2009 05:28 AM
Long Tube Header Dyno results & Photo richardholdener Performance Modifications 59 11-26-2008 05:27 PM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 06:03 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
