Old 07-28-2009, 10:15 PM   #37
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Last bar means you've got right about 1 gallon left.
Old 07-31-2009, 09:13 PM   #38
minicorolla
Drives: 2008 Sedan White
A comparison:
This week I'm doing everything wrong, Driving 70MPH, hard acceleration, etc. just to see what I get. Mostly the same route but with more freeway. After driving country roads, I hate the freeway even more! I fill up tomorrow.
minicorolla is offline   Reply With Quote
Old 08-02-2009, 08:52 PM   #39
minicorolla
423.3 Miles, 10.222 Gals. = 41.4 MPG.
Guess I didn't try hard enough.
Going back to the country roads tomorrow.
Old 09-14-2009, 03:27 AM   #40
microbe__
Drives: yaris d4d
hi friends,
those numbers do not sound reasonable to me. we here drive 1.4 D-4d diesels and nearly reach 45 mpg
may be its cuz of fuel quality or something else
i always drive carefully trying not to pass 55-60 mph, use the throtle as if there is an egg under it :) and take the cut off in to account..with these driving habits here is my calculation.
37lt 690 km
9,77Gallon 428Miles...i guess it corresponds to 44 MPG
am i doing something wrong or do you guys run on uranium
microbe__ is offline   Reply With Quote
Old 09-14-2009, 09:24 PM   #41
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
minicorolla: You're doing great so far, I beleive you should heed more of Woody Woodchuck's advice more. Try harder to stick to the lower mph and you should reach more consecutive 45mpg numbers. I hate to use these sayings but... 55 will get you 45 (or more).
microbe: Your numbers seem correct, you are definitely using US gallons and not imperial gallons. You actually have the advantage being the diesel. There is a European member here whom I'm very jealous of, he gets from 50-55mpg easily on the diesel. I don't know how to address your problem.
Old 09-17-2009, 09:24 AM   #42
Zaphod
Drives: Big Yellow
Originally Posted by talnlnky View Post
there are tons of factors when going that speed. Drifting behind a semi I can get very high numbers, even when doing 70.
You can expect to see around 5-10MPG difference on average between the two speeds... especially if you don't try the "Hangtime" skill... Tho hangtime I think has been exaggerated, it does help. I don't think it really has anything to do with ECU maps or whatever, but rather physics of energy & torque required to speed up versus energy/torque required to maintain speed.
There are some times I notice that going slower makes it harder to get good mpg's than slightly faster... for example... I find it easier to get good numbers going around 60mph than 55mph on the highway I use to go home. Regardless of of fast I go I seem to use the same throttle possition after I get up to speed and back off on the trottle a bit. So really, the slower speed, but same usage of gas means I get lower mpg at 55. That doesn't appear to be true on all roads/highways tho.
Still haven't gotten to 45 yet. I lowered my tires back down to 40psi... so I don't know if i'll see it ever. 43's seem to be what I see. I had one 250+ mile trip that I got almost 48mpg on, But not for a full tank.
I just got 54.5 on a trip from St. Louis to Indianapolis and back with some city driving in between. That's no scanguage/ecometer, and the car still hasn't even had it's first oil change (although I'm doing that today just to get it out of the way before winter kicks in).
I usually get 43.6 average between my tanks, but the biggest factors for me was the city to highway ratio, and the fact that the engine was warmed up well as normal daily trips are just not long enough to warm up fully.
Of course, I hypermilled big time to prove a friendly point to a Prius owner, allowing for 45-60 on hills and generally cruising at a mere 50 on relatively flat stretches. I was able to achieve all of that staying within the speed minimum/maximum ranges fairly easily. I don't think I could have gotten above 50 by just remaining at 60 the whole way, especially on the hills.
I've yet to hear from someone tailgating a semis (which is dangerous anyway) achieve those same numbers, and doubt I ever will as they're still running their engine at higher RPMs.
Zaphod is offline   Reply With Quote
Old 09-17-2009, 05:04 PM   #43
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by twowheels View Post
I have a hard time hitting 45 MPG consistently. My last fillup: 200 miles, 100 degree heat, 55 MPH and slower, no stop-and-go, A/C running as little as I could stand, slow acceleration, etc... still only 42 MPG. One problem that I face with this trip (which I make frequently) is the delta breeze that blows in from the ocean and into the valley... for half of the trip I'm facing directly into the wind and the tailwind for the first half does NOT make up for the losses on the way back. The wind is always blowing and always in the same direction during this trip.
as long as I don't do highway trips of more than 100miles I seem to be able to be in the 44-46mpg range very consistently. My commute to work is now what keeps my mpg's up... it used to be what kept it down. I'm hoping to be getting 40+ mpg tanks throughout the winter. Last winter i saw my tanks drop down to 37-38mpg.
Old 09-28-2009, 08:43 PM   #44
minicorolla
45.9 and 45.7 for the last two tanks. Not too bad. After my last fill up, I talked to a guy at the next pump with a Honda shadow. He gets 44 mpg at 70. Got his attention! I just didn't tell him I drove 63 mph or less. Let's see how I do with the winter gas coming up.
Old 09-28-2009, 09:24 PM   #45
2+2
Drives: 09 3Dr Manual
Just to let you know, I drive a semi and when I see someone trying to catch a draft back there I usually slow down until they give up and go around. I'm not even sure why I do that. I mean if anything goes south while they're back there and they end up underneath my trailer it's their fault not mine. But then I guess my to-do is full enough and I just hate the thought of adding keeping them healthy to the list. That probably sounds cold and I guess it is.
Congrats on the 45 mpg!
2+2 is offline   Reply With Quote
Old 09-29-2009, 08:23 PM   #46
minicorolla
If I'm behind a truck, the driver will see my headlights. I draft at sixty, one hundred feet. Don't like driving blind. Slower is better!
Old 10-07-2009, 08:41 AM   #47
1stToyota
1stToyota's Avatar
I just went over 45 mpg for the first time [45.17], using Sinclair, not using the a/c this week except for a couple of days, running 28 psi for 5 of those days ...and managing to break the speed limits every day.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 10-07-2009, 08:53 AM   #48
DevilGirl
Drives: 09 3dr LB MT
Flat roads? Or nice rolling hills that never stop, but just keep on "rollin, rollin, rollin"?
Old 10-07-2009, 09:27 AM   #49
1stToyota
1stToyota's Avatar
Roughly 2/3rds boring, flat highway, 1/3rd boring flat city driving, but I usually avoid the heaviest traffic because I'm ahead of morning rush hour and later than the evening rush hour, except on Wednesdays I get in a little bit of the 5pm mess.
2008 Scion xD
Old 10-07-2009, 09:45 AM   #50
DevilGirl
I'd love flat roads! At least a few of them anyway. My commute consists of mostly highway (speed limit of 65, so I usually hang around 70). But because it's a constant up and down, up and down, up and down, the entire 50 miles there and back, I'm luck to get even close to 38, let alone over 40. And that's with really cutting back on my hard accellerations.
Old 10-09-2009, 08:01 PM   #51
minicorolla
45 is a magic number. makes you feel good when you reach it.
Old 10-10-2009, 01:19 PM   #52
kameele
Drives: 2009 Zephyr Blue manual sedan
I've had my first two fillups on my new sedan and made about 41.5 mpg each time. I have a 50 mile each way commute that's 95% highway. I was traveling about 65 with the cruise control on. I still have to fill up every 4th day, but put a lot less in each time. Big change from the 25mpg I got with my Outback. Looking forward to many more of these happy fillups!
kameele is offline   Reply With Quote
Old 10-11-2009, 10:45 AM   #53
minicorolla
try 62 and lose the cruise.
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
Why is my new 09 Yaris MPG is so low soup1207 Fuel Economy Forum 34 06-12-2009 03:45 PM
52.60 mpg Kaotic Lazagna Fuel Economy Forum 42 05-19-2009 01:45 PM
Help me see 55 mpg! Loren Fuel Economy Forum 76 04-02-2009 04:23 PM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 05:48 PM
