Old 10-20-2006, 12:15 AM   #37
Centurion2200
Centurion2200's Avatar
Drives: Yaris Hatchback 07
Send a message via MSN to Centurion2200
hmmmmmmm this is weird........im seeing the pics of your engines........my Hatchback is 1.3 but the throtle body isnt in the place as katana's......but its in the same place that the 1.5 in the picture.......hmmmmmmmm
Centurion2200 is offline   Reply With Quote
Old 10-20-2006, 01:43 AM   #38
jmew0ng
Drives: Scion FRS
throw in some pics ^^ maybe you got a 1.5 instead and they never told you haha
jmew0ng is offline   Reply With Quote
Old 10-20-2006, 08:12 AM   #39
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Τhis is really weird...
Tell me the code of your engine.
Mine is coded 2SZ-FE.
Old 10-20-2006, 08:13 AM   #40
Katana
Katana's Avatar
I am sure that you are not confusing the airbox tube to the throttle body, correct?
Old 10-20-2006, 08:55 AM   #41
Centurion2200
That's the difference....mine is a 2NZ-FE.....1.3 .....it looks the same as the 1NZ-FE (1.5)....but the cilynders are smaller...
i think i can use the 1.5 intake.....
Old 10-20-2006, 09:12 AM   #42
Katana
Katana's Avatar
Ηaha, it appears that you have the old 1.3lt engine, that was fitted to the old Yaris.
How come did this happen?
Old 10-20-2006, 09:15 AM   #43
Katana
Katana's Avatar
Αnd yes, you can use almost everything that is made for the 1NZ-FE(1.5lt).
Old 10-20-2006, 09:49 AM   #44
Katana
Katana's Avatar
Αre you sure about it?I need a picture of your engine if you can.Tell me exactly what it says in the manufacturer's book.
Old 10-20-2006, 02:38 PM   #45
regulus
Drives: yaris sedan
Originally Posted by ChinoCharles
The more oxygen present in the cylinder, the less fuel it would take to start an ignition... since oxygen feeds fires by default a spark applied to a smaller amount of fuel with more oxygen in the cylinder should result in a strong enough ignition to complete the cycle. The MAF sensor would mitigate this and the result would be improved mileage.
Know that most people will tell you a CAI is SUPPOSED to improve mileage. The difference may be negligable on a 1.5 L 4 banger, but as your engine gets larger the difference should become more noticable.
If the computer managing the engine is set to keep the gas/oxygen ratio the same the CAI means more gas in the chamber.
Ignition might be easier with more oxygen but im not sure the computer is concerned with that when the engine is warm.
Last, expansion is due to the increased volume of compounds in the air phase in the chamber (CO2 and H2O) after ignition and the increased temperature.
In physics you cannot gain anything from nothing. You loose somewhere and this is on gas efficiency
regulus is offline   Reply With Quote
Old 10-21-2006, 02:00 AM   #46
obylium
Drives: 07 Yaris Sedan S, black/bisque
I've heard some real-world gains with Tornado's and related products, but it could be bullshit. I've never had one myself so I can't really vouch for it. IMHO if you're one of the people looking to stretch the gas mileage on your Yaris (I'm not that person) go drop the 15 bucks or so on a vortex generator and test it out. What do you have to lose?
As far as how it affects mileage, I don't know much about cars but I do know my math and science (physics) and I'll propose this idea and someone smarter can correct me if I am wrong, but... in the intake there is a sensor for the amount and composition (temp, speed, etc) of air coming into the engine, and according to this reading fuel is richened or... uhm... stoicized? (thinned out haha) Like I said, CAI means more oxygen which means the engine (with the MAF sensor info) will "know" it doesn't need as much fuel and will use less accordingly. I don't know a wrench from a mouse, but it makes sense to me.
I actually have one of these vortex generators on order and it should come in within a few weeks. I can let you all know if there is improvement, if any on my new CAI.
obylium is offline   Reply With Quote
Old 10-21-2006, 03:41 AM   #47
Katana
Katana's Avatar
Yeap, keep us posted!
Old 10-23-2006, 12:33 PM   #48
Centurion2200
where did you get the adapter to plug the MAF sensor?...or did you cut it from the stock box....
Old 10-23-2006, 01:19 PM   #49
Katana
Katana's Avatar
I made one from aluminium.
Old 10-27-2006, 12:05 AM   #50
Centurion2200
this weekend i'll install my custom made intake :)..... pics comming soon ;)
Old 10-27-2006, 01:50 AM   #51
LOL don't expect any improvement, but more likely a decrease in performance... those things are the scam of the century, Popular Mechanics even did some in-depth tests on a variety of such cheap "performance-improving" devices and found them to be absolutely useless.
Just think about it, after going through your filter and any bends in the air intake, isn't the air flow already spinning around in all directions? Why add a device to add turbulence when it's already there? All it's gonna do is create a restriction to the air flowing in... And, since they're so simple and cheap to make, and make such improvements to power and fuel consumption, why wouldn't the manufacturers have them pre-installed?
Just think about that
Old 10-27-2006, 10:53 AM   #52
Katana
Katana's Avatar
Well described!
Old 11-08-2006, 05:53 AM   #53
Katana
Katana's Avatar
Guys here is a video from inside the car, when testing my CAI on 2nd gear
http://www.youtube.com/watch?v=EuDmVOBovNA
Old 11-08-2006, 10:53 AM   #54
ChinoCharles
Drives: LB
Nice video (again). You can hear it start to hiss about halfway through. Now, how to fly to Greece to steal your cluster...
Going for test drive Monday; I'm gonna custom order one YarisBlazer New YARIS Purchase Forum 9 05-24-2007 07:52 PM
Custom Exhaust dngz Performance Modifications 17 10-28-2006 09:12 PM
Is it hard to order a custom one? YarisBlazer New YARIS Purchase Forum 29 08-02-2006 02:25 PM
Custom Paint Job Blenjar General Yaris / Vitz Discussion 8 07-30-2006 09:21 PM
