Old 07-23-2009, 06:39 PM   #1
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
The source of your pinging is carbon deposits on the cylinder head/pistons. You might consider having the head removed and decarbonized. Also ask them to check your valves and guides for replacement. (valve job) You really want to consider replacing the valves at this point because its POSSIBLE the head of one of them (probably an exhaust valve) could break off and smash up the engine. Your mileage decrease is probably due to valve sealing issues. I also have to believe your timing chain should be checked/replaced too. If it breaks it will destroy the engine. BTW have you had the ball joints/tie rods/steering rack checked? Any failure here and you crash/die. Good luck with it!
bronsin, I appreciate your technical input and suggestions. But, it's a Toyota I drive, not an American POS. I'm sorry if I sound ignorant. But, with the amount of driving I do, your average mechanical theory does not apply to me. Some maybe, but not all.
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 07-23-2009, 07:43 PM   #2
bronsin
bronsin's Avatar
Well Allrighty Then!
Old 07-24-2009, 10:49 PM   #3
Kal-El
Kal-El's Avatar
When is the video coming up?
Old 07-25-2009, 12:47 AM   #4
PhilD424
Drives: Red Yaris
American cars are pieces of shit? Thats some attitude you got there.
-Phil
PhilD424 is offline   Reply With Quote
Old 07-27-2009, 06:22 PM   #5
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
I've had a few cars get into the 200k mileage, so I'm glad you write about the obvious need for maintenance, b/c I don't think the OP is doing proper maintenance (brakes, balljoints, etc.), especially when safety is a factor. I also mentioned the valves earlier, but I don't think I went into detail as you did here. i'm not sure what else the tapping could be, as valves go at this point in time.
@ trini: but still, 350k is amazing, are you the google maps guy? lol
I knock on wood for you!
Old 07-23-2009, 07:20 PM   #6
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
well said... +1
Its a Chao!!!
Old 07-24-2009, 11:00 PM   #7
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
A used engine with under 20,000 miles can be had for less than the price of head removal/valve job, and a maaco paint job good for 2-3 years can be had for under $300..
Bob Dog is offline   Reply With Quote
Old 07-25-2009, 09:01 AM   #8
bronsin
bronsin's Avatar
Yeah its getting too expensive to have anything fixed! Thats why we need to be DIY. I painted my 67 VW Bus (in two colors) for >$100 in 1980 and when I saw it in the junk yard the other day the paint was still pretty good! (five coats of enamel paint)
Theres something to be said for going the junkyard engine route but Id prefer to rebuild my own. You know whats been done to it that way.
Old 07-24-2009, 11:43 PM   #9
A-tron
A-tron's Avatar
Drives: Black hb
Super rad man. It gives me lots of miles to go with my car only just cresting 36000. If it was three years to the date you wouldhave dove 300 miles a day. Lol I like driving but that's a lot of sitting and shifting. Gratz!
Bang those gears
A-tron is offline   Reply With Quote
Old 07-25-2009, 02:43 AM   #10
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
Do you have nst crank pulleys installed?
Red Horse is offline   Reply With Quote
Old 07-27-2009, 01:23 PM   #11
trini_per4mance
NO, I don't have an NST crank pulley installed. I had one, but I sold it.
Old 07-27-2009, 01:44 PM   #12
Split
Drives: 2008 Yaris Sedan
Exclamation
do you have an exhaust system as well? I'm baffled that you'd drive so much with an intake and header, doesn't the noise get to you after a while? I suppose if you have the factory muffler on you're probably okay.
Split is offline   Reply With Quote
Old 07-28-2009, 09:41 AM   #13
trini_per4mance
I have a dynomax exhaust, but cruising at 70mph, you don't hear any intake or exhaust noise. The car is almost as quiet as factory while cruising.
Old 07-30-2009, 04:48 PM   #14
toyo
Drives: toyota
ohh my god that is freaking awesome!!!!! you should contact toyota inmediatly and get sponsored, discounts and you could be on TV lol
awesome dude, freaking awesome..
1st gen FTW
toyo is offline   Reply With Quote
Old 08-10-2009, 05:25 PM   #15
Split
Question
i thought you had a magnaflow exhaust?
Old 07-25-2009, 09:14 AM   #16
Bob Dog
Bob Dog's Avatar
Drives: 07 liftback
The trick is to know what vehicle its coming out of, if you do , you can get almost new everything, and assembly line certainty to roll of the dice rebuilding.
Old 07-25-2009, 11:05 PM   #17
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
trini, you are awesome, I'm glad you've posted again sooner since your last one. Always following your thread and better preparing myself for whatever i must face in the long run of the Yaris vehicle :)
I read the mods on your youtube links....just curious as to what brand of mods they are:
intake
header
lowering springs
strut bar/sway bar
etc...
Thanks as always...
Old 07-27-2009, 06:04 PM   #18
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
In your Youtube links its says under 'more info' you are running under drive pulley/s...so not anymore? or is it a c-one brand?
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
